View Full Version : Alignment Where to get it done?
daveybtv
07-07-2013, 07:29 AM
Where do you guys go I upgraded to SC&C stage 2 and just mounted my new Rushforths and need to get the alignment done, But where do you go? will the machine scratch my new wheels?
Vicinity
07-07-2013, 08:09 AM
I had mine done by a local guy who does a lot of race cars, no machines, he did it all manually.
MonzaRacer
07-12-2013, 06:26 PM
As long as there is a small amount of space most rim clamp setups now will clamp on outside and if you need protection simply have then use duck tape and razor blade and make 3 or 4 layer "cushion" between wheel and clamp head.
OR go over to Hunter Engineering web site and get the newer model number machines as the newest model no longer clamp to wheels, they attach to tire. Then call around till you find shop that uses that set up.
If you were in Indiana near Bloomington I have set up may cars over years, including a ACR Neon back in late 90s. Owner and his wife wound up doing pretty good and only used one set of tires through whole year except for run off at end of year. Must have done something right, the nest year I had 27 ACR Neons to set up not just 1!!!!
Talking to tech doing it who actually understands performance and handling you will soon find one who you can trust.
Personally after using FMC/John Bean/Snap On , Launch and Hunter, I personally want a Hunter,,,even if its an older A111, over most of the newer other brands,,, just no impressed,,, not even happy with Beissbarth thats supposed to be no touch,,,never saw a car repeat.
