View Full Version : tach signal problem, set to 8 still not moving tach
chevnut55
07-22-2013, 07:11 AM
I had the programmer set the tach resolution to 8 in my 69 ls1 to use the factory tach but still it will not work at all, also tried a aftermarket tach and nothing.
any ideas what to do next?
rickpaw
07-24-2013, 09:37 AM
Try setting your after market tach to 4 cyl signal to see if the change was done at the ECU. Maybe the programmer forgot to make the change.
MalibuSSwagon
07-30-2013, 09:04 AM
You evidently need to do the tach signal pullup mod in order to get your tach working.
http://67-72chevytrucks.com/vboard/showthread.php?t=445975
chevnut55
07-31-2013, 08:04 AM
Probably but there is nothing on a tach set to 4 cyl either, the 1st programmer forgot to take out vats and t/c brake switch. problem is the current and only programmer around programed it 2 times and doesn't care if I have a tach . I need to either find a tach signal on the tach moduel or find a better programmer.
