View Full Version : Broke my Art Morrison front sway bar link
Gandalf
07-20-2013, 03:57 PM
I'm in Syracuse NY and discovered today I broke the end link on my Art Morrison subframe on the autocross. The main bolt sheared off and the main/top part of the bolt disappeared. I suspect it may have broken at the track but come out on the freeway/street. I've been having trouble tuning the front suspension this weekend and this might explain why although I'm unsure when it took place. It does explain why my front shock settings were not producing the results I was expecting.
1 - Does anyone have an idea if these AM sway bar links come off another OEM setup that I can find at a parts store?
2 - I did manage to locate an Energy Suspension sway bar link kit that will work all except for the main bolt which uses a coarse thread and will not attach to the lower link (fine thread). The AM bolt is 3/8-24 and 4.5" long. I found a grade 5 bolt at Lowes but only 3" long. If anyone happens to know where I can locate such a bolt on a weekend - I'm all ears.
Any ideas appreciated.
Gregg
RobNoLimit
07-20-2013, 04:03 PM
go check with the guys at RideTech.
Bryce
07-20-2013, 04:08 PM
If you were in San Diego, I know of an awesome hardware store....
Gandalf
07-20-2013, 06:43 PM
Thanks Rob, I did exactly that today at the show but unfortunately nothing doing that would fit.
I looked around but couldn't find any of the other suspension guys usually at the shows. Different crowd.
At worst I have a lead on two separate, local fastener stores which will be open Monday. I would REALLY like to run tomorrow because the track is fun, we are getting tons and tons of runs plus I really need this no-pressure dial-in time before MotorState next week.
G
07-20-2013, 08:20 PM
My AM sub has two rod ends that screw into a double female tube. It has 3/8" bolts to bolt the heims into the sway bar and A arm. It sounds like yours is different. Is it like a stock camaro?
07-20-2013, 08:44 PM
79541
Gandalf
07-21-2013, 03:22 AM
Thanks Dave. Very similar but my bar attaches using a vertical (pin?) style, yes like the original GM bar. The bottom of mine mounts identical to yours using that 90deg mounted female Heim. The top half was easy to replace at the parts store with an Energy Suspension kit but the thread on the main fastener is coarse, unlike that lower female Heim.
The included bolt is also way too long so now I'm wondering if I just cut and thread it myself? Can I put a thread on that plated steel the bolt is made from?
79544
07-21-2013, 01:41 PM
Yes, you could cut & thread a bolt if you can't find a fine thread one. Hardware stores don't stock much in fine thread, but you might find one. Use a grade 8 bolt.
Bigblue73
07-23-2013, 05:50 AM
http://www.midwestcontrol.com/
Check this company out. They have just about everything a guy could ask for.
CraigMorrison
07-23-2013, 10:15 AM
If you can't get something there, please give us a call and we can ship something to your hotel.
CraigMorrison
07-23-2013, 10:41 AM
Please give us a call ASAP 800-929-7188 and ask for Dave. I just double checked and it is not an off the shelf end link. If we get the order taken care of early enough in the day, it can be next day aired to you. PLEASE CALL!
CraigMorrison
07-23-2013, 12:56 PM
Everything is sitting on Dave's desk waiting for your call.
Larry Callahan
07-23-2013, 01:16 PM
Gregg, your voicemail box is full
Gandalf
07-23-2013, 06:16 PM
Awesome guys!!! Thanks Craig - been on the road all day from Syracuse on the way to Motorstate via Niagra Falls today. Have had to stop in Erie for the night due to flash flood warnings. Will call Dave tomorrow AM thank you! You guys rock!
G
LUV2XLR8
07-24-2013, 03:19 AM
if you need a garage to work on it ... i live in erie.... PM me if u need tools.. welder..lift... ect
LUV2XLR8
08-13-2013, 10:42 AM
How did you do @ motorstate
