View Full Version : The LSX Forum
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. 10-15k for a LS1 install, how is that even possible?
  2. Billet Specialties True Trac LSx
  3. LSx into old Corvette
  4. what do you think the labor charge should be for a head and cam swap?
  5. what do you use instead of the TR Cam swap tool to keep lifters from falling?
  6. Headers and ATS plates
  7. LS1 into a Monte Carlo
  8. is the 4l60e worth anything? all i see F/S are ls1/autos
  9. SW LT Header clearance problems w/ S&P plates (stock steering)
  10. OEM or Aftermarket Clutch
  11. Any opinions on my LS1 build so far?
  12. Hot Rodding a 5.3L vortec
  13. LS1 F-body accessories
  14. Mark Stielows Camaro X Dry Sump
  15. Corvette Engine Covers?
  16. anyone using autokraft engine mounts
  17. Pin hole in oil pan
  18. Aftermarket 90mm throttle body for LS7
  19. 1st gen f-body ls1 motor height???
  20. Differences between the LS1 and LS2?
  21. LS2 Cam advice needed
  22. whats needed to bring a short or long block to life?
  23. What did you use for fuel lines on your conversion? Braided, stainless?
  24. Lt1 Engine mount ?? in a 69 camaro
  25. 6.0 Ls1?
  26. Displacement on demand
  27. aftermarket oil pans, how do you close up bell housing
  28. this might be better for the interior thread but planning my swap a couple of ?s
  29. Basic cost of install?
  30. Basic cost of install?
  31. can i use a Ls1 intake
  32. Wire Harness
  33. Carbureted LS2 Engine ???
  34. Anyone tried Hookers w/ ATS mounts?
  35. Changing oil pan on 69 camaro
  36. What did you guys find to be the biggest challenge in your conversion
  37. Has any one tried the Painless Perfect RPM system yet?
  38. Probably a dumb question, but...
  39. Not sure where this should really go (LSx cooling)
  40. Considering head/cam swap & need advice
  41. Possible Budget LSX Accessory Drive Systems (GM P/Ns)
  42. Where did you mount your Fuel Pressure
  43. Trying to decide on what engine....
  44. 65 chevelle
  45. 2dr 2wd Tahoe LSx Swap.
  46. ls1 auto weight vs gen1 auto??
  47. Ls7 Internals
  48. Newb here, LS1 shop recommendation, NorCal?
  49. Ls1 Ls7 Stuff
  50. Displacment on demand
  51. LSX 427...which Intake and TB?
  52. Run to the Sun, Myrtle Beach?
  53. LS build your own headers?
  54. ls6 vs ls7 heads?
  55. Low oil pressure.. argh!
  56. Car Craft LQ/L92 build
  57. which cam to use on 5.3
  58. cool new LSX engine lift plate
  59. Crank Position Relearn
  60. Question about intakes for the L92
  61. 4" intake tube couplings ( no gloss)?
  62. How Hot is Too Hot
  63. Parts swapping LSx
  64. carbon fiber intake tube
  65. Stock LS1 harmonic damper
  66. L92 6.2 Pan Fit A Body ?
  67. Known LSx swap combinations. Please Read.
  68. Here comes the LS3.
  69. LS1 Computer and Cooling Fan Question
  70. ATS LSX Drive System
  71. Twin Turbo Lsx pics and dyno numbers
  72. Ls2 Front Drive set up
  73. ATS LS7 oil pan
  74. LQ4 in a 65 A-body
  75. LS2 Prices coming down!
  76. What's the difference between ls1 and ls2
  77. Stock exhaust manifolds
  78. Is the ATI Super Damper Harmonic Balancer Really worth the Money?
  79. LS7 twin turbo finished
  80. Is it safe to buy from LS motors on ebay?
  81. Just Got An '07 6.2 And Auto 6 Spd.
  82. cylinder setting when pulling tach signal from coil
  83. Stock LSX Oil Pan in Chassisworks subframe?
  84. Proposed L92 build up
  85. GM Gen IV VVT Dyno Data
  86. Value of GTO LS2 / 4L60E + parts ??
  87. anybody have problems with street and Performance?
  88. Lsx 6 bolt Heads
  89. LS1 swap oil pans
  90. where to mount ecm?
  91. Unknown LSx swap combos
  92. Corvette fuel filter/regulator
  93. Best LS1 engine mounts for 67 camaro
  94. LS2 conversion
  95. Jegs Aluminum LS1 radiator
  96. LS2 A/c
  97. Pics of 4in cold air induction for 1st gen
  98. Maybe this helps!
  99. LsX Conversion Motor mount
  100. ls1 with distributer?
  101. 400 club
  102. 413rwhp plus Ls2 dyno
  103. are all 6.0s worth building? I want l92 heads and a carb!
  104. Help me pick out a cam
  105. My Modifed LS-7
  106. Flexfuel and DOD, anybody?
  107. Will any 98-up V8 PCM work for an '03 4.8L?
  108. anyone seen the "car shop" swap oil pan?
  109. General LSX Information
  110. Few swap questions
  111. Mileage!
  112. The LS3 delivers!
  113. school me on wiring for efi
  114. Options for aftermarket LS1 oil dipsticks?
  115. Buying a LS1 but got a question?
  116. LSX into a G-Body?
  117. Will any 4L60e work?
  118. LS2 good deal or not
  119. Anyone have regrets of going LSX
  120. Coil relocation
  121. Didn't someone make a Eaton manifold for the LS motors?
  122. LSX Efficiency: EFI vs. Carburetion
  123. Well that just burst my bubble :(
  124. finally got an ls1
  125. jegs ls1 swap kits
  126. caddy LS
  127. LS3 Dyno Goodness
  128. Anbody running carshop mounts
  129. LSX in a 63 nova
  130. LS2 Questions
  131. Oil sump on LSx engines
  132. Katech Value 427 Short block
  133. What's the most affordable oil pan for a Gen III engine swap?
  134. Building an LSX engine for school
  135. Is this a good deal on a LS1?
  136. Got Bored...Is this a Good Idea?
  137. LS1 power streering pump??
  138. How many miles is too many?
  139. ATS Motor mounts with ?? headers
  140. Mounting the Computer
  141. Rear gear in LS1 69 Camaro
  142. Questions on a LQ4 or LQ9 build
  143. How much boost?
  144. Anyone using the trans dapt motor mounts on their 67 camaro
  145. 6.0 + L92 heads = 500 hp?
  146. LS Time - Help me choose...
  147. thoughts on painting an LSx motor...
  148. ls1 engine install guide pdf file
  149. What year F-body radiator and fans in 69
  150. LSX coil packs
  151. pictures and measurements of Trans Dapt LS1 mounts
  152. Anyone...
  153. questions about ls2 402
  154. Are all T56 crossmembers created equal?
  155. Fuel system questions.....
  156. I have too much fuel pressure
  157. Delima
  158. Anyone deal with Dave @ OC Stangs??
  159. Let's talk gauges
  160. Anyone done TT LSX setup in 1st gen?
  161. LSX porn. Post up your best LSX engine photos.
  162. oil pressure sender question
  163. Gaskets for S&P Headers
  164. What header bolts work best
  165. Big Problem Please Help??
  166. LS1 swap into a 55 re:exhaust manifolds
  167. LS6 intake casting numbers
  168. Bored out 5.3L for LS1 pistons?
  169. To tune or not to tune?
  170. Considering replacing LS6 with LS7. Can I still use the headers?
  171. Some helpful LS1/6 etc Info
  172. 2005 6.0 swap in to a 2000 ws6, need some help! asap!
  173. what are the best mounts for 79z
  174. Questions about running an external fuel pump....
  175. ricks efi tank with carb ls1 setup
  176. LSx running hot only at idle
  177. Stripped bolt on LS1??
  178. Stripped oil pick up tube bolt??
  179. Hard time Choosing.. built LS2 or stock LS7 give me your vote!
  180. What body harness in 69 Camaro w/LS1??
  181. 4th gen headers on 1st gen?
  182. newbie needs help: LS2 or LS1 for 2nd Gen F Body
  183. 70 Camaro LS1/T56 questions????
  184. Questions on engine building
  185. Friggin need advice
  186. lsx instalation kit for a 72 nova
  187. Ls1-t56?
  188. LS motor installation kits
  189. Stroked h/c/i LS1, LS2 h/c/i, or LS3 c/i?????????
  190. Would this fuel pump be good for an LS1?
  191. I might be buying this LS7 engine.. need help IDing it.. what do you guys think?
  192. Still confused on this oil and temp sensor deal.....
  193. Question
  194. t56 in a 79z
  195. Venting spent gases in an LS1....
  196. Doug's ls1 swap headers!!!!
  197. ls1 in a 1st gen, what power steering hose? 3rd gen box
  198. What is this and do I need it?
  199. 1st gen ls1 swap with turbo
  200. List of PCM items to delete....
  201. Help getting started
  202. power steering pump and bracets for 1st gen
  203. Professional Products LS1 intake?
  204. Anyone come out with a new LS front runner?
  205. what are the specs on the LS1 master cylinder?
  206. 67 Camaro LS1 project
  207. N00b LS question
  208. Mast Motorsports LS3 427 Dyno Numbers and Product Release
  209. ls1 camaro frame mounts
  210. LS2 Info ?
  211. Setting up Transmission angle (LS1 related).
  212. 454 lsx?
  213. 67 LS1 Camaro
  214. LS1/T56 into a 2ndGen Trans Am: lot of questions
  215. Hummer oil pan in ls1 camaro
  216. s&p plates, ats crossmember, engine isnt level *pics
  217. 4l80e and LS2 Crate Motor Help
  218. Edelbrock is making ls 70-72 A body conversion kits
  219. so here is my "budget" LS1 combo
  220. LS1 tweaking and durability
  221. Transmission Crossmember
  222. 600 hp LSx with 2.5" exhaust?
  223. Is this gonna work for the fuel pressure?
  224. What brand fuel rail covers are these???
  225. Ultimate LSx Build
  226. Twin Blown lsx by Nre
  227. Schwartz LS7 projects
  228. What to do about a gas pedal assembly?
  229. Caddilac LQ9 question
  230. Freshen' up a 6.0L
  231. pics of the hooker mounts in a 69
  232. LSx Motors: why switch to a carb intake?
  233. LS2 Swap first-gen Headers Help!
  234. Another LS swap mount plate, real nice from AA
  235. LS1 engine harness
  236. Motor mount and engine mount just wont line up
  237. Gas tank setup
  238. I am WAY overwhelmed.... GMPP LSX in a 70 Chevelle
  239. Thoughts on dropping in an L92?
  240. Pulley issue need help please
  241. Drive by wire mounting
  242. LS3 in a 66 chevy II nova
  243. Edelbrock ls1 headers for chevelle?
  244. Fuel system questions
  245. LQ4 swap in a 68 camaro
  246. Ls1
  247. crate lsx
  248. LS2 camaro dyno results
  249. Ls2/tko500
  250. ls1 coil on valve cover 45* spark plug wires.
