View Full Version : Help w/ GM A Body Viking Shock Install
john31s
07-23-2013, 02:24 PM
So I am wrapping up the rear suspension on my '70 LeMans and adding the Viking Shock which I got through UMI. Everything is going fine except the bottom connection needs a spacer to properly mount up to the shock mount on the axle. When I go and add the spacer it looks like its pushing the shock too far out. I am afraid the top end doesn't have enough room for flex to accomidate the spacer.
Any guidence/advice would be greatly appriciated.
Do I just need a smaller spacer? I'm still worried it will put too much strain on the top of the shock.
John
796207962179622
killer69
07-23-2013, 02:57 PM
That should be fine.
Typhoon1015
07-23-2013, 03:10 PM
where is your original shock mount bolt? It usually bolts on to the axle and has a built in spacer, and acts as a stud with a nut and washer to hold the shock on.
Typhoon1015
07-23-2013, 03:47 PM
something like this
http://www.opgi.com/chevelle/CH26743/
UMI Performance
07-24-2013, 04:11 AM
something like this
This is correct, this is what you need. Or the spacer above and a bolt will work just fine. NAPA and other Autopart stores carry these too, sometimes even in their "Help" sections. Hope that helps,
Ryan
john31s
07-24-2013, 04:40 AM
79644
This is how it looks like it will be if I use the spacer (red line), is that angle safe for the top mount, it doesn't look to have enough movement. Also it looks like if I use a spacer the lower mount won't bolt up flat up against the lower shock mount on the rear axle tube.
UMI Tech
07-24-2013, 05:23 AM
Hey John.
That angle is fine. Like Ryan mentioned, we used a stud from the Help! section at the local auto parts. Our previous shocks were Bilstein with the integral stud and have a smaller body diameter.
Any time we use a large body diameter shock in this application it's at a slight angle.
ramey
csouth
07-25-2013, 06:48 AM
My Varishocks are the same way. Like Ramey said, you will be fine.
Bryce
07-25-2013, 07:53 AM
Pinion angle would change the required spacer thickness.
protour_chevelle
07-27-2013, 04:41 AM
perfectly normal
Rod
07-27-2013, 11:33 AM
79644
why don't you just put a small shim on the upper mount on one side to create a top angle
