View Full Version : The LSX Forum
Pages :
1
2
3
4
5]
6
7
8
9
10
11
12
13
- GMPP intake or edelbrock performer rpm?
- DSE LSx engine mounts
- L92 from 08 Escalade accessories in 67 Camaro
- ls stroker kits
- Bay Area source for LS engines
- Advice on cooling fans needed.
- Corvette DBW pedal 06 - newer
- Trail Blazer LS2 accesory question in 69 camaro
- LS1 Swap Wiring Harness
- L92 Cam
- LS carb ignition controller question
- NewB to LS engines, I"m picking up a LS7, Advise?
- ls2 in a 68 camaro 1/4 mile
- L92 heads on a 5.3?
- Baffle in modified LS1 oil pan????
- Headers for L92 in 67 Camaro
- Anyone have a picture of Kooks LSx mounts?
- Are LS1 engines a dying breed
- 5.3 options
- Prodigy / Wegner Supercharged 415CI Dyno Run
- ECU WOT Closed Loop Capable?
- LS1 with C5 oil pan in 68 Firebird?
- I have questions about wiring this sucker up.
- LS2 Fuel Pump
- Oil Pan
- Nova LSX swap kit info needed. where to look? who to buy from?
- LSX Block Decking?
- almost time to start, please help!
- New help figuring out something on LS1
- Should I swap the 302DZ for LSX376??
- BRP motor mounts and Stainless works headers
- Do I use windage tray with Champ pan
- lt1 to LS1 transmission
- LS turbo motor - allumminum vs. iron
- Drive Shaft for LS1 swap plus other ????
- How long is too long to be in the crate?
- Why do I run out of gas at 12 gallons
- Thinking about taking the leap to a 6.0L LQ engine
- LQ9 Oil Pump Thread Stripped?!
- Ls1 conversion
- 100 horsepower gain cam swap????
- LSX376 intake?
- lsx in 1970 challenger
- LSX weight
- LQ4/9 vs. LY6
- Where to buy LS3 intake manifold bolts??
- Damn You LSX Guys...
- Eldebrock motor mount question
- LS2 Vats ?
- Drive by wire gas pedal
- Trying to pick the perfect engine.69 Camaro
- Accessories? - Which factory setup works?
- 4L60e experts chime in please
- More "live and learn" LS moments...
- RetroLSX oil pan
- LS1 Camaro Power Steering Pump fittings.
- Variable Valve Timing - to keep or not???
- What gas pedal??
- LS engine drop out resources
- problems with my motor running right
- DBW throttle quits after flooring it
- 98 LS1 + T56 swap in my 79 Monte. Wiring harness? Which one?
- 6.0 power?
- GM A Body Swap ????'s
- Which intake gasket to use for L92 with FAST 102 intake
- Mast Motorsports Carb Style Intake Throttle Body Adapter
- New to pro-touring and to LS motors
- Will this oil pan fit
- LS1 Swap Shop near Savannah
- fuel line to fuel rail connection
- Anyone using Alum GMPP CT525 crate engine?
- CTS-V pan into a Second Gen 'Bird?
- Which 02 sensors have the longest wire?
- Anything other than a LS??
- Cant turn the crank to install tc 98 ls1
- Difference between L92 and LS3
- ls1 vette vs camaro
- LSx Headers
- 5>7 Hemi swap
- Cam bearing install
- HELP! Dynatech headers burning plug wire
- lsx oil pan help on a slammed a body
- okay, my head hurts. A-Body conversion
- ATS oil pan problem.
- Tach not working like it should
- LS with a F1R Procharger? build options?
- 02 ls1 into 65 GTO battery cable question
- ls 5.3 into my 87 buick
- Street & Performance Electronics LS1 Valve Cover Conversion Kit
- ls1 69 camaro
- Best intake for boosted applicaton?
- RHS block 461 LS engine build thread - now built, dyno tomorrow
- ATS oil pan relocation filter
- LS Turbo newbie
- Valve train noise / lifter preload question
- GM #12557583 Pilot Bearing
- LLT swap?
- Problem setting LSx into wayne due subframe: engine mount perches
- LS1/T56 swap into 73 Corvette
- LS2 Top Radiator Hose 69 Camaro Info Needed
- Calling all LS1 69 Camaro installers
- Ls2/4l85e?
- Ls starter
- Is there anything SPECIFIC about a LS swap into a 67 pontiac GTO?
- Has Anyone Used the Chassisworks Billet LS Engine Mount Set?
- LSX dropouts put shifter where?
- 91 K5 LS conversion
- FI tank fab questions
- LS2 not getting full throttle
- I may be dumb, but--correctly venting an lsx w/o pcv?
- LS parts compatiblity
- info needed on these parts please
- Mast Motorsports now has 14 different fully ported CNC Cylinder Heads
- LS Gas tanks--too many options!?
- Matching different LS parts
- Taller mounts or stands
- intake foam?
- motor mounts
- obd II install?
- 6.2 l92
- Retro LSX pan clearance
- Windage tray questions
- ecu ground for obdII
- trailblazer ss intake
- LSX mounts any one wanna give idea?
- gas mileage worse after tune
- ls2 with th350
- LS oil pan into Heidts Subframe
- B-body -67
- Need info on a shop
- best header for ls1 swap 67 camaro
- New GM LSX Valve Covers
- ls guys Help!
- Sell me your ls7 :)
- anyone ever used...
- LS oiling issues on a Road Course?
- LS3/4L65E Swap into '67 Chevelle Completed!
- Another Texas Speed Retrofit!
- oil pan and accessory question
- Best LSX daily driver accessory drive
- What is the actual HP of the LS3/480?
- l92
- Pontiac to chevy engine mounts
- hooker mounts
- Phoenix Area LSX Engine Dyno
- Lexus GS300 LS engine Mount kit!!!
- Swap! LS1 or LS2 ? Help decide....
- LSX454 Weight?
- injector size
- need some LS 5.3L engine opinions
- How much of this would swap out...
- throttle cable for ls1 2nd gen?
- dbw motor, dbc ecm?
- RetroLSX
- LS1 intake swap worth it ?
- Low Budget!? Use everything from LS 6sp swap car and finish around $4000?
- LS6 Cracked Block Repair?
- Mast Motorsports builds Ultimate NA LS Pump Gas Street Motor (870hp/665tq)
- 6.0 noisy valvetrain on startup.. what would you do?
- harness integration question
- difference between 07 and 08 ls2 harness/ecm
- LS motor mounts for a '67 Firebird
- motor mount 68 camaro with muncie ?
- Help! Abear hidden coil valve covers
- It's time for a little more mojo.
- Metric to standard fitting for mechanical temperture gauge?
- will z06 cam drop right into an 08 5.3 lmg?
- LS3 rod bearings - please help
- GMPP muscle car oil pan
- Dry sump engine height drop
- DropOuts LS2 vs Ls3
- LSX Tuners, need help determining detonation with HP Tuners scan files.
- fuel line limits
- Mast Motorsports Controller/Tune question:
- Most LS for the money?
- is there a problem with 98/7 ls1s?
- Tuner simulation softare?
- motor mounts for a '72 firebird?
- Which ECM for an LS7?
- L76 into 69 Firebird - Steering Joint(s) Replacment
- Help me outfit my new LSX 454 for my 70 Camaro
- LS header flange in 304 SS .500" thick
- Radiator hose for 2nd gen
- Stock L92 engine in a car?
- MSD/APS Starter -- GM LSX454
- LS back from machine shop
- Question about Ls2 engines
- Did the Katech rod bolt upgrade today
- Best 6 speed for crate engine?
- upgrade to 243 or keep 241?
- Where to get great deal on LSX motors?
- engine harness question
- For those running a GM Controller for LS setup
- LS stroker crank?
- 6.0 ls2 bellhousing to fit a ford c4 tranny
- speed denisty???
- MEFI4 controller better than stock LS?
- Most "budget friendly" LS Swap parts
- Split Lock header bolts
- Ls2 72 chevelle
- Weight of a LS3/T56
- plug for stock oil sender?
- charcoal canister?
- Is this a good deal on a LS6?
- cts-v pan
- LS9 Performance Upgrades & Modidications
- Have a line on a 5.3
- LS1 starts but dies
- Can a non LS motor be made to run like a LS motor?
- LS engine cover
- Little off-topic - looking to do ECU update on mostly stock 5.3 Tahoe
- what year did the ls2 reluctor count change
- Need help ordering an engine ECM and Harness.
- LSx & cruise control questions
- Cam change for LS6 researched, help.
- Modded LS2 as Daily Driver, Help Needed
- best way to pull a flywheel from LS
- PS pully interference with stock Gen 1 Camaro subframe.
- -6an too small for a breather tank?
- Air intake tube
- oil pan questions
- L92 accessory layout diagram?
- Ls7 with TH400 trans
- ls1 or lq9 which one???
- Anybody run the EZ EFI on a LS motor for old school looK?
- clarification of accessory options with the LY6
- Anyone with a LS with C5 accessories/pulley's and stock control arms?
- LS2 Victor JR vs Performer RPM
- ls2 into 65 stang...
- Valve Spring question
- swingin'
- Realized I have a 24x LS2 - Question About ECM? E67 or E40?
- Problems with Kooks custom conversion headers!
- ls2 cam, intake manifold and carb
- Will my original clutch linkage work with my new LSX376
- Will C6 manifolds fit LSX block and heads?
- oil pressure sending unit leak?
- LS2 running rough
- l92 turbo intake!!!!
- weird chirping noise - after installing ps pump??
- inectors and fuel pump
- just something cool
- What headers will fit a 1966 GTO with a 04 ls trans plant?
- Help! LY6/6L90 Swap
- MAST motorsports controller or GM?
- Vortech supercharging my LS1 swap. Help!!
- Which reluctor wheel do I have?
- Questions about CA and NV engine swaps and smog inspections
- Anybody actually using the spectra tank
- edelbrock intake?
