View Full Version : New Calipers, rotors & lines = breeder valve leaking?
1967ls2
07-30-2013, 09:30 PM
Just installed some new calipers, pads, rotors, and lines on my 67 camaro. There seems to be a persistent leak coming from both bleeder valves. I put rubber nipple covers on the valves but they still leak. Any suggestions?
chevnut55
07-31-2013, 05:11 AM
Guessing you bought them at autozone or peep boyz ? I had a few bad ones from them , I had to rebuild or repair them after I bought them.
Did you try to install new bleaders? rubber nipples will not help, they are just dust covers.
Apogee
07-31-2013, 07:49 AM
Return/exchange the calipers if you can. The bleed screws seal against a tapered seat inside the caliper, so if either the bleeder screw or the caliper is corroded, pitted or otherwise damaged, you can get a leak. If it's the seal on the caliper body, nothing short of remachining that surface will fix it. Alternatively, you may just have calipers with the wrong bleeder screws, causing them to bottom out on their threads or something similar before making hard contact with the sealing surface.
Tobin
KORE3
Ron Sutton
07-31-2013, 09:34 AM
Sorry ... I'm in the wrong forum. I came in to to see what a "breeder valve" is?
Just kiddin ya. :lol:
1967ls2
07-31-2013, 08:19 PM
I purchased the calipers in a disc brake conversion kit which came with rotors, pads, calipers, bearings, dust caps, etc. The bleeders were pre installed. I just went to the auto parts store, picked up some speed bleeders and installed. Pumped the brakes a few times and didn't see any fluid seeping. Will check again tomorrow after work to see if it's leaking our not.
When I pulled the pre installed bleeders out I could see where the bottom of the bleeders were making contact with the caliper seat and it looked like the wear mark wasn't making full contact.
Thanks for the response!
