Gratefuldiver
08-05-2013, 11:54 AM
Couple noob questions about auto x for first time. They may be stupid questions so feel free to make fun of me lol
Tire air pressure. You just run what the tires call for. I run them a few lb under max pressure normal.
Fuel level. Does it matter as long as its not so low you stall the engine on a hard turn.
Shifting. Even though I have an auto I'm assuming I want to run through the gears. I can over power my tires pretty easy
Windows. Best to have all up except drivers?
Lastly do you guys prefer to use one foot or two with an auto.
Gratefuldiver
08-05-2013, 06:02 PM
So I post these questions in the wrong spot lol?
mpozzi
08-05-2013, 08:21 PM
Answering in the body of your text ...
Depending on the tire, I run between 30-35 psi and then check the sidewalls to make sure they're not rolling over too much. If the track surface is concrete, this can be a bit more abrasive than asphalt. Take one run with these pressures and then adjust either up or down as handling dictates.
It does matter and not every fuel system will tolerate a low level. My S197 Mustang could run with half a gallon in the tank as it had EFI but with a carburetor and mechanical pump, no way. I'd get fuel starvation on turns with even a quarter of a tank so usually ran almost full. Better weight balance, too.
I've run both manual and automatics and found that manually up shifting the auto is the fastest way through an autox. Start in low (first) and then bump up and back down as you need to. I like to manually shift the automatic as I've gotten up shifts and down shifts at the most inopportune times letting it think for itself.
Doesn't matter but if you can take passengers and do, make sure they keep all body parts inside the car during your runs. You might get a DNF or red flagged and lose that run if they don't.
If you adopt left foot braking, practice before you get to the event. If done properly, LFB can be faster than using the right foot for both. It takes a lot of practice to do this properly.
Good luck,
Mary Pozzi
Gratefuldiver
08-06-2013, 11:57 AM
Sounds good that's. My fronts call for 50lb and rears at 43lb 275/40/17 and 285/40/17.
