View Full Version : Mobil 1 Oil question for turbo engines
PT Sportwagon
07-03-2013, 05:54 PM
I have heard that when used in Turbo applications the full synthic Mobil 1 5w30 breaks down ( shears)quickly. Has anyone had any problems using Mobil 1 5w30. I have used Mobil 1 in my vehicles and want to in my new one.
Tim
Schwartz Performance
07-03-2013, 07:10 PM
What kind of car is it? Most synthetics will break down at around 300 degrees, but a daily driver won't ever get the oil that hot. High performance cars might, which would benefit from an oil cooler.
-Dale
PT Sportwagon
07-04-2013, 06:49 PM
Dale, This is in my 2013 Ford Focus ST 2.0 ecoboost turbo. My daily driver.
Tim
AMSOILGUY
07-04-2013, 09:48 PM
Tim
Tim,
I did a little looking and the oil needed for your car needs to meet this spec: Ford specification WSS-M2C946-A. I do not know if the Mobil meets that or not. I do know that AMSOIL meets this spec in our 5w-30. Here is a link to where I got this information from. (http://www.amsoil.com/mygarage/vehiclelookuppage.aspx?url2=2013+FORD+FOCUS+9/?=1856266) Hope this helps.
Jacob
CarlC
07-05-2013, 06:04 AM
I agree with Dale. Ford sets a 284*F maximum for synthetic oil temperatures.
MonzaRacer
12-18-2013, 05:49 PM
Synthetics break down at 300deg? huh, strange, everything I have seen synthetics operate at higher temps than conventional.
284deg? heck doesnt leave much margin for conventional oil then, that must be breaking down at a much lower temp.
As for me I would run a 10w30 or 15w40/15w50 synthetic in a turbo engine and get some sort of accusump set up where it feeds oil after shut down AND use a turbo timer.
I do have couple of local Honda guys running Shell rotella 5W40 with no ill will BUT we also used dodge durango electric heater assist pumps and post oiling and water cooled GT style oil/water cooled turbos.
ALSO I have several guys running evans cooling NPG+ coolant with zero heat or oiling issues.
rrelco
12-18-2013, 06:40 PM
check out Schaeffers oil or Amsoil, i have been using Amsoil but switched to Schaeffers due to the cost and they have a micro molly protection in all there oil
option
02-27-2014, 10:56 AM
I have always run Mobil 1 5w30 syn in all of my boosted vehicles... my current daily driver is a fairly modified 2010 Cobalt SS/TC. At 24psi I burn absolutely nothing and that's with the factory twin scroll K04. You'd be perfectly fine running that oil my friend. Actually now that I think about it the only turbo manufacturer I've ever heard guys complain about oil consumption issues is Precision.
Rod
02-27-2014, 11:06 AM
what does the manufacture recommend?
LS1-IROC
02-27-2014, 02:36 PM
I was running M1 on my boosted LS1 but after reading all the horror stories using M1 on higher output boosted motors I have switched to VR1. I still use M1 in my DD stock motors though.
shmoov69
02-27-2014, 07:38 PM
I really like the feel of the VR1. It is still thick and "oily", even after a weekend of boosted activities at the Midwest Muscle Car Challenge. With my old turbos, which were too small, the egt's were about 1500° at the end of EVERY front stretch lap at Putnam Park.... And I put about 35-40 of them on there!! Then the auto-x the next day where the water temps were still in the 230-235° range after a few runs. I gotta say that I don't think the M1 would hold up after that kind of abuse. When I used it in our old GN, the pressure dropped significantly after it got hot, so I didn't want to risk it under the abuse of the Camaro!
