toofun
07-31-2013, 01:57 PM
So I have a mechanical secondary Holley carb that has been working FLAWLESSLY on my car. It tended to leak fuel ever so slightly but nothing major. It would always start right up and idle right away happily at around 1000rpm. Blip the throttle and it would have no hesitation at all and very very responsive.
I noticed the other day a very strong gas smell in the garage. Pulled the car out and started it up. It ran very very rough and when I tried to get it to idle it would idle then chug down slowly until it would finally die (not right away but about 15 seconds later) When I shut the car off I could see fuel on top of the intake. So I cleaned all of it off removed the air cleaner and started the car.. NO LEAKS but it still would run rough and I had to hit the throttle to keep it running. When I hit the throttle it would be very very responsive with NO HESITATION at all. I tried adjusting the idle but all that did was make the engine idle HIGHER once I hit the throttle and then over 30 seconds later it would go from 1500 rpms to 1000 rpms and chug at 500 rpms.
Couple of notes.. the car runs an electric fuel pump and it reads steady at 8 lbs. It is deadheaded at the carb dual feed with a return line. Again this car ran flawlessly for about two months and 5000 miles with this setup. It just seems like all of a sudden this happened. I also checked all the vaccuum lines and plugs to be sure none came off. Any help would be greatly appreciated. Could it be the idle circuit? What should I check first? Not very carb savvy so any help is appreciated.
Thanks in advance
Mark
TOOFUN
Thanks in advance
Mark
TOOFUN
