View Full Version : Quicktime Bell 6023-PB Ls3 Corvette Oil Pan (New) Hypertech Thermostat 160 & 180
Reactor
07-30-2013, 08:38 AM
800598006080061
I have a few parts from my LS swap that I need to get gone. The Quicktime bell will bolt a T56 Magnum to a
SBC or BBC and use the manual clutch linkage. Includes the TO brg collar that goes on the trans. I had to trim a small cutout
between the bolts on the flange to allow the rear drain plug on the oil pan clearance. You can see it on the picture at the 1 o'clock position.
400$ plus shipping. The pan is off the new crate engine. 100$ plus shipping. I have 2 new Hypertech thermostats for a LS1. I thought these
would work with the Vintage Air water pumps, but would not. 20$ plus shipping, each. one is 160 deg and the other is 180 deg.
I am in the Charlotte, NC area, and would be glad to allow local pickup or arrange a meeting near by. PM for any additional info.
**** Oil Pan is Sold****
**** Bellhousing Sold***
evostilo
07-30-2013, 10:13 AM
Is there any advantage to running a 160 t-stat over a 180.? I plan on street/cruise most of the time for my ls1, cam and some bolt ons.
jwcarguy
07-30-2013, 11:41 AM
pm sent
Reactor
07-30-2013, 04:39 PM
I needed the 160 for my fan setup that already had a temp switch that needed the 160 degree thermostat. You can read a lot of info on the LS1tech site about this issue. Some say it helps, and some say the LS engines are better at 200 degrees.
