View Full Version : New from Minnesota with camaro
lbluecamaro69
07-25-2013, 09:57 PM
hey guys sorry I can't get many pictures up but I'm working on a lemans blue 1969 camaro with my dad.. I'm open to suggestions and criticism! I got it a year ago as a painted rolling shell. first rebuilt the front end and painted the subframe with kbs anti rust paint. New bushings& ball joints and blasted and painted the control arms. New shocks all around and hotchkis 2" drop springs in front. other than the rear shocks moved inboard, the caltracs bars, and poly bushings the suspension is stock. the motor is a 400 small block bored 40 over which I honed out and freshened up with new gaskets. it pulled 456hp and 478 ft lbs on the dyno. trans is a th400 with a gear vendors overdrive. rear end is a mopar 8 3/4 with a 3.91:1 posi. car is mini tubbed and has subframe connectors welded on each side front tires are 195/60r15s bfGoodrich radials and rear are 275/60r15 nitto nt555r drag radials. going with stock interior other than a gauge pod and lokar shifter. exterior will also be stock. it has all new wiring and all new 4 wheel power disc brakes
Rod
07-25-2013, 10:03 PM
welcome
lbluecamaro69
07-25-2013, 10:06 PM
jfreakofkorn
07-26-2013, 03:44 AM
welcome to the board ....
