View Full Version : 1980 T/A w/455 driver
pandatime
07-10-2013, 07:12 AM
1980 trans am I've owned since '09. Had the current motor and trans with a different setup. Ive tond it down a bit. This is a capable weekend warrior built for mostly street time. Has little issues but nothing serious. No A/C.
*Exterior: Some rust on pass. door corner, drivers side A pillar, and edge of hood but otherwise good for a 30 yr old car. Good glass new w78900789017889978902789037890478905indshield. Cameo white with black graphics. Pass. door is beginning to sag. Stored outside. White turbo wheels 255-60-15. New hood hinges with springs.
*Interior: Black vinyl. Good shape. All panels there except drivers side kick. No package tray. Original radio no speakers. Blue headliner. Grant GT wheel. Dash is rough but have a spare w/ only a slight crack. Has no soundproofing except in floor. No rust inside. Have 2004 bmw SEDAN power sport seats to go with it. Has 4th gen front seat belts.
*Suspension: Stock type except Delalum LCA bushings and shocks-KYB front and Hotchkis rear. Power steering. Disc/drum power brakes.
*Drivetrain: 1973 455+0.060 bore to 469. 1972 400 heads. Unknown if ported etc. New valvesprings. Cam is streetable. Edelbrock p4b aluminum intake and custom jetted 750. Electric choke. Pertronix hei kit and coil. 8mm wires. New fuel pump and sending unit. Fuel line all recently replaced. Headers. 2.5 dual exhaust and flowmasters. Th350 trans rebuilt in '12 to withstand the 455. Vistapro 4 core radiator. Electric fan and shroud. New thermostat. New coolant temp sensor. Have dual carb edelbrock intake and edelbrock aircleaner too. Has edelbrock valve covers. Spare Holley 4160 600cfm carb also.
*$7000 obo for everything. Any offer will be considered. Have a 1 yr old and cant work on vehicle.
*850-358-23zero5
yodas little brother
07-10-2013, 01:39 PM
pm sent
pandatime
08-04-2013, 10:25 AM
Interior pic
80333
pandatime
08-04-2013, 10:27 AM
6000 gets it.
pandatime
11-28-2013, 09:38 AM
$4000 and has new sending unit for fuel level. Gray fourth gen seatbelts installed in front. No longer have the rear shocks but the dual quad setup and eeverything else still go with it.
