View Full Version : Are 1/4" wheel spacers safe
tumper93
07-27-2013, 01:23 PM
I have done many searches to check whether or not this is a good idea with no real answer. My front wheel is flexing just enough to touch the tie rod end and 1/4" would cure the problem and give me 1/2" clearance between the two. I have also installed a g-link and minitubs in the rear and I will be widening the wheels on the inside to run a 335 tire which I may have to slightly adjust outwards to make perfect. Just to say NO I don't want to replace these wheels. So with that said will a billet wheel spacer work for this safely and should it be a custom hubcentric piece.
SSLance
07-27-2013, 01:26 PM
I'm running a 1/4" spacer with my track wheels and slicks, it's perfectly safe...with a caveat. You have to have lug studs long enough that the lug nut will still fully engage with the spacer in place.
Rod
07-27-2013, 03:22 PM
its safe as long as the wheel studs are long enough, if you dont have long studs that will be the failure point
Ron Sutton
07-27-2013, 04:25 PM
Agreed.
tumper93
07-27-2013, 05:41 PM
They are long studs so that won't be an issue. I just need to tweek the wheel placement to not have any problems front or rear. I was looking at the Baer spacers that are available and figured those are ones I could trust for being correct as opposed to the old ebay tricks. Any others out there anyone would suggest
Rod
07-27-2013, 07:40 PM
I use wilwood spacers
