View Full Version : UMI New Product- Pro-Touring Rear Sway Bar for the 1964-1972 GM A-Body
UMI Performance
07-01-2013, 10:46 AM
Pro-Tour style rear sway bar for 1964-1972 GM A-Body
3 position adjustable, tubular
P/N 4047-xxx
Introductory Offer- $319.99/kit for the first 10 buyers!
(Regularly $399.99)
UMI Performance, Inc. is pleased to announce the availability of our new Pro-Tour style rear sway bar for 1964-1972 GM A-Body applications. This 1” dia lightweight hollow sway bar is axle tube mounted using our tried and true CNC machined serrated tooth mounting clamps and heavy duty u-bolts. Strong double shear mounts and four 3/8” fasteners attach the race quality rod ends to the chassis. It offers less rear suspension bind as it no longer mounts to the rear trailing arms. Three position adjustability provides soft/medium/firm tuning options to allow for a perfect handling balance. The UMI manufactured hex adjusters ensure a perfect fit and provide preload capability when used as a light drag bar. The P/N 4047 Pro-Tour bar has been designed to accommodate 10-bolt, 12-bolt, Ford 9”, Moser M9, Strange S60 and others while still offering great ground clearance and a clean look (available for 2.75”, 3.00” and 3.25” rear axle tubes). These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA – USA.
Website Link Here
(http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=1_27&products_id=746)
https://static1.pt-content.com/images/pt/2013/07/4047a_LRG-1.jpg
https://static1.pt-content.com/images/pt/2013/07/4047ab_LRG-1.jpg
