View Full Version : The Fabrication Forum
- Advanced Aluminum Welding ??
- How to make these pipes?
- Welding Brackets to 12 bolt Housing
- What happens if I try to fabricate this?
- home made rotisserie
- Mounted to the rotisserie---question
- Anyone have a solid model of a Ford 9"
- Stainless AN fittings
- Another welding question
- screamin performance?
- 1969 camaro fuel tank fab
- Welding Stainless Steel - shielding gas question
- The infamous Rigid band saw mod
- chassis jig design
- Working with Tap & Dies
- welding copper
- Fuel level sender
- Couple of fab questions
- I need Big Block Chevy valve cover bolt pattern please.
- Making a belly pan for fuel safe cell -
- Tungsten balling up.....
- Chevelle gas tank fab
- getting a plasma cutter worth it
- RollCage fabrication
- I need some help fiberglassing
- TIG welder....110V.....such a thing?
- Metal Spinning
- overhead shop crane in the garage
- Can I weld near gas tank???
- fiberglass laying techniques and mold making
- need tool bit sharpening tips for magnesium
- Looking for some crossmember input
- Tig welding mask
- Stainless Steel welding
- Fuel Cell mounting
- 70 chevelle dash board alternative
- Racing Fabrication Forum
- moving from flux to gas...
- Door holder
- anyone have a water jet.. need small job
- grinding wheel composition?
- press fit for power steering pump pulley
- where your skills come from
- Plasma cutters- Anyone have a specific brand preference???
- What should I build this flat body panel out of?
- Need some bracket water jet cut ...
- Roll Cage Gussets
- Sheet Metal Brake for Cheap
- Welding experts
- Straightening Vette IRS batwing mount?
- Question about Welder setting for SF Connectors
- Advice for "bolt-in" DSE SF Connectors
- square tube question
- RFR Matt
- Square tube reinforcement?
- Welding and certifications
- Honeycomb mesh
- What gives...
- welding 4130
- structural adhesive for aluminum
- My rotisserie build
- G code Lathe help with Radius
- Chromoly Tubing: Domestic vs Chinese
- structual body work questions
- fabricated spindles?
- Cutting Solid Zinc - Help
- Cutting 16ga. Stainless
- welding ss to mild
- bending aluminum
- Weld seams showing through new paint job
- Large tubing
- Metal finish question
- stainless steel welding
- stainless hard lines
- Fabbing Tail Light Lens
- Ford 9" Housing Bracket JIGS
- which tig machine
- Supercharger or weber side draft solidworks drawings….anybody have ‘em?
- bending hoops
- 4130 Chromoly Tubing
- Which tools do I need to start on my fab projects?
- Toyota Supra engine into 1989 Transam?
- What medium duty box and pan brake to get?
- The Official Tube Bending Thread
- Serpentine setup
- Engine Covers
- Arc welder help.
- Body mounting solid vs bushed
- welding on fuel tank
- Will the mini tub install process harm exterior paint?
- 14ga frame horns for engine
- weld or rivet?
- burn through?
- What size square tubing for building a frame?
- Splined Shafts
- My first header.
- Building a pro-touring crew cab truck
- Sheet metal brake
- critque these welds please
- School question
- Looking for direction...
- 66 Chevelle Body Cart Questions
- Air Ducts
- The Official Tube Notching Thread
- minimizing distortion
- A-Body Frame
- Will this work or stress the body too much?
- Stainless welded seam tubing........
- pot metal and sheet metal
- Cool U weld it brackets and parts
- Noob question -- 2-1/16" holes in .25" aluminum?
- CAD freeware?
- Motor and transmission mounts
- Roll bar connection
- Template for Caliper Adapter Bracket
- square or round tubing strength after damage
- tig welding stainless to mild steel
- how to lay out an ellispe
- Custom CNC / Fab guys
- Annealing Cold rolled 16g steel
- Suitable material for a coolant reservoir?
- Alibre Design Standard
- Mass Welding & Surface Conditioning
- wishbone advice
- car rotisserie / spit
- Recirculating air filtration
- I need a welder recommendation
- anyone make a homemade tube bending die?
- Glovebox wiper install pics
- Welding steel under tension?????
- 1st Gen F-Body Body Cart
- Adding "fish plates" to a welded joint?
- MIG beginner and I need advice
- Well been looking for small tig,,,,
- My new battery tray
- henrob 2000
- Metal type and thickness for bracing?
- Who here does water jet cutting???
- who can make some brackets for me?
- Tig conversion kit?
- Bracket Spacer needed.. aluminum or steel
- Houston (area) mill work needed
- Neat Tube Notching pattern creater - free
- Crossmember Fabrication
- Autocad headers help
- 1st Gen Custom Valance
- Brake caliper bracket design/fabrication
- need pricing assistence on fab work
- fuel cell fabrication tips
- Rod end experts -- got a question
- AutoCad 3d question (using inventor 2010)
- Multiplaz, plasma kutter and welder, anyone?
- connecting tubes at a low angle
- Working with Copper
- eMachineShop.com
- magnetic materials
- Rivet nut / nut insert tools
- welding frame-how to splice
- CNC aluminum job questions
- Cold Air intake from SLS material
- Using 4130 for sheet metal repairs
- using the correct polarity when welding
- 67 Mustang Fender Flaring Question
- Welding mild steel and stainless
- Tips for removing the color from welded stainless steel
- How much tube for a full roll cage?
- Millermatic 180 or 211
- Anyone have access to a SLS machine ?
- Anyone on the board have access to a CNC & CNC mini Lath and Plastic?
- Steel Shape Charts w/ weights per ft
- JCG Wheel Stands
- Custom Hub Adaptor for Steering Wheel
- off topic help on repairing dented 7075 extruded section
- Laser or water jet work needed
- '69 rear bumper on a '67 Camaro......
- English Wheel Build
- Boxing a frame, questions?
- I need some dims from stock Chevrolet motor mount "clam shell" brackets.
- LS motor mount hole locations.
- watts link
- 1 3/4" chromoly thick wall
- fender rolling
- AutoCad Inventor help - Need to export/convert to DXF
- Yet another AutoCad Inventor Question...
- Modeling frame rails in autocad inventor?
- 3in. Aluminum tubing
- Help getting started with a bead roller.
- BendTech?
- proper way to build custom gauge housing
- Looking for DXF image
- Headers
- Fabbing alt bracket and guage panel?
- Lookin for good fab videos or books or website
- aluminum thickness for spoiler
- Welding Mods to GM A-body Frame
- look what im making!!
- Upper Control Arm Bushing Sleeves
- drilling axles, rotors or drums for different lug pattern
- Thermo Dynamics Cutmaster 38. Good/bad...?
- Rotisserie tube size and thickness
- Tube Chassis for Protouring Cuda
- Preferred weld thru primer
- shops/people in knoxville
- elongating a spoiler?
- Welders and Fabricators, is it a taught skill or something you can learn alone?
- welding stainless with a mig
- Chrome-moly vs mild steel for cage
- need some advice on billet strength for serpentine setup
- where to get cool hole punching tool
- Carbon fiber shatter?
- Zen and the art of tube notching...
- Cutting sheet metal
- Firewall Steel question
- CNC Machinists/CAD designers, I need advice on creating my invention.
- Rotted Body Mount
- Filling Seams with silicon bronze
- covertible top and DSE tubs!
- 2x3 frame thickness question
- Anyone with a lathe willing to make something for me?
- CNC Machining?
- FUSE welding from Vibrant ???
- Sheet aluminum for polishing
- Custom fuel tank with VaporWorx gear
- CNC Tube bending
- welding on threaded aluminum
- CAD/Design Help Requested for Tube Chassis Please!
- Anyone use BobCAD/CAM?
- Custom Intake wanted
- New blog post about using shock simulators instead of real shocks
- Before I spend $60 on ebay, anyone capable of making a straight LS thermostat housing
- Mig wire size for Quadralink install
- TIG welding cast aluminum
- Metal Shaping @ 2012 Santa Cruz Metal Meet
- Machine shop hours....
- Need a Fab guy. TKO 600 adapter
- Vespel
- The art of purge welding( back purging)
- Ideas for my engine bay cover
- Chassis Jig
- Ls2 ac/alt bracket help
- bumpers
- Montana
- Need a good heat shield material
- Welding table construction advice needed
- How about a Tig welding aluminum discussion?
- could someone convert a stlprt (soldiworks) file to autocad for me?
- Muggy Weld ??
- Fuel tank construction
- baffles and sump for carb tank
- Chassis Jig
