View Full Version : The LSX Forum
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. How much NOS Can a LS1 take safely??
  2. LS1 fuel pressure range?
  3. Ok, who's done the cheapest LSx swap?
  4. Alternator clearance
  5. anyone else make a throttle cable bracket??
  6. DSE Fuel tank Vent questions
  7. Corvette Coil Cover installation question
  8. Fuel Pressure Regulator Problem/question?
  9. ATS firewall plate fit chevelle?
  10. 5.3L question
  11. Fuel pressure regulator for 5.3l
  12. Build most budjet friendly LS1 69 camaro - suggestions???
  13. another 1968 camaro LQ4 6.0 swap
  14. what is the diff between the brakets
  15. LS1 Turbo kit for 1st gen F-body
  16. High mileage LS1
  17. Difference between LS1 and LS6 pistons??
  18. header suggestions needed
  19. p1sc pro-charger on a LS-1 in a 67 Camaro?
  20. LQ9 6.0 VS. Gen1 406 SB
  21. 5.3 Alum engine - Deal?
  22. Ls2 question
  23. LS1 Painless Wiring harness for LQ4/9?
  24. Upgraded Oil Pan for a LS2? What's the best?
  25. kinda dumb LSx wiring question
  26. LS1 Oil Quantity?
  27. LS1 into 71 Chevelle??
  28. Fuel Pressure regulator Which one ?
  29. LS1 into a 70 duster
  30. whats the deal with the lq9
  31. carb. style intakes
  32. Help choosing LS engine
  33. power steering delete
  34. ls3 to hood distance?
  35. Budget front drive
  36. Unisteer rack does not fit with ls2, autokraft plates, and VA frontrunner
  37. L98 or 6.2 truck motor?
  38. Bating a dead hosre maybe (alt ?)
  39. 68 Camaro Project question
  40. Trouble Codes
  41. What would a bad MAP Sensor do??
  42. Ls1 low fuel pressure at hot start
  43. First gen ls1 problems help needed.
  44. LSx oil drainback issue
  45. Gauges / LSx
  46. LS2 vs LS3
  47. 5.3 verses all lsx block
  48. LQ4/200-4R into 71 A-body
  49. GM accessory drive system on ls7 question
  50. oil pan?
  51. Fuel mileage??
  52. who has a chevy a body with edelbrock mounts?
  53. edelbrock headers and plates? 1st gen camaro
  54. Autokraft LSx oil pan measurements
  55. Wegner Motorsports Black Anodized LS Accessory Drive (Picture)
  56. LS3 and turbo 350
  57. Need help ASAP...LS2/3/L92 question
  58. stock ecu controlling ac
  59. s&p hydraulic clutch bracket question
  60. L98 Questions
  61. L92 Intake Options?
  62. Maybe a stupid question
  63. GTO LS2 - 68 Camaro
  64. Best Drop out Motor for my 67 F body
  65. LS7 exhaust manifolds - Which mounts?
  66. ls1 dampner bolt
  67. Need DSE fuel tank Vent help!!!!
  68. LS7 Clutch for LS2?
  69. Oil pressure?
  70. best motor mount?
  71. MuscleCar Oil Pan Kit Specs
  72. What engine to go with?
  73. LS7 drive by wire problems?
  74. power steering pressure ?
  75. Hookers....
  76. 408 long block needing everything else (sensors etc).
  77. ls1 starts and runs for about 1 second ideas??
  78. intake for 454 lsx
  79. who can disable the vats function?
  80. Buying a used LS1
  81. Help LS3 Map sensor pinout
  82. Stock LS1 Manifolds - swap into 1969 Camaro
  83. how does the SB2 fit in.....???
  84. Very cool LS part number reference site I found..
  85. looking for help on PCV on supercharged LS1
  86. LS1, LSX, LQ9, LS3..........huh??????
  87. 68 camaro LQ9 turbo build
  88. 5.3L LS.. 491 hp and 445 tq... woot!
  89. What to do with 5.3
  90. motor mounts
  91. Which engine mounts/plates for wayne due subframe?
  92. LS7 Engine to be discontinued ??
  93. may switch to FI.. and auto..
  94. LQ4 from wrecked truck
  95. LS2 vette brackets?
  96. What temp is this LS thermostat?
  97. LQ9 truck intake
  98. What is the internal difference between the 5.3, LS1, LS6?
  99. LQ4 serial number
  100. LS2 68 Camaro newbie needs help!
  101. L92 header size?
  102. Need Some LS1 info
  103. STock GM Radiator or BeCool 2 row
  104. LSX to a 200-4R TV CABLE
  105. Help! Removing 5.3, how much wiring harness to get?
  106. LS2 vs. LS6
  107. Trailblazer SS 6.0
  108. drive by wire?????
  109. Fuel system Question.
  110. Dyno Test: FAST LSX-R 102mm intake on stock LS7
  111. Magnacharger Deals Anyone ???
  112. LS7 in a 67 Camaro - need help!
  113. "Street Rod Engines"?
  114. Best gas mileage out of a 3200# car with an LS3 + 6L80E?
  115. powermaster ls starter 9201
  116. ls2 into pontiac lemans sport
  117. Engine builders
  118. GM's LSA crate engine...
  119. Let's talk LS7
  120. This 5.3 worth it?
  121. LS7 aftermarket subframe clearance
  122. LS1 & wayne due subframe- which mounts, headers?
  123. What year of harness will work?
  124. Ls1 engine
  125. Help with my 67 Firebird...
  126. LS1 oil pan question
  127. 5.3 conversion wiring Confusion/solution
  128. Which 6.2 has VVT ??
  129. valve cover question
  130. LS1 T56 swap into a 1968 Camaro
  131. School me on the 5.3
  132. Jake's Performance LY6 6.0/4L80E into 1973 Camaro
  133. DSE Fuel tank Builds up pressure????
  134. LS in 1st gen valve cover question
  135. Modified LS1 oil pan baffle
  136. ATS motor plates and AutoKraft pan?
  137. LS? Cad Drawings
  138. 04 GTO engine + trans in 69 camaro
  139. GM part #10033125 fuel valve question??
  140. How much fuel...
  141. LSx Headers in a 69 Camaro
  142. ls1/lt1 interchange
  143. looking for headers with factory a/c
  144. Magnacharged LS2 in my area.... any problems putting into '69 'Bird?
  145. LS factory oil pan gasket thickness?
  146. 200-4r behind a ls1
  147. GTO oil pan
  148. best way to adapt C5/C6 drivetrain to a 69 Camaro
  149. LS engine indentification
  150. TO Bearing T-56 to LSx
  151. LS3 Accessories
  152. Ls1 ecu ???
  153. How much power do you lose in the drivetrain??
  154. Which LS based engine to put in my chevelle?Bang for my buck?
  155. Markings on L92 heads?
  156. LSx bore/stroke interchange info?
  157. ls water pump
  158. bolt size from 6.0l motor to trans
  159. t56 question
  160. GMPP Drive by wire ECM/PCMs--OBD2 or CAN?
  161. LSx into a Nova
  162. corvette accessory drive system
  163. LS2 crank pulley
  164. what in-line fuel pump do you have
  165. Need 5.7 help
  166. Looking for an engine
  167. LSX Swap Questions
  168. Magnacharger with A/C relocated up top?
  169. Any recommended head porters for an LS7 head?
  170. What mods for a an LS7? Cam pick?
  171. homemade engine plates
  172. GMPP Drive by wire ECM to factory tach?
  173. Length when extending LS1 f-body oil tube?
  174. Fuel rail covers for a 98 f-body ls1
  175. throttle cable and pedal on 68 lq9
  176. lt1 to LS1
  177. LS motor - head bolts/studs
  178. Another DBW vs Cable throttle
  179. LS7 motor needs ECU - What to get?
  180. Choosing a LSX.... Help Please!!
  181. Trail Blazer SS Motor and Trans
  182. LSx vs. LD5 weight?
  183. LS coils - LS2 vs LS3 vs LS7
  184. ls1 headers for 69 camaro with art morrison subframe
  185. LS1 Short block
  186. LS1 F-Body Oil Pan Notch....Help Please..
  187. Does the Truck Accessory Drive Fit?
  188. O WA TAGU SIAM - LSx Valve cover breather
  189. Does Corvette LSX accessory drive fit Chevelle?
  190. Trail Blazer SS accessory drive
  191. 69 camaro 4l60e crossmember
  192. 98 harness and computer
  193. A couple of other Trailblazer SS Questions
  194. LQ9 - Good to Go, or In Need of Rebuild?
  195. dumb question on egine mounts
  196. lsx cam ?
  197. LS7 titanium rods, what can they handle?
  198. Budget Minded Throttle cable First gen Camaros
  199. New LHX Swap oil pan CAST
  200. Question about buying LQ9 engine
  201. Taking the LS Leap
  202. have anybody done a LY6 swap?
  203. Looking for an engine & tranny.
  204. In tank fuel pump
  205. Vengeance about to take the LS7 plunge!... Guys please help me figure out what i need
  206. Question about coils
  207. Anyone using 4th gen F-body headers on a 1st gen?
  208. what cam to use
  209. TR6060 & LS3 into a 69 Camaro
  210. Narrowing down my new LS engine combo..
  211. LS Engine harness firewall pass thru
  212. what to buy, Ls1 or Ls6?
  213. installing LS in a 69 camaro
  214. LS1/TKO 600 Mechanical clutch
  215. corvette LS alternator ?
  216. LS7+WCCH ported L92 in a Blazer
  217. Coil Packs - Which Connector
  218. How big can i make 5.3
  219. low profile oil pan
  220. ls7 oil pan?
  221. Mike Norris Motorsports EFI Tuning In Your Area
  222. advise twin turbo ls3
  223. 6.2 w/ 6-Speed Auto Question??
  224. Need advice on LS7 Accessory setup
  225. What ECM is everyone running?
  226. Share your LSX Tuner Experiences and Recommendations
  227. 6.0 engine and 4l80 trans opinions
  228. Cheap Parts for a Grassroots Motorsports 2010 Challenge
  229. low budget ls carbed combo?
  230. ls2 accessory drive for 72 chevelle
  231. Early model radiator for an LS1??
  232. Tuning the GMPP PCM
  233. Stock LSX Exhaust Manifolds For A 67 Camaro??
  234. Good LS deal???
  235. ats mounts and headers??
  236. 5.3 DBW to DBC conversion Which PCM etc.
  237. weird chirping noise from driver's side?? help!
  238. Is it worth it to port L92 heads??
  239. LQ9 + LS3 Heads: Cam Recommendations?
  240. Upgrades for 402 LS
  241. 1969 camaro preping for LS7
  242. Active fuel management
  243. LS3 engine cover on LS1??
  244. LS1 Procharger 1972 camaro alternator, a/c compressor questions
  245. Ls2 cam selection help
  246. Flywheel for LSX 8 bolt crankshaft
  247. What goes here behind throttle body
  248. Stick or auto?
  249. gmpp LSX376?
  250. Electronic Throttle Control on LS3 conversion
