View Full Version : The LSX Forum
Pages :
1
2
3
4
5
6]
7
8
9
10
11
12
13
- need swap help ls1 in 68 camaro ?
- Single bolt cam...Bolt part number???
- what headers, mounts, crossmember did you use?
- L92 vs LS3, L92 controller?
- mast or retrolsx oil pans
- ls pans milodon vs champ
- LS Air Intake Idea?
- GM ECM and harness, Speartech or street and performance
- Taking the LS3 Plunge
- Tech II Scanner
- Intake manifold question LS1
- engine swap choice and questions
- Another 'Should I buy an LS7' thread
- 2011 Mustang GT Motor.....
- lokar pedal
- harness conversions
- Water pump spacers for L92 with VVT
- LSx motor mounts, back of motor location VS normal small block chevy?
- LS2 GTO accessories - Radiator Q's
- wil corvette front drive asc work on a first gen ls swap
- T56 swap master cylinder questions
- Please explain this LS motor mount drawing
- any one using spectra GM32 fuel tank in 1st gen camaro
- Want to confirm how to tune a self-tuning efi system lol
- Road race oil pan from stock LS pan. DIY
- LS1 Build Help. Trying to get 500HP
- lsx cooling
- L92 PCM help...... which harness/controller?
- engine mount help
- Ls2/ 4l70e
- LS1 accessory offsets
- Oil Pan Baffles
- any 1st gen guys running autokraft pan
- Water pump question
- Harmonic Balancer???
- Do LS3's need an oil cooler?
- Why the hell are LS valve covers so expensive???????
- Stuck on engine direction
- Your best MPG with your LS motor
- Street and Performance Motor Plates...What motor mounts???
- DBW Pedal Mounting option
- Help with LQ4/LQ9 pricing questions and best setups to buy
- LS3 Flywheel Dowel?
- ls mount
- TransDapt LS Series Mounts and pictures
- LS3 Engine covers?
- Current Performance wiring harness?
- any ls guys running sumped tanks, please post set ups
- LS Valve Covers
- Cam position sensor question
- Aftermarket fuel rails
- C5 Vette Alt & PS on Trailblazer SS LS2?
- LS7 injectors & throttle body
- T56 shifter location. Do I need to move forward?
- ordering my ls 1st gen f-body swap parts this week,suggestions please ?
- Aftermarket Harness - Oil Level Sensor - Oil Pan
- My LS3 crate has water pump hose on wrong side..Change?
- LQ9 into 69 camaro
- 58x reluctor - there's got to be an easier way.
- Corvette fuel filter question.
- Would you call this a mild, decent size, or large cam.....
- LSx front pulley system??
- 4.8 Swap?
- MIL Wire Question
- Which injectors do I need for my L92?
- another ls pan question
- LS3 vs L92 heads (valves)
- Newbie LSx questions
- Recommendations for intake / throttle body porting?
- L92/6L90e performance mods in 67 Camaro
- Fuel rails for 6.0 with L76 intake
- I need to get some stock LS3 injectors!
- Alternator Bracket for LS1
- LQ9 w/LS3 Heads - What controller & harness to use?
- Billet valve covers for LS3/L92. What do I need on them?
- Stock GM balancer or aftermarket?
- Speartech vs GM ECU
- MAT Sensor
- Do I need mass air sensor?
- Help me choose a cam for a LS3 cause I have no clue!!
- Connceting fuel lines to the LS quick connecting fuel rail connection, how?
- Someone pls help!
- Is there a need to switch from a single bolt cam to a 3 bolt one?
- LQ4 Possability's??
- AC Bracket for a L92 in a 67 Camaro
- LY6 to go 24x & Cable or keep 58x reluctor and DBW?
- Cruise control on a reworked LS2 harness
- Making your factory gauges work with the LS engines!
- Oil pickup tube girdle: gauging intereste before I have them made
- 5.3l Swap Advice
- L92 not fitting in frame any help?
- LS that revs to 7500 RPM
- Oil Cooler/Tranny cooler for a L92/6l90e swap into a 67 Camaro
- Headder to ps hose clearance. Is this too lttle?
- preparing my wagon for EFI LS swap, What to do???
- holley ls3 and l92 intake
- LSx Engine Build & Install Help Needed
- A-body LSX Swap guys in here
- Is an LSx engine swap worth the wiring hassle?
- LY6 with LS2 throttle body and E38 ECM with VVT ??
- 2nd Gen LSX Trans Am with Functional Shaker
- Acc drive in a 67 Camaro
- fuel rails for L76 intake?
- Anyone done an E-Rod? Need some info on the charcoal cannister.
- How much ground clearance to the aluminum pan on your LS swap?
- LS engine conversion for my camaro
- LS3 Wiring Diagram
- 68-72 A-body LSX swap guys in here
- Are LS7's worth the bucks ?
- 2001 trans am, need some help
- i need 68 camaro 6 cyl Accelerator Pedal Assembly please help
- JCG/Vaporworx Gas Tank
- Oil Pan Gasket
- LS3 pistons, flat, dished, valve reliefs?
- engine swap
- 5.3 shorty headers worth it?
- does anyone know main bolts length and thread?
- LSx conversion owners. In hindsight what would you have done differently
- LSA outboard engines
- Hope you can all help me ls oil pan ?
- Fuel tank vent problems
- L92 in 68 camaro fuel pump?
- I'm taking the LS plunge!
- New Texas Speed & Performance Engine Machining Center!
- LS7 / Z06 Oiling Issues
- Which gauges
- T56 Clutch Master Q - Again lol
- Is this LS2 timing chain too loose?
- What LSx headers to use for a '91-'96 B-Body (Impala SS)?
- Removing original ls1 Intake fuel line fitting...need some help!
- Question about idle speed and gear selection with LS2 4L70
- LS engine harness locaiton through firewall?
- Hood clearance
- Sheetmetal intake measured performance
- SSTB LS2 into 67 Camaro
- Need help fast LS2 in a Chevelle
- Road trip! Picking up my LS2/4L70E tomorrow!
- noise in engine
- starter hangs up
- What would you do?
- 3 valve 4.6 into a 67 fastback
- Prodigy Power LS 6.2L, 11.80 / 116MPH CR in 3650LB Pro Touring Car!
- L92 flywheel recomendation?
- 1970 Mustang LS3
- '06 5.3
- LS6 into a 74 c10
- LSX Blower Setup
- Something stupid I did (LS2)
- headers before or after install
- Aftermarket coil brackets?
- Need help with LS3 Connections
- Floor-Mounted DBW A-Pedal?
- Oil Pan needed for LS3
- best spark plugs?
- LS3 Fuse Box Terminations
- 69 Camaro ls1 radiator hoses?
- Ls1 oil sending units?
- 5.3 LM7 rebuild - is it worth it?
- Coils.....where'd ya put them.
- Need transmission cross member for LS2/4l70e in my 69 Camaro
- 1st gen F body Hood clearance issue, carb'd L92
- 1st gen f body, lsx swap, BRP mount and hooker swap headers a no go
- harness hole first gen
- Vented Fuel Cap
- LS front accessory serpentine setup question
- Looking at this cam for my LQ9. Opinions?
- 5.3L cam recommndation
- Who has installed a LS engine in a '68-'72 GM A body?
- LS dyno
- Will this work?
- LS1 Technical assembly info?
- LS1 PCM Choices - Help please
- lsx header info---please post your setup
- Anyone Swapped a LSX into a 73-77 GM A Body Car Such As A Cutlass, Regal or Malibu???
- My very first LS1
- LS1/T56 1st gen Camaro Question
- L92 with LS3 intake vacuum quesion
- What are the simplest ( LS ) motor mounts for 1969 camaro? and where should i buy the
- How much was your cold air intake?
- Does anybody make a swapkit to put a LSx/6L80e(or 6L90e) combo into 77-96 GM B-Body??
- ? On LS computer mounting under the fender on the firewall?
- LS3 Motor w/ Billet Speciality Tru Trac System Problem
- Ls3 /brake booster size
- LS3 MAS Problems
- Vent systems that you KNOW work
- Low mount A/C for 1st gen Camaro with LS Engine
- LS1 PCM Mounting Pics Needed
- stock ls2 idle number?
- Pulley Direction and RPM
- What windage tray?
- new site sponsor "JJs automotive"
- Which LS???
- Clearance issues: How much is enough, Stainless Works headers & ATS 670 Gearbox
- Help with identification on new vehicle
- Needing help with lsx power steering hoses to factory box
- Crazy wild cylinder head idea
- Oil bypass cover
- 6.0 LS Question
- Can the driverside header be put in aftre the engine?
- Trade LS2 controller for GM LS376/480 controller ECM PN 19258268
- Mass Airflow Part Number
- Question 6.0 LQ4
- 5.3L G-body Cutlass
- LS6 T56 into 66 Chevelle... Help
- Budget LS engine questions, 5.3 or 6.0?
- 6.0 LS Newbie question
- About to take LS1 plung..need advice
- What mounts have you match with Dynatech headers (715-21410) on your 1st gen F body?
- spun bolts in aluminum
- 68 camaro - ls motor, 4l80e trans- what mounts fit?
- Question: LM7?
- Lq4 supercharged????
- Free Crate and Cradle W/ Any Engine Purchase @ Texas Speed!
- LS engine with best horsepower to gas mileage ratio?
- LSX "Classic" intake
- I want to build a cold air intake
- LS1 vs LS2 intake - fuel rail
- Used LS engines
- Taking the jump ( I think)
- Plug for LS1 cam sensor hole in block?
- Intake Tube Help Request
- loud knocking noise
- How are you connecting to the quick connect fuel fitting on the intake?
- ls headers for art morrison subframe
- Oil coolers?? Need one?
- Z06 Cam in 5.3L
- LS 2 install in a 69 Firebird
- coolant temp sensor
- Need g-body LSX Frame no
- Need decent plug wires!
- 5.3 engines
- ls7 stock injector flywheel hp
- Ls Choices
- Engine Builder
- Ls1 to corvette transaxle
- Engine Builder In Ga
- Texas Speed has Moved! NEW PHONE NUMBER!!!
- what ecm are you using when doing a ls swap
- PCM location
- LS3 Stock oil pan--good enough for Track Days & Auto Cross?
- Accessory Drives - Anyone using the March Performance Pro Track setup
- Any issues using non-LS radiator for LS2 swap
- ls3 stroker need camshaft advice?
- Which stock car LS2 throttle body?
- LS1 Power steering hose to 1st Gen F body info needed
- What wire connects to the starter solenoid?
- ls3 416 stroker Head gasket help!!
- FREE HEADERS - LSx into C10
- Drive by wire - intermittent operation??
- Mating 6.2 to 4l80
