View Full Version : best initial timing: how to find. need guidance.
dusterbd13
08-08-2013, 02:09 AM
small block chevy. unknown compression ratio. unknown cam. automatic trans with 3.42 gears. weiand dual plane intake, 600 holley vacuum secondary, factory HEI out of god knows what. chevelle manifolds and 2.25 dual exhaust.
since we don't know much about this thing, I have no idea what to set initial timing to. we have no mechanical or vacuum advance acting at idle, so were talking pure initial timing.
what methods are there to determine best initial timing? I was honestly thinking of getting the thing to idle as low as possible, and hook up a vacuum gauge. keep cranking in timing until the manifold vacuum starts to drop off, then backing it off 3-4 degrees. what is wrong with this approach? I know the rest of my timing curve will be all sorts of out of whack after that, and I will address that by the same means I always have: dial back timing light to get an idea of total timing, figure out how much total mechanical it can stand before detonation on junk gas/heavy load/high throttle, and then figure out where the curve is happy. then add in as much vacuum advance as I can.
but this post is about initial timing, and how to determine where to set it. please advise. wanna get this done and get the ignition started to be sorted prior to getting the new carb dialed in. currently its at 14 degrees btdc, and starts like theres barely any advance in it. (unlike my mopar that has 12, and will kick back on the starter hot)
Michael
Mr_Roboto
08-09-2013, 03:02 PM
Vacuum gauge pulling the most HG is how I'd do it personally. Not saying it's right or the best by any means. If you've got stock weights and springs in your HEI unit I doubt it'd be a "bad" thing. Could also try the standard 12 degrees of advance at idle if you've got a pretty much stock dizzy.
The big thing about the "vacuum gauge" approach is going to be the peak amount of timing you get. If you have springs that aren't stiff enough and no travel limits you could end up with too much advance wide open or if you have a vacuum canister that's too aggressive you'd end up with pinging in the mid RPMs. If you have an adjustable timing light the WOT is easy to check the latter is probably going to be difficult without a distributor dyno to see the curve you're getting. The last thing is a bit too much advance can make hot starts a pain, but if you're not running locked timing I doubt you'd really run into that.
