View Full Version : The LSX Forum
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Precision Race Components – SEE Why We Build Superior Cylinder Heads!
  2. What parts did you use for your 1st gen f body ls swap? and would you use them again?
  3. More power from my LS1, how to?
  4. GMPP Controller kit
  5. LS Camaro 1/4 mile times
  6. Front Accessory Drive ls3 69 camaro
  7. Hiding coil packs, LS2 1981 Trans Am project X-Clean
  8. ls1 carb intake
  9. Ls7 questions.. too good to be true?
  10. Ls2 swap?
  11. identify ls afr heads
  12. where to bolt chain hoist to LSA
  13. Speartech Harness in a 69 Camaro
  14. Pulley and bracket question with Daily dry sump system and remote water pump
  15. Am I better off ordering a crate based motor or having one custom built
  16. Not Enough Clearance Between Champ Pans Oil Filter Adapter and Edelbrock Headers???
  17. LS ignition system - Is it inductive or CDI based
  18. Seems like a pretty goof deal on an LS3.. ready to go...
  19. Feedback on Jegs Oil pan.
  20. Please read, need help, crappy running LQ4 in 03 Silverado.
  21. Acc drive with LS7 and DSE sub??
  22. Corvette Filter / regulator location suggestions 69 camaro
  23. CTS V front acc drive
  24. LS build ideas need some help from those who've done it
  25. c6 corvette oil pan on 68 camaro
  26. LS Dyno Tuning (Which oil)
  27. Tell me what these spark plugs mean.....
  28. LS1 carb cam - can I run this cam, should I run this cam
  29. ls4
  30. LS1 Accessory bracket bolt sizes
  31. ats road race pan
  32. Please Help with Under Dash Mounting Ideas for ECM
  33. ID this throttle body for me?
  34. Ls3 Engine builder?
  35. Advice on cam choice
  36. CORVETTE LS3 PAN in Camaro Nova Subframe
  37. Need the Advice from the Experts...LS1 Break in...Synthetic / Mineral Oil
  38. 68 Camaro LS6 fit problems!
  39. quick question on 04 gto engine/trans
  40. LS1 fuel line to rail,firewall or frame to drivers side?
  41. 6.0 chevy van engine?
  42. Budget LS3 'Connect & Cruise' mount advice
  43. Questions for anyone running a 5th Gen fuel module.
  44. Engine Management
  45. Anyone Running LS or OBD II MUST SEE THIS!!!
  46. New Engine Very low on power
  47. LS known mounting/header/crossmember for Camaro
  48. Recommendation on a LS1 stroker kit.
  49. value of LS7 with 5000 mikes.
  50. LS3 windage tray question
  51. Break-in oil
  52. ls3 swap 65 Chevelle
  53. 67-69 Camaro gas tank or other tank in a 69 nova?
  54. Wanted: Truck LQ4 intake
  55. steering
  56. Dingo Sliders for LS mount in 69 camaro
  57. ls monte carlo
  58. LS Conversion headers for first gen F-Bodys (new header being developed)
  59. Aftermarket Launch Controller
  60. Blue Print Engine LS3 427
  61. Fast 92mm
  62. 1968-73 Nova / LS3 Accessory drive
  63. LS2 and Corvette Pedal won't communicate
  64. C5 ls accessory drive with DSE steering rack and Hydratech hydroboost
  65. GTO LS2 into '69 Camaro question
  66. LS engine install book advice
  67. LS1 Sensor Question (what is it)
  68. Ricks tank with Vaporwox controler
  69. Lets see the carbed ls conversions
  70. Confirmed! Swap mounts and oil pan clearance
  71. Just bought a 68 Camaro
  72. Which is better? Short deck or tall Deck block
  73. I need Tuning Help. Somebody has to know...
  74. Harness question
  75. LS2 in 72 Chevelle Questions [URGENT]
  76. need some comp cam help from the cam gurus
  77. Fuel Line from the Tank to the Fuel Rail
  78. Edelbrock Coil Covers - Would they fit on a LS3 6.2?
  79. bigger injectors, do I need a tune?!
  80. carbed ls coil mount
  81. Emissions Question
  82. spal fan sensor
  83. Carb intake trade?
  84. LS swap question?
  85. Any chance these headers would fit---first gen
  86. Twist machine adjustable shifter
  87. is there a list?
  88. Question on tranny out of 02 C5.
  89. Anyone in need of some custom grind Cam shafts?
  90. LS3 480 HP... T56 Magnum 3200 # car
  91. Has any one used this package?
  92. 67 ls swap radiator hoses part # needed and MAF
  93. carb'd LSx intake question
  94. Where to get an LS-3
  95. Engine Seized - Now What???
  96. LS Conversion Parts Problems
  97. LS7 & DSE Subframe - what wet sump to use ?
  98. LS3 in my 71 Camaro motor mount question
  99. Holley Hi-Ram intake on camaro
  100. Delphi ECU mounting ideas
  101. LS3 misfire ,breaking up, from 2500 rpm to 3800 rpm
  102. Position Available for Full-Time Salesperson at Texas Speed & Performance
  103. 2005 Silverado donor truck for my 68 camaro questions?
  104. vaporworx tank no pressure
  105. AC Compresser notch panel
  106. Recommended radiator for ls3/up to 600hp
  107. What gauges work for 5.3 swap?!
  108. +- 7000$ - crate LS3 or build engine...must pass some emission test...goal 450whp
  109. LXS454 - Codes -P0068, P0101, P1101. Wiring, Tune or Sensors
  110. Anyone looking for a MAST oil pan?
  111. ls1 swap open headers smoke **help**
  112. Texas Speed Contact
  113. Connect & Cruise accessories question...
  114. What Lifters should I upgrade to?
  115. few questions ls1 into an 88 monte carlo ss
  116. Can anyone recommend the BRP LS conversion kit for a 69 camaro?
  117. Anyone have a CTS-V oil pickup tube laying around? PN 12621299
  118. Would a defective 411 PCM throw a code?
  119. LS3 fuel line routing question on a 69 camaro...
  120. Olds 455 or low mileage LS1? opinions
  121. I know the question has been asked in the past but Camaro ECM mount under dash pics?
  122. Proper power circuits for ECM?
  123. 660 RWHP N/A H/C/I pump gas LS7 Monte Carlo SS update, now 680 RWHP!
  124. Ideal motor mount position/type lsx swap?
  125. th400 to 5.3
  126. What oil pan to use for LS-1 into 1969 Firebird w/ original sub frame ?
  127. Mast Motorsports 427 v. Katech?
  128. Driveline angle of LS installed in a 69 Camaro
  129. Wich way do I go?
  130. oil pan options
  131. Big LS power inside!!
  132. Is it worth it or not?
  133. Fuel tank suggestions
  134. 67 chevelle with 2012 ls and 6 speed auto swap
  135. Ls3's. Hot or Not?
  136. Lq4 with 4l80e question
  137. Need help: LS swap options
  138. Need o2 help
  139. Questions Before 1st time Fire on LS
  140. Question about finding a vendor
  141. ls swap with stock f-body oil pan?
  142. LSx Under Drive Pulley....Benefits out weigh the risk?
  143. Is this an LS3 or an L92 truck motor?
  144. Ls3 480 HP crate
  145. 1966 Malibu LSX376/T56 PT attempt...
  146. timing cover front cover 2009 5.3
  147. Air Intake - Alternative Routing on 1970 Chevelle?
  148. Corvette alternator connection?
  149. Bellhousing... did i order the right one
  150. 1964 Buick Skylark has 30k on its original 300 v8.... but i have a 5.3l w/1000 mi
  151. Crankshaft Pulley (Before I do Something Stupid)
  152. HP Tuners Data.....anybody a whiz at troubleshooting?
  153. Looking for a fabricator to make me a custom intake ls7 for kenne bell
  154. GM controller outputs
  155. L92 swap into 69 camaro
  156. LS2 custom fuel rail covers ?
  157. Parts needed for hydraulic clutch setup 1968 Camaro LS3
  158. How to get an LSX started for the first time?
  159. What is this thing on the negative battery cable?
  160. What crossmembers and driveshaft work for an ls swap in a gen 1 camaro?
  161. GTO tank into 1st gen F-body
  162. Lookinmg for a Magnacharger for LS1
  163. MAF placement?
  164. Deceleration fuel enrichment
  165. LS3 T-Stat housing ?
  166. LS376/525 break in
  167. LS1, whats wrong with my engine? See pictures
  168. Fuel tank question
  169. Th400 swappers use this!
  170. Can you truely " Plug and Play"?
  171. LS2 swap - scan data output issue
  172. need a ls 6speed dropout for a 2007 canyon p/u
  173. LS2/LS3 -6 speed install in a G Body- Need Serpentine belt install info
  174. AGR power steering box
  175. Issues with lsx swap combo.
  176. LS1 MAF Selection
  177. LS conversion company
  178. How would you build a LSX376 B-15
  179. 1986 El Camino G Body LS Swap Stainless Headers swap- need info
  180. 72 chevelle ls swap
  181. LS7 / 9 Dry Supm Oil Pan by Speedtech/ ATS is BACK
  182. Value of an LS1 longblock
  183. intake y-pipe where to buy
  184. LS3, 430hp upgrade?
  185. LS1 budget swap parts???
  186. Cam Selection 2004 LS1
  187. Wet sump LS7 into a 69 - which conversion mounts?
  188. eBay LS1 gas tank for 68 Camaro??
  189. Universal weld in motor mounts?
  190. brackets to move T56 shifter to stock location on 68 camaro???
  191. Best way to get hand on a LS7 Engine??
  192. Builders using LS9 supercharger
  193. Hooker 1st-gen F-body/3rd-gen Nova Trick or Treat tease
  194. Danny Popp 72
  195. Going to take the plunge and convert to FI
  196. 5.3 Combo help....
  197. VVT accessory drives...
  198. lt1 swap Datsun
  199. does Dirty Dingo DD brackets, hooker headers and holley pan work together???
  200. New LS3 crate Engine - Idles HIGH
  201. GMPP LS3 harness- looking for CEL wire
  202. Best fitting oil pan for 5.3 in a 67 Chevelle
  203. Nice combo for LS3s with drivablity and broad power band
  204. LT1 to 1967 camaro
  205. GM Performance LS3 or Builder?
  206. is lokar the only LS throttle cable option?
  207. need some help please
  208. lsx salvage car pull
  209. 68-72 gm a body headers?
  210. LS6 Motor w/460L Auto trans Help!!!!
  211. LS help
  212. LS Swap and ECU mounting location?
  213. L92 with t56?
  214. Blueprint LS 427
  215. New Holley 302-2 oil pan now available
  216. Best ls adapter plates for 2 gen camaro
  217. The "What If It Was Yours..." LQ4 engine thread...
  218. ls1 oil pan on l92?
  219. LS swap shop in sf bay area
  220. L92 fuel injector plugs
  221. 6.0L in a 67 woe's
  222. 2011 L96 silverado 6.0 engine spec question!
  223. Lsx swap manual or automatic?!
  224. Which Motor would you use?
  225. LS3/525 F.I. Idle rpm ?
  226. vortec 5,3 to 1967 camaro
  227. Gen 4 l92 standalone wiring harness diagram?
  228. 72 nova ls swap parts with ride tech parts
  229. fuel tank mods for in take pump
  230. Mike Norris EFI Calibration Work Avail Feb 11 & 12, 2014 in SoCal
  231. DSE fuel injection tank vs Aeromotive Phantom w/ stock tank
  232. ASA Cam?
  233. What LS ignition coils should I buy?
  234. Holley LS oil pan on a first gen f-body
  235. LS engine decision. Need help quick!
  236. What exactly is needed to make a ls actually turn and run in a classic muscle car
  237. Need help on decision on what motor on budget of $2500
  238. custom motor mounts
  239. Holley HP EFI vs. GM Computer
  240. Opinion on headers for my lowered 69 Camaro w/ LS motor
  241. Mike w/ New Era Performance In Las Vegas for Tuning Jan 22-26
  242. Cylinder head issues Tahoe 5.3 -02
  243. FAST EZ EFI 2.0 on an LS????
  244. Jegs LSX 454 Build?
  245. Anyone running the LS376/525 ?
  246. Norris Motorsports Mail Order, E-mail & Remote Calibration Now Available
  247. ls 5.7 engine
  248. HELP Need help with wiring on an ls swap
  249. LS Swap headers
  250. Feedback on Mast Motorsports Black Label LS7?
