View Full Version : Brembo GT Brakes 355mm/14" Rotors, Calipers, Mounts, NEW! The MacDaddy of Brakes
oldguy
07-12-2013, 10:02 AM
A complete set of HUGE Brembo GT Brakes.
http://www.racetechnologies.com/page3-42/GTSystems
Includes:
2 front 355MM/14" Rotors, Drilled
2 Rear 355mm/14" Rotors, Drilled
2 Front 4 Piston Calipers
2 Rear 4 Piston Calipers
4 SS brake lines
1 set front pads (Brembo)
1 Set Rear Pads (Brembo)
4 Caliper Adapters
These Brembo brakes were used for mockup only. They have NEVER been used to stop the vehicle and all gold zinc coating on the rotors are intact and perfect. The calipers and hats are in black. The calipers are PERFECT as well. The hats have been modified by drilling, however you can buy new rotor hats for around 250 each that will fit your specific application.
This kit retails for around $3800 per axle or $7,200. A quick sale here for $5,500 for the complete set, includes hipping lower 48 states. Other areas extra.
PM me or call 954-282-1602
Dont miss this deal !
andrewb70
07-12-2013, 12:22 PM
It would be really helpful to know the application. What car do these fit?
oldguy
07-12-2013, 12:27 PM
Originally the brackets and hats were for a Ferrari Testarossa, however you can change the hats and they will fit anything. Brackets are easy as well to modify.
oldguy
07-17-2013, 07:29 AM
bump
