View Full Version : Did I kill my rear end?
john31s
07-01-2013, 04:23 AM
So I may have ruined a rear end this past weekend. I was replacing the rear upper control arms and the bushings on top of the pumpkin and ran into an issue. I got the arm off and the bushing out pretty easily, but was left with the outer casing of the rubber bushing left in the hole. My plan was to fold the material into the center and driver the sleeve out. This did not work out so well as I was left with a smaller ring left inside the casting. To get it out I went in with a carbide cutting bit on a dremile to cut through the ring and give me a gap to relieve pressure and slide the last piece out. That was easy enough and I got it out. In doing so I put a 1/32-1/16 inch deep grove inside the casting (see picture). Being cast iron there is no way to repair it and I’m afraid driving the new bearing in will cause it to crack. Even if I get it in I assume it will fail eventually. So my question is did I ruin the rear?
rohrt
07-01-2013, 08:34 AM
If your afraid of cracking it by I assume hammer pounding in a new one, I would recommend gettting the Autozone balljoint press tool through their free rental. Then press the bushing in.
You don't mention what the car will be used for or what exstreams it might see. I think for the most part it would be fine.
john31s
07-01-2013, 09:54 AM
Fairly spirited street driving with the occasional track use. Most likely 5-10% track time and of that the majority would be drag racing with the occasional autoX or track day.
07-01-2013, 12:23 PM
It should be OK.
