View Full Version : The LSX Forum
Pages :
1
2
3
4
5
6
7
8
9
10
11
12]
13
- Steering Column Keys
- Air intake through radiator support
- ls3 camshaft
- Not so expensive mock up motor?
- 2.9 Whipple Hood Clearance 64-67 A-body
- Need help with LS3 swap in 69 camaro
- 1970 Buick GSX LSA SWAP
- LSA front engine drive
- Rear Main Leaking - Again
- LSA, what do I do for vacumn for brake booster, help
- header options ls3, dse subframe 69 camaro
- Holley Low mount AC Bracket
- Exhaust kit for LS/4L80E A-Body
- LSA Lid on First Gen
- Oil pan for 67 camaro/ls3 with rack and pinion...
- LQ4 build questions
- 416 First Gen Camaro Oil Pan
- Ls conversion question
- LS3 Cam Selection
- Anyone used this LS swap combo in a 2nd gen F-body?
- 6.0 Starter grinding on flexplate
- LSX conversion wiring harness favorite
- alternator only bracket for ls3
- LS3 header options with mechanical clutch 69 Camaro
- THE MCB TAX TIME SALE HAS BEGUN! Now - Mar. 15th!
- Radiator Installation
- Drive Junky Early Bird 2019 sale has begun
- Transmission Cooler Location
- HELP - LSA Crate Engine won't fire
- Damaged LS3 Block for $100.
- Holley LS subframe mounts first gen Camaro problems
- FiTech Ultimate LS with Trans Control - Anyone using this?
- porting ls3 heads
- GMPP 525Hp LS3 with T56 SuperMagnum and Dakota Digital DBW Cruise Control
- 1955 Chevy 6.0 all wheel drive
- Holley Terminator X
- GM ecu vs aftermarket and PWM control
- LQ4 with a new TVS-2300.....build questions
- Help Identifying Rod Bolt Part Number
- Advice to avoid fitment issues with lq4 in 1969 camaro (ridetech suspension)
- pcm options
- LS3 eRod ODB2 Port
- Melted PS reservoir nipple/connection.
- LS7 with LSx Speedtech oil pan not registering oil on dipstick.
- Connect and Cruise or build?
- LS3 Cruise & Connect for 68 Chevelle
- LS Oil Cooling?
- 12k LS motor and tranny 500 hp build challengr
- LS2 camshaft going to whipple
- Need help to keep engine running!
- ls3 camshaft position sensor codes
- Which LS swap kit for first gen camaro?
- LS3 motor swap what can I use what can’t I use
- LT1 with LT4 blower wiring harness options
- LS3 into ‘67 camaro DSE engine mounts -oil cooler in the way
- Need help figuring out how this valve got bent like this
- New Billet Specialties LS Valve Cover Conversion Kit for Big Block Chevy Valve Cover
- LS Swap with speedtech Sitting too far forward
- Quality metric fasteners
- LS oil pan - lowest profile -
- LS6 with supercharger pros cons?
- Intake valves
- T56 reverse lockout problem
- LS Tuning
- timing set
- LS2 ticking
- LS swap rollover valve options
- 2013 SS Camaro swap into 69 Camaro
- Looking for info on maf or speed density tune
- Turning engine over by hand question
- Resurface an used ls7 flywheel?
- L99/6l80e swap no spark!
- 2013 or 14 ls3 l99 ecm pinout
- Whipple 2.9 under stock cal hood
- Oil catch can setup
- Holley LS engine mount, Total Height Installed.
- BRP hotrods products?
- PCM refuses to deliver spark
- 69 Camaro t56 swap crossmember needed.
- LS2 DBW throttle issue
- LS throttle body question
- 1969 Mustang / Cougar LSX Swap Kit ?
- GM box frame/ convertible frame
- Tutorials for Basic and Advanced HPTuners Now Available!!!
- LSA Belt drive system
- 4.5l Whipple
- LS3 Coolant Temp Sensors
- LS3 First start oil issue
- LSA ECU and Fuse Center
- Ridetech coil overs how to adjust ride higher?
- LS Oil Pan Buyers Guide
- LS1 Wake Up!!!!
- How to go about pinion angle on a 5.3/t56 swap?
- Mounting Intercooler Pump
- need help, LS3 swap into 70 Camaro cranks but no start
- LS Swap motor recommendation for reliable driver with AC
- LS3 Holley Oil Pan
- holley white box oil pan
- Lsx 454
- Low oil pressure at idle. LH6 in an '08 Envoy
- A/F jumping at idle
- Dry Sump Tank Help
- Drive by wire question...
- Anyone got a few bolts? GM 11588711
- Ls2 rough start up
- Harmonic balancer ac pulley
- Ls3 starter issues
- Has anyone used/ heard of this starter?
- I want to supercharge my LS2 suggestions?
- LS Mounts for 72 A-Body + Oil Pan options
- LS7 Atomic Air Force Intake
- Ideas for coil relocation, LS3 in a first gen
- TKO Crossmember Help!
- LS7 into my first gen Fbody
- Ls oil prime
- Some weirdo mapped out every single LS engine, ever
- Painted LSA Pics??
- Turbo LS street car engine managment
- Need steering pump help...
- LSA Coolant in Oil Pan
- LS oil dipstick, What's everyone using???
- 69 Camaro LSA
- LSA TB work the same/compatable with the LS3/LS7 TB
- Gen IV tuner?
- Detonation under no load
- Gen IV questions/build
- Kwik Performance Assembly Drive Help
- Spun bearing on LS7 with wet sump conversion
- Help!
- LS swap hooker headers?
- L96/ly6
- FiTech LS 92/102mm Throttle Body
- cold air intake for 1969 camaro with ls3,
- Pics of coil relocations please
- Who makes a nice LS Engine Harmonic Balancer Puller?
- LS7 from LMR
- New engine, sat untouched for fifteen years
- Issue with Hooker Crossmember and t56 magnum 72 Nova
- LS Swap 6.0 - 100k miles on it. What should I replace?
- Question about terminator x
- N/A LS3, stock bottom end
- LS3 - 495 seems to be spitting fuel all over the back of my car
- Crankcase ventilation for NA 5.3
- Aluminum vs iron block
- LS3 in a 69 Camaro, weird shuttering when turning off engine
- 2015 LS3 front drive??
- Tensioner position
- Need some help selecting headers
- Dakota Digital bim module
- Catch Can Routing....
- Swap mounts that allow low mount A/C.
- First start ideas
- LS3 corvette water pump, where to tap for vent/steam port?
- LS swap - fuel pump relay not turning on
- Ls3 lost oil pressure
- Ls7 wet sump crate engine now available
- LSA vs Mast Motorsports vs Pace Performance
- need MAJOR COMPUTER HELP - LS3 in speed density
- PSI conversion Harness and HP tuners
- Ls2 acting up....again
- 2013 Camaro LS3 into a 66 GM A Body (buick skylark) accessory drive options?
- 29 ways the LS is better than the Small Block Chevy
- 5.3 flexplate
- universal cold air intake vendors?
- Ls3 cfm
- “Junk yard” engine
- What do you think I can gain from Tuning an LS3 with hotcam
- 1980 F Body Air Intake
- LS3/L92 timing damper + oil pump?
- Will FAST LSXHR intake fit?
- texas speed ls headers
- Anyone Else PUMPED About LS FEST EAST!!!!
- eBay Sloppy Stage 2 cams legit?
- Carb LS - PCV Help
- question for guys with 102mm throttle body
- 67 Nova LS conversion
- P0171 P0174 LTFT 24% at Idle
- Fuel injector recommendation
- Why is my truck slow?
- Video comparing LS to LT
- holley sniper intake help
- Ls motor mounts for tri-5 chevy
- Water in Oil Pan
- LS3 cam swap and vacuum
- Ls2 questions
- Tuner near The Villages, FL
- LSA injectors and spark plugs
- Components to mate an LS427/570 and T56...
- DIY Home Air Intake-What has worked well?
- C1 Corvette LSA swap
- 6.0/6l80e out of a G8 GT into a 67 A-Body?
- Which ATI balancer for ls3 480 crate engine?
- Lsa or ls7 570hp?
- 98-02 GM F body pan in 68 Camaro?
- Drive By Wire Pedal Assembly
- Need help finding the fitting size for CTS-V V2 Power Steering Pump
- Turbo ls3 vs 427
- C1 corvette lsa 6l90 build
- Anyone used the Speed Engineering oil pan in a GM A-body?
- 67 Camaro LS2 Silicone Radiator Hose?
- Nick Williams TB Internals and base tune Holley Term X Max
- Hardline to Flex to Tank Connection and to Fuel Rail
- Getting the engine/trans in
- Mating LS427 to T56...
- Gas leaking out of tank vent
- 2005 Cadillac 6.0 swap. Please recommend valve train, etc. for Sloppy Stage 2 cam
- LSX swap Malibu
- LS swap to TKX help
- Engine alignment in the engine bay...
- LSA or LS3 best fitment in 66 nova w/ tci everything
- Alternator options
- Corvette filter regulator limits.
- Opinions on Cam I am getting from Cam Motion for LS3 swap.
- LSA what mods? LSA into 70 Camaro swap question / parts
- Oil catch can
- LSA Crate engine Ship with oil?
- RPM Gauge Signal
- Help! LY6 Turbo selection
- will a truck intake clear hood
- Ls3 tick
- Help! Weird Issue L99/6L80E
- plumbing oil return for an oil/air separator
- Harmonic balancer removal and installation...
- Help---LS& in 69 camaro
- No pulse to #3 code p0203
- Damper position...
- Burping LS cooling system?
- Unloading the belt tensioner…
- L99 friction ring/ seal Question
- 5.3 swap from old truck to new truck and wont run now
- HP Tuners training looking for recommendations
- Anyone running an ITB set up on an LS3?
- What should all be included from donor car for a smooth LS swap?
- Inline fuel pump pressure problems walbro 255
- Help diagnosing stumbling/back firing LQ4
- Broken intake bolts
- Computer and battery disconnect
- LS1 GTO ecm rev lock out
- Undecided lsx 454 n.a. 700hp vs 408 stroked 2.9 whipple sc
- Holley Terminator X Max Software
- Did anyone buy out the old Street & Performance inventory?
- LS7 & super victor intake
- Pushrod length
- Temp sensor
- Tach issues
- Rad hoses for LQ4 swap into 79 T/A
- Lq4 rockers and pushrods
- Gas tank vent options
- First Gen engine mount adapters
- Stand alone harness
