View Full Version : PS cooler install diagram
J-440
08-11-2013, 10:59 AM
Does someone have a diagram of a rack and pinion, ps pump, and cooler install? I think I have my lines crossed bc my steering wheel turns suddenly on startup (it's on jackstands). Which is the high pressure side of the rack? Also, the pump is REVERSE rotation (had it converted). I have the high pressure Teflon lines as well...just don't think it's routed correctly. Thanks.
J-440
08-11-2013, 11:51 AM
Ok, here's the deal:
Metal section of the pump, it's line goes to the bottom side of the rack (low pressure side?)
Plastic section of the pump, it's line goes to the cooler
The other cooler line goes to the top side of the rack (high pressure side?)
This sound right for a reverse rotation pump?
Bryce
08-12-2013, 05:55 AM
The cooler should be on the low pressure side.
The high pressure side of the pump is the metal body, The return should go to the plastic resevoir.
I am not sure what the rack connetions are. Sometimes they are stamped or cast into the rack body.
