View Full Version : 1969 Camaro project--DSE parts, lots of work done already
nkopper
08-04-2013, 01:48 PM
Sadly, I am forced to sell my 1969 Camaro project. It started as a 94,000 mile 307/pwg car with a/c, pws and console as the only options. It has been stripped to a bare shell. The only rust was in the quarter panel/outer wheel housing area and very minor spots on the bottom of the front fenders. The rest of the car is straight and rust free original. About 18 months ago, I had V8TV install full quarter panels, DSE minitub kit and US-made outer wheel housings. They also gapped the deck lid and doors in addition to installing new door latches, rebuilding the door hinges and welding in the passenger front side cowl panel. Well over $7000 in parts and labor.
Last year, I purchased a DSE Quadralink kit with upgraded dual adjustable JRI shocks and antiroll bar. I have the upper link mounts about 75% installed, they just need to be final welded. I cut the trunk for the shock crossmember, but it needs to be final fitted and the panhard mount needs to be welded. I also had V8TV weld the axle brackets onto a full floater rear end housing with an aluminum Winters center section. It includes a full Coleman floater kit, brake brackets and axle seals. I do not have axles or differential yet, but the WMS to WMS length of the rear end is 58". Front subframe is original with power steering and manual drum brakes.
Other stuff: I started to create a smooth firewall based on pics from Bad Penny and have cut some of the humps out of the firewall and created a pattern for an overlay panel. I have tons of other parts including all original glass except the windshield that broke when removed, window tracks and hardware, dash pad (A/C car), trim, taillights, headlights, interior parts, marker lights, grill, rear seat, wiring harness, windshield wiper mechanism, hardware, steering column, pedals, 2 rear spoilers, repro front air dam and lots of other stuff boxed up in storage. Most is in good condition. Also have DSE subframe connectors NIB. I'll add pics to the Photobucket site as I pull parts out: http://s1222.photobucket.com/user/nkopper/library/?sort=3&page=1.
Parts I do not have: console, front seats, gauge panel, engine, transmission, master cylinder, hood, a/c box and some other original parts that were worn out or broken.
Located in Wentzville, Missouri. Not considering trades at this time. $12,500 obo. Thanks for looking. PM me if interested.
Nathan
nkopper
08-05-2013, 05:56 PM
Sold!!
