View Full Version : Changing Stereo to Mono...
pitts64
08-06-2013, 06:21 PM
I want to run my two channel Panasonic 8 track into one 4 x 8 dash speaker...
Isn't there a way I can connect a resister in series with one of the channels so I can connect both right and left channels to the same speaker without backfeed?
Both the speaker and the tape player are 4 ohm...
Thank you....
alocker
08-07-2013, 04:07 AM
It's called bridging but I doubt you can do it safely with that 8 track. Your best bet is to get a couple 3.5's and a bracket from Autosound to mount them.
pitts64
08-07-2013, 06:41 PM
Thanks....
DEIVIONCRX
08-10-2013, 09:46 AM
Or if you do want to keep a single speaker they have Dual Voice coil speakers now. It has both left and right hookup's only one runs the woofer tho, one channel ends up being only tweeters.
http://www.ebay.com/itm/RetroMod-R-48N-120-watt-Dual-Voice-Coil-ULTRA-THIN-4x8-speaker-/300889407557
pitts64
08-10-2013, 12:30 PM
I was wondering how they did that with the dual voice coil, too bad you will loose all the mid range and low tones from the channel that just feeds the one tweeter...
