View Full Version : The LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. Fuel Line Question
  2. ly6 swap- having start issue
  3. Ls accessories clearance
  4. L33 5.3 or 6.0 Denali
  5. To stroke or not to stroke
  6. Post your twin turbo LS swaps!
  7. Muffler recommendation for LS swap
  8. Odd or Even
  9. LS2 swap-throwing codes P1682 P1516 P2101
  10. Best bang for the buck cylinderhead for the 415 LS3 ?
  11. LS3 525 hp crate motor upgrades
  12. LS3 Oil Filter Adapter For 2nd Gen Camaro
  13. Ls3 starter won't fit on t56
  14. Tick LS master cylinder on 2nd gen camaro
  15. How to mount ls3 gas pedal?
  16. What is this?
  17. Direct fit torque starter recommendations(ls2)
  18. Radiator Recommendation please.......
  19. where to mount holley efi ?
  20. few last min questions on my LS3 swap
  21. LS6 Won't Start after electrical work
  22. LS1 Passenger side head mount accessory spacer for LS1?
  23. hiding coil packs
  24. New LT1 or general 5 motor swap questions.
  25. 71 Firebird with 6.0 L76 and 6L80E auto
  26. Any 67-69 f body guys running ls autocraft pan
  27. Fuel Gauge and PCM fuel level input
  28. LS ECU options
  29. ls GM crate engine price increase?
  30. Will a Vortec Fit with stock intake?
  31. Griffin fan wiring
  32. power steering hose to pump routing
  33. any other 67-69 f bodies running ls3 accessories
  34. Rick's Restomod Tank Question?
  35. Aftermarket accessory drive - need opinions
  36. scarebirds 2nd gen fbody DBW pedal kit (pics)
  37. Trying to get opinion's! Pro touring vs x275 for the street?
  38. 67 Camaro LS swap header fitment
  39. Which Harness ECM to use LS1 or LS2
  40. Mounting the computer....how'd you do it?
  41. Texas Speed
  42. Katech chain LS7
  43. What size throttle body?
  44. LS3 /4L70 GMCC tranny issues
  45. Melling Oil Pump Install
  46. Front accessory drive for a 69 camaro
  47. 1 fuel line or 2
  48. LS1 head gaskets and studs
  49. Do you have to run a breather? LS2
  50. ls3 conversion not crank situation
  51. Fast 102 intake or Mast 4500 efi Intake for LSX454
  52. LS3 vs. LSA 67 Camaro
  53. LS1 70 chevrolet swap oil pan questions
  54. Which LS3 for my Camaro?
  55. Which Peterson tank for LS7?
  56. LS2 Fuel Pump Wire Not Energizing?
  57. PCV Routing
  58. Ls3 coil wiring
  59. Short Stroke 408
  60. Trunk Mount ECM - Length of Wiring Harness?
  61. LS engine with a carb, pros and cons
  62. Brp engine mounts or swap them out
  63. Will an LSA fit under 70-76 TA hood
  64. Knock sensor real close to header. Is this a problem? with pics.
  65. 70 Camaro LS T56 swap issue
  66. Crankcase Ventilation options for using vintage valve covers on LS2?
  67. LS2 Crank Position sensor P0335 no start
  68. LSA, LS3 Chassisworks front Sub 69 Camaro
  69. What injectors do you all use? I
  70. Where to Buy LSA
  71. LSA Fuel System
  72. Ls3 swap, no spark, no injector pulse.
  73. Harness on the Rail or on the intake?
  74. Connect and Cruise or better option?
  75. LS3 525 vs cammed 430
  76. ECM mounting. Is this too close??
  77. Holley Passenger side AC Bracket
  78. Gen III or Gen IV - 1969 Camaro Swap
  79. UMI Releases New Product: Lightweight solid engine mounts for the 93-02 GM F-Body
  80. LS header heat shield
  81. LS2 catch can or breather or both
  82. MAF location
  83. Holley Hi Ram Clearance
  84. LSA Hoses
  85. Alternator question
  86. LS2 into G-body swap (1979 cutlass)
  87. FAST 102 TB Insert repair
  88. Hack or Hot rod Fix !
  89. street and performance LS plates,where does it place the motor??
  90. ECU mount to replace glove box
  91. Serpentine setup on dry sump Ls
  92. Which ls7 pan adapter?
  93. Anyone put a LSA supercharger on LS3?
  94. ARP LS rocker stud
  95. Holley accessory drive 20-137 LS3
  96. LS Serpentine System
  97. Issue with holley transmission crossmember
  98. LSA Power Steering Pump
  99. Tuning LS7, what to do?
  100. Billet Specialties Valve Cover Adapter for LS
  101. Peterson or Aviaid Oil Tank
  102. LS7 Oil Pan inlet/outlet
  103. How many are keeping it old school
  104. SD vs MAF
  105. LS3 square air filter from Street and Performance
  106. LS3 square air filter from Street and Performance
  107. 4.0 Whipple fitment
  108. Whats cheaper basic 6.0 T56 build or LS1/2 T56 donor swap for first timers?
  109. LS3 Timing & A/F
  110. LS Cam Choice
  111. GMPP LS3 harness a lil short
  112. GMPP LS3 crate engine starter
  113. Ls3 crate motor and harness upgrade question
  114. 416/418 Stroker kit
  115. Pulley Aligment
  116. LSA with Holley High Mount Brackets
  117. Distance between Vette & truck belt?
  118. 1st gen camaro headers
  119. LS2 Temperature Sensor / 67 Camaro
  120. Adding a supercharger and need to beef up my fuel delivery
  121. Holley 20-137 accessory drive w A/C EVAP solenoid relocate
  122. LS1 not firing injectors on drivers side
  123. LS3 ECU Dimensions
  124. LSA Swap tips
  125. LSA ECU/harness and FEAD selection
  126. LS swap 69 Camaro w a 1990 (metric) PS Box
  127. 4L65E behind an LSA
  128. 68 camaro ls3 swap
  129. Hooker LS swap parts with Doug's Headers?
  130. Ls9 cam swap into ls3 with asa cam set up already .. valve spring question.
  131. Which front drive LS serpentine system
  132. Ls3 pcv
  133. 6.0 with LS3 engine combination
  134. I Need a Fuel Pump Relay
  135. Video Billet Specialties LS Tru Trac Installation
  136. 69 Camaro LS3 CAI set-up
  137. Wet Sump vs Dry Sump?
  138. I want to autocross with new engine
  139. Holley Alternator pigtail needed ???
  140. T56 Hydraulics in my 69 camaro question
  141. DBW pedals and tunes
  142. LQ9 Oil Pan, 69 Chevelle, Melling oil pump compatability question
  143. LS1 Power steering hose
  144. Custom made LS3 engine covers using the Holley Acc drive
  145. any experiences with the new Holly XP carbs in 850/950 CFM on a modded LS
  146. 67 pontiac A body frame mounts
  147. who’s running cat converters with their LS Swaps
  148. LS3 GMPP Bulkhead connection for gauges
  149. Oil Cooler Location - '69 Chevelle
  150. Holley 302-2 Pan hitting LS2 rod bolt
  151. c6 gas pedal bracket for 2nd gen fbody
  152. 02 sensor wiring hanging down low under car, looking for routing ideas
  153. NEW Edelbrock Pro-Flo XT LS3 intake manifolds
  154. DBW Throttle Pedal
  155. Auto plumbing experts
  156. LS Valve Cover Conversion Kit from Billet Specialties
  157. GMPP Harness with Vintage Air and Dual Electric Fans??
  158. Holley Mid-Mount Accessory Drive fit 2nd gen firebird?
  159. Oil System experience
  160. body module and ignition switch
  161. LS3 steam vent routing
  162. Ls3 hot cam gmpp tune ..... fine tuning?
  163. Valve covers with no pcv provision
  164. 70 Nova LSA T56 Magnum Swap questions?????
  165. CEL, GMPP harness for LS3
  166. LSA Cam selection advice
  167. Oil pan
  168. LS7 into 67 Camaro
  169. I need help doing ls1 swap into 69 camaro.
  170. LS3 vs LS7 fuel rail swap & injectors
  171. help with mast oil pan
  172. Serpentine Syst Needed for the Track
  173. Ls3 safe power up to 7000 rpms
  174. Headers for a LS3 in a 60 Brookwood
  175. Oil condition after break in?!?!
  176. Do all 5.3 engines have catherdral port heads?
  177. coolant overflow tank sizing?
  178. LS vs BB advice needed
  179. Holley 302-1 pan, Dirty Dingo adapters, LSx454 - Which mounts? - '69 subframe
  180. LSX Engine porn
  181. LS7 and LS9 Price Reduction!
  182. GMPP harness help!
  183. Replacement intake cover for LS3
  184. Billet Specialties Sport Trac Serpentine System for Chevy LS
  185. ARH and engine mounts
  186. LS3 480 questions ......
  187. Ls3 525 questions
  188. Tuner in the Northern VA area
  189. LSX engine cover
  190. Billet Specialties Chevy LS Thermostat Housings
  191. Throttle response difference? Drive by wire vs cable driven...
  192. 1967 Camaro LS 427 / 4L80e Swap
  193. LS3 480 swap ... 2.5 or 3 inch exhaust?? Muffler suggestions?
  194. full throttle signal fly by wire
  195. LSX370 Build for my '69
  196. 77 Firebird LSA Swap Advice Help Needed
  197. 69 Camaro LS3 with Entropy radiator upper rad hose needed
  198. Bare minimum for an LS swap?
  199. Mounting Bracket for LS1 Computer?
  200. Going rate for a ls7 with forged internals
  201. URGENT - Need low profile oil pan for LS7
  202. Reverse Lights Question with Lokar Shifter
  203. 69 Camaro, DSE sub, SS hood, LSA fit?
  204. LS3 crate engine factory tune question
  205. First gen camaro ls swap air intake options
  206. 68 Chevelle LS3 Oil Pan Conversion
  207. Lean bank 1 and 2
  208. LS2 misfire issues
  209. FITech LSx efi system?
  210. LSX376-B8 w/TVS1900 ECU question
  211. what is my LS EFI system worth
  212. Rear Cover Leak
  213. ADVISE LS2 catch can plumbing
  214. LSA swap in 69 camaro
  215. Billet Specialties LS Valve Covers
  216. LS3/4l60e trans flexplate ?
  217. Question on converting LS7 to wet sump...
  218. Stealth Engine Bay Heat Venting
  219. LS missing - tried almost everything to fix
  220. LS3 Clearance Issues to Frame
  221. Cam sensor question - LS3 with 1x cam gear
  222. LSA E67 flash
  223. What Are These Ports for LSA??
  224. Lsx 454 r
  225. 4.8 swap?
  226. Any starter experts in here? Starter grind post engine starting up
  227. Ls3 throwing map code and running rich during start up
  228. LS3 Long Tube Headers in 68 Chevelle
  229. Big problems: Oil bubbles in my ATS/Petersen dry sump tank with LS7 ?
  230. LS3 or L99?
  231. Scan Tool suggestions??
  232. LS2 swap fusible link
  233. LS, manual trans and cruise control
  234. Running too lean....
  235. Fuel Line for 1981 Corvette LS1
  236. Anyone used Rocky Engines to buy LS
  237. Just tried firing my ls2 for the first time
  238. Gen 1 camaro ecu mounting
  239. Need Quick Recommendation for Fuel Pump
  240. PCV Question
  241. 64 nova ls swap need help
  242. Sorry stupid question
  243. LS Chevelle swap AC fitment
  244. Fuel Pressure at The Rails will Vette FFR
  245. holley sniper ls1 intake
  246. LS to T56 Bellhousing question
  247. Hp tuners lsX tuning discussion and help. Anyone can ask
  248. Radiator & Transmission Cooler
  249. GMPP LS high idle
  250. 1969 Camaro - LS3 TKO 600 Flaming River R&P
