View Full Version : G body shocks in S10
Z06killinSBF
08-01-2013, 05:58 AM
Will G body shocks fit the front of a 2wd S10? They look identical and fit the height dimensions I need being lowered. I know the springs fit but need info on shocks before I pull the trigger. Thanks!
Slick68
08-01-2013, 08:47 AM
As far as I know, the chassis' and suspension is all very similar, so they should work.
Samckitt
08-01-2013, 08:51 AM
Spindles are the same, pretty sure upper & lower control arms are the same, springs are the same, so i would be shocks are the same.
Z06killinSBF
08-01-2013, 09:07 AM
Awesome, thanks guys.
Brwnelky
08-01-2013, 01:07 PM
Front suspension is the same minus the LCA bushings and track width from the wider g body frame. Most of the steering part numbers match up too, except the centerlink.
SRD art
08-01-2013, 03:50 PM
Our Moog catalog at work lists the LCA bushings as different numbers, as stated above other parts cross over. Anybody know what the difference is in LCA bushings? Do the LCAs themselves cross over?
rentedmule
08-02-2013, 05:11 AM
IIRC the bolt for the rear LCA bushing is a bit larger in the S-series stuff - I can't recall the exact size but one of the vendors here should know.
