View Full Version : Vintage Air wiring
GrabberGT
07-21-2013, 11:56 AM
Im wiring up my Vintage Air Gen IV and am wondering if anyone wired the white wires to a chassis ground or does it HAVE to go to the battery ground. I have a remote mount battery and chassis ground would make it soo much easier.
Chris, I have installed 3 VA systems so far and they are pretty specific about using the battery post as a ground for the white wires. The electronics on the GenIV systems are sensitive and need battery ground for some reason. I had problems with the blower speed controller when it was grounded to chassis. Use battery.
Evan Q.
XLexusTech
07-21-2013, 02:18 PM
you could consider running the bat Negitive up to the firewall and ground it to the Negitive there...
chevnut55
11-15-2013, 05:24 AM
I just had a problem with that. If you disconnect your battery like I do the system goes nuts looking for a ground even when off and the blower comes on until the batter is dead then the whole system has a fit.
They way over complicated the ac wiring.
parsonsj
11-15-2013, 05:52 AM
I've wired many VA Gen IV kits. Never once have I connected the main grounds to the battery. I also cut the power side of the harness up -- and wire it to the power block.
I think VA does that to avoid having to hold folks' hands that don't understand how properly ground a vehicle.
Having said that, if you have electrical or electronic glitches, and you call VA for support: guess what question they'll ask first? :)
Heleanor
12-16-2013, 02:48 PM
Find a place where you would like to ground it and use a meter to check for resistance. That is the only logical reason to connect to the battery directly. Maybe the systems react weird with negative resistance ???
