Rileys68Camaro
08-23-2005, 09:11 PM
Okay, I'm just really pissed right now. The guys that worked on my car were total hacks, but it keeps getting worse.
What I've got, is I decide to paint the whole car monochrome type. Firewall, inner fenders, dash, everything body color.
Well, my master cylinder leaked, and they hacked the Vintage Air Surefit install, so I've got oval, jagged edged holes, vent tubes right over my headers/starter etc. Several extra holes need filled. They'd drill a hole, 3/8" say, and then oops, wrong spot, but not bother to weld it up.
I've also got several 3/8" holes in the floor pan that look like oopss'.
So, I want to put a DSE fill plate in, weld up all the uneeded holes, run either a bulkhead or the hoses through the original blower motor hole. Nothing crazy extream, I'll still have the wire harness, ignition, coil, etc visible.
So, what should I expect to spend to have my firewall cleaned up, and painted with a few misc holes filled? I'd probably have my inner fenders done at the same time and maybe the dash. Shop rate is about $65/hr here.
The car is still a body with a motor, I can pull the fenders and motor/trans as I need to anyway to fix those mounting problems.
All I'd need is the welding and prep/paint done. In flat black.
I'm so sick of this stuff! Having to take it back apart, fix it and put it back together.
