View Full Version : Automatic Transmissions
Pages : 1 2 [3] 4 5
  1. Any C6 guys out there?
  2. I have a paddle shifter idea....
  3. G6 shifter for a 4L80E?
  4. Transmission Pan Magnets?
  5. 4L80E pan touching filter?
  6. Clearance issue?
  7. stall speed converter question
  8. Converter question for Road Racing
  9. Picking a transmimsion
  10. Parts supplier
  11. 4 L60E transmition
  12. 700r4 or th400
  13. Almost polished C6
  14. PADDLE SHIFT Automatic Driving Video, Part 1
  15. ideas needed for lower shield on 4l60e
  16. 2004R or TH350 with Gearvendor
  17. Lockup or Non-Lockup
  18. Plumbing cooling lines NPT vs. flare
  19. help with flywheel
  20. TCI Controller Differances
  21. 800HP and a 4l80e
  22. Decode a 4l80e
  23. TV Cable?
  24. good converter for 5.3 in 69 cutlass?
  25. 4l80e how much can it handle ?
  26. where to get late model tailhousing 4l60e
  27. How much effiency does 400 use
  28. Help Setting Up SGI-5 C
  29. Second gen manumatic
  30. TH350 second gear disengages under load
  31. 700R4 adjustable TV Cable Bracket
  32. TH400 crossmember
  33. 4L80e electronic connector?
  34. Manual Shifter for 4L80E
  35. T-400 lines
  36. Swap Vette T56 manual to an Automatic 4L60E
  37. th350 question "shifting"
  38. TH350 - broken case
  39. Anyone used the TCI paddle shifter?
  40. Used 700r4
  41. how to check what kind or converter i have??
  42. TH350 is puking all over everything...
  43. Lockup in a regular 350??
  44. L460 Trans to Autometer Speedo
  45. TF 727 Shifting Issues
  46. do i need professional help?
  47. 4L80E vibration
  48. Installing my Kilduff ratchet shifter
  49. 4L80E or Gear Vendors ???
  50. best way to seal transmission
  51. Help me design an all electronic 4R70W drive train?
  52. 200-4R transmission troubles.
  53. 4L60E 2/3 shift
  54. 6L90 and LS
  55. Daily driver-1999 Venture engine knocking and tranny slipping
  56. How long does it take to rebuild a 4l60e?
  57. 4L80E torque lockup problem
  58. need opinions on which converter and controller
  59. 4l60e to a sbc
  60. ? with gear vender in 2nd gen bird
  61. 4L60E differences
  62. 4L60E in GM A Body?????
  63. passing gear on th400
  64. 4L80-E tailhousing question
  65. muncie
  66. powerglide to 350 flywheel questions
  67. 4l60 or 4l80 manual shift trans?
  68. Ebay trannies
  69. mega shifter
  70. ? convertor flash/stall
  71. TH400 not shifting 2-3 at WOT
  72. what type of tranny cooler are you running
  73. 4L80E, Tuning Help
  74. 700R4 rattle
  75. TH 350 No or very little reverse action.
  76. 700R4 shift points
  77. Shifter Install problem
  78. Interested in a paddle shifter
  79. Torque converter rattle??
  80. Choice of Auto trans for 750 ft.lbs FI BBC set-up
  81. Questions on a SFI plate for a L92/4L80e combination
  82. 700R4 help
  83. Maybe closed '4L80E, tuning help' a bit early?
  84. Another Gear Vendors question..
  85. TH350 feels mushy, havent driven in 5 years
  86. 4L60e feeling Soft
  87. TH400 speedo gear for bigger rims?
  88. shift kit and shift points change on TH400
  89. Dodge 46RE Accumulator Springs
  90. Transmissions suggestions please
  91. Paddle shifter
  92. Best place to gat a Quicktime SFI Bellhousing?
  93. Trans Cooler Thermostat
  94. Art Carr 700R4
  95. Edge Racing Converters
  96. 1st Gen Firebird (Camaro?) - Gear Vendors or 4L80E Fitment?
  97. Master Shift vs Retrotek Paddle Shifters
  98. transmission identification
  99. Who is using a Gear Vendors unit
  100. THM200/THM200C 3spd Tech
  101. th350 problems
  102. 68 firebird w/ 600+ hp whats the best way to go
  103. TH400 Location issues
  104. largest cam with factory converter
  105. ls1/th400 combo
  106. best trans controller
  107. 68 Camaro / 4L80E Help
  108. Wow fianally found a converter
  109. c6
  110. 82-92 Console Megashifter
  111. Looking for a 4 speed auto for a vintage Mustang
  112. c5 Corvette shifter in a Camaro
  113. how did you route your external cooler lines?
  114. 4L60E woes
  115. 700R4 into C10 ?'s
  116. What does "trans flush" mean?
  117. 4L80e install - Questions
  118. Turbo 400 Kickdown??
  119. 200-4r problem
  120. For thsoe who want to rebuild 4l80e/4l60e/ kits for sale I found
  121. looking for a 4L60 shifter.
  122. 4L80e shifter that looks modern?
  123. 4L60E Swap info needed... trouble with electrics
  124. cool shifters?
  125. 700-R4 Rebuild Manual
  126. 700r4 "myths"
  127. @001 Silverado Transmission swap Help!
  128. Does anyone know of an aftermarket controller for the 6HP26?
  129. Automatic for a 572 Hemi????
  130. TH425 adapter
  131. New Manual Tranny
  132. Trans Line differences?
  133. Chevy 4L60e Bad Vibration and No 3rd
  134. Rebuild 200-4r or rebuild 4l60e for LSx 5.3?
  135. 4L80E Transbrake is here!
  136. TH350 always in drive
  137. 4l60e dipstick
  138. 4L60? What do I need?
  139. brake switch / 4l60e
  140. HELP!! 4L80E Issues
  141. where to find a 289 bellhousing
  142. TH350 not shifting properly
  143. Converter too tight?
  144. Tci 6x
  145. 4L80e Scatter Shield?
  146. 4l80e questions in 67 camaro
  147. Transmission help
  148. Dakota Digital sensor?
  149. Can a Gen4/LSx ECM manual shift a 4L60e??
  150. LS motor + 700R4 flex plate part number
  151. GM 6LX0 series transmissions; Stand alone controllers yet?
  152. Swapping speedo gear??
  153. Need Help, Which Trans?
  154. transmission lines
  155. My 4l80e build!
  156. 700R4 wont lock up
  157. cracked flexplate
  158. Neutral safety on 4L80 retrofit
  159. going back to auto and paddle shift, need advice
  160. dipstick issues
  161. 4l80e issues
  162. streetfytr68, ? Your Paddles & 6L80E
  163. 4l60e output shaft?
  164. GM Performance Parts Transmission Controller PN12497316
  165. TH-400 name of "flexplate protection"
  166. TH350 vacuum line
  167. TH350 OEM Pan with drain - where to get?
  168. 200-4r help
  169. Protecting hose from heat?
  170. TH200R4 with Hurst Dual Gate shifter
  171. Sitting 700r4
  172. Anyone looking for an F body 700R4, I suggest G-Force.
  173. transmission cooling auxiliary or stand alone
  174. When is my 700r4 going to explode?
  175. Diagnosis and advice on a 4L60E
  176. 4L65E shift issues
  177. 400 or 700 tansmission
  178. Gear Vendor and MSD ?
  179. grinding problem
  180. manual or auto?
  181. TH400 tail shaft housings ??
  182. '66 Mustang - what electronic auto will fit ?
  183. 4L80E shifter and crossmember questions
  184. how to repair indicator cable??
  185. TH400 question
  186. what are my options...
  187. 1965 Chevelle 2door Wagon trans
  188. 765 from bowtie overdrive
  189. TCI profile pool
  190. 4l80e
  191. 700r4 first gen trans tunnel
  192. B&M kit killed my trans.
  193. ?? for anyone who has built their own transmission?
  194. Can't find a dust cover
  195. Trans crossmember
  196. Transmission options for LS motors, any advice?
  197. Where to get 700r4
  198. L92 460RWHP / 6L80 / 285-305 18 tire / = what converter for the street?
  199. 4l80e TCI controller
  200. Can I use an awd 4l70
  201. best for a 400 sbc?
  202. What are advantages of larger torque converter?
  203. 6l80/6l90 TCM location
  204. wire off of speedometer drive gear
  205. 4 knob hurst shifter
  206. TH400 Speedo Question
  207. 72 chevelle w ls2 need transmission help.....
  208. 4l60e help
  209. Transmission question
  210. Hurst Dual gate w/ a 4 speed?
  211. Transmission Identification
  212. speedometer calibrating
  213. suggestions on tranny choice
  214. th350 question
  215. 4L60E engine braking?
  216. Does GM make a version of their 6L80E/6L90E for European OEMs
  217. 6L80 Question...ANYone using it?
  218. Aux. Filter for TH400 ????
  219. 2001 Civic Trans. Problems
  220. crossmember for 4L80e: what angle should I have
  221. What crossmember to use?
  222. TH400 lack of pressure, wont go.
  223. Found used gear vendors unit for sale. Is it worth buying with no wiring?
  224. 4T60-E slip from 1st to 2nd gear
  225. who sells paddle shifting automatics
  226. Will it fit tko 600 Chevelle to 67 Camaro?
  227. Submersable hose???
  228. which auto - or perhaps a stick
  229. C4 won't stay in park after TCI MVB swap
  230. Ls7 with TH400 trans
  231. 6L80E Anyone?
  232. Gm 4L80e old style connector and wiring color code
  233. 6L90e in a 67' Camaro with a L92 --will it fit
  234. Paddle shifter question
  235. Help..Im about to pull my tranny out!
  236. 300, th400, or 700r4
  237. Who makes the best stand alone controller?
  238. 4l80e help!
  239. HELP!! 4l80e problems
  240. 4l80 vs 4l65
  241. Paddle shifter, 4l80e, pushbutton shifter/touchscreen?
  242. Auto Trans for Ford 4.6
  243. Is there a difference in 4l60 years?
  244. TH400 cooler suggestions
  245. 4l65 trans in a 1st gen camaro ?with a ls1
  246. Saw this on craigalist.
  247. 200R4 no 2nd gear ???
  248. Shallow pan for a 6L90e
  249. Hurst pistol grip 3 speed converting to 4 speed????
  250. T-42 connector controller
