View Full Version : Manual Transmissions
Pages :
1
2
3
4
5
6
7
8
9]
10
11
- GForce T5 vs TKO 600
- need help finding a bearing
- Need opinions about T56 Mag. stick and boot
- t56 1 piece countershaft question.
- Adapter help needed
- t56 behind a 454
- t56 flywheel???
- Need T-56 shift rail measurement
- keep my T56 or get new? help
- CTS-V Bellhousing?
- Clutch Fork Broke
- bellhousing help
- Older TKO500 need some advice
- ???? Tremec 3550 a good trans for my '68 El Camino?
- flywheel and clutch
- Recommendation for metal clutch alignment tool?
- T56, Quicktime 8020, and GM LSA/ZL1 clutch?
- Muncie M22 mated to a LSX questions!!!
- Bellhousing Alignment 101
- LT1 T56 Clutch Problems
- Fe t56
- pontiac 461/ t56 magnum hydraulic clutch 69 firebird
- T56 clutch master bracket for GM A body
- 69 Camaro Big Block/T56 swap. Pedals, Details, Questions?
- 4l60e to TKO-600
- Best Street/Track Clutch for M21 Mechanical Setup
- Liberty Gears TKO feedback
- t56 magnum crossmember
- Richmond 6 speed i 1968 Camaro.. help!!
- auto to manual he
- T-56 LT1 Life Span
- T-56 LT1 Rebuild
- Corvette pilot bushing wont fit
- Quicktime/pontiac/tko?
- t56 magnum oil
- DSE Frame T56 Magnum Crossmember
- LT1 T56 Question
- T56 shifter relocation.
- tko-600 quicktime bell starter issue
- Anyone Using Wilwood Pedals w/ Mechanical Clutch?
- Bellhousing suggestion
- C4 Corvette VSS issues
- QuickTime bellhousing to ls3 how to align
- LGT-700 Manual Transmission - Holy Grail?
- Ideas for T5 Shifter Boot
- 1st gen t56 shifter placement help with console
- clutch alinement tool
- 68 Firebird 5.3 ls t5 swap
- QuickTime to T56 bolts??
- T56 questions
- hydraulic clutch kit install
- 1986 Elcamino -T56 Magnum 6 speed- time to order parts
- T56 question
- 90* swivel fitting on clutch line
- Used Clutches
- tko600 install without kit
- mini starter motor
- Clutch pedal options
- What slave are you using with magnum and quicktime?
- GM T56 slave cylinder issue with twin plate clutch.
- gear vendors od
- bugs in tko600
- Silver Sport Transmissions or American Powertrain?
- LS 1/3 vs LS2/7 style flywheel and clutch
- T56 magnum fluid choice?
- storing my t56 magnum
- Want to install LGT700 or T56 in my 67. Looking for a kit or parts
- SBC / LS with a Ford T56?
- $1,000,000 question!
- 1st Gen Firebird Auto to Manual Swap Questions
- Bowler Shifter Boot
- T56 magnum Ratio selection and rear gearing
- LS bellhousing/scattershield confusion...
- using 3rd gen clutch hydralic clutch
- Flywheel torquing 3 step...
- Hurst Drivelines
- balancing a clutch
- APT X-Factor Cross-Member Review on Sec Gen DSE Frame
- tr6060 safety concern
- Looking for a T56 rebuilder in No. Cal
- clutch master cylinder for ls7 to t56?
- 6 speed trans question
- Help with 1st Gen LS Camaro and Tremec-pilot bushing problems!!!
- Driveability
- LT T56 to LS T56
- Manual Transmission Selection.
- Whats a good price for an LT1 T56 ?
- fbody t56 in a 70 chevelle with factory console question
- Amerucan Powertrain hydraulic clutch firewall mounting problem
- hydraulic clutch for 2nd gen fbody and TKO 600
- LGT-700 Drive Shaft Seal Part Number or Application
- T56 master cylinder setup????
- TKO 500/600 Reviews
- Ford Borg Warner T10
- 67 Firebird - TH350 to Tremec T56/TKO500/600
- ls9 to t56 quaestion
- wide or close ratio t56 magnum?
- LQ4 + TKO600 + longtube headers = throwout bearing question...
- MGW shifter question
- Clutch Recommendation
- Any real time high performance Feedback yet on the Legend 5 speed transmission
- Flywheel & Clutch....What are you using?
- Where to find small remote reservoir , clutch
- Help T-56 Hydraulic clutch
- T56 Magnum S1 sequential shifter opinions.
- which Hyd clutch setup should I use .
- D&D t56 or TR6060?? Which one is it?
- wilwood hydraulic clutch master bad leaking
- tko 600 carbon fiber synchros upgrade
- clutch for a 572 ci 745 hp BBC in a 64 chevelle
- Looking for reliable shop for manual transmission work
- Tr6060 t56 magnum hybrid flywheel and clutch
- T-56 Early Camaro Trans Swap
- School me on clutch hydraulics for my configuration
- T56 Magnum. What ratios?
- Lost bleeder fitting
- bleeding t56
- Viper T56 in my 67 Cougar
- LT1 6 speed behind a Pontiac 400?
- T-56 clutch problems.......
- 69 Camaro Th350 to Muncie
- T56 Swap parts needed list for A Body (1972 Pontiac Lemans)
- instilling a lt1 t56 in a 70'monte????
- T56 Magnum Wiring Pigtail Kit by Schwartz Performance
- t56 White Lightning Shifter
- t56 front cover
- using a Corvette transaxle with an open drive shaft?
- Clutch Identification
- Super T10 Behind an 8.1L Vortec 496
- Hurst Driveline Conversions promotion
- TKO-600,LGT-700,Mcleod 5-speed comparison
- t56 magnum/69 camaro - which crossmember and shifter?
- Tremec Price Increase, Jan 1 2016
- My McCleod Throwout Bearing is leaking BAD what other would you use to replace?
- Gto T56 shifter location
- American powertrain clutch m/c bracket
- T56 magnum trans mount?
- GM Quick Connect Fitting - Does anyone make an adapter?
- 2nd Gen -DSE sub-Tremec-Quicktime Quesiton
- 4spd trans clutch...stock vs. spherical joint z-bar vs. hydraulic
- t56 magnum noise when no load on drivetrain
- 58-64 impala T-56 Question
- Ask an HDC Tech: the Transmission Conversion Q&A
- Clutch pushrod angle?
- Found the trans axle solution for the mid engine car I'll probably never build
- TR6060 in 67 Camaro Sugg?
- C5 T56 to Mark IV BBC
- Hurst Driveline Conversions-NEW PRODUCT RELEASES-March 1, 2016
- would this fit an LT1?
- Gear Vendor Overdrive for Pro Touring
- line popping out of hydraulic throwout bearing....
- 2017 ZL1 announced... single overdrive 6 spd. What?
- Tick Master in 69 Camaro with T56
- 1967-81 Camaro Tremec TKO Overdrive Transmission Kit Installation Notes
- Hydraulic Pedal Ratio / F-Body Firewall bracket
- T56 magnum in 2nd Gen with DSE subframe
- T56 Reverse Lockout - Options?
- Hydraulic Clutch set up advice / help.
- Whos done a 2nd Gen F-body Auto to Manual Swap
- 1956-62 Corvette HDC Tremec TKO Overdrive Transmission Kit Installation
- auto to manual swap
- Clutch pedal loss at high RPM
- Who makes a good GM A body Hydraulic throw out bearing kit.
- which t56 hydraulics
- Terrible vibration after clutch swap
- 74 4 speed Firebird to T56 6 speed question...
- Install Overview: Hurst Driveline Conversions Tremec TKO Kit for 67-76 Mopar A-Body
- 600 Reasons to Step Up to a Tremec TKO or T-56 Magnum Transmission this Summer
- T-56 magnum /Tr6060 cts-v pump
- Hyd clutch issues.
- Need a clutch
- T56 input shaft play??
- Tilton clutch master cylinder bracket problem/question
- Help win converting 68 f body to manual.
- Life sucks...
- t56 swap
- I was a fool for owning a ......
- t56 help
- Bowler Performance Transmission Internal Front Pump Install, - T56 Magnum only
- Clutch alignment tool for FE ford/tko/T56?
- LT1 T56 and a Gen 1 SBC questions
- TKO600 or T-56 Magnum for LT4 Supercharged 69 Camaro
- Quicktime Vs aluminum bellhousing
- APT Science Friction Clutch
- LS T-56 to SBC - what is the best installation?
- Any American Powertrain Clutch owners out their? Review please
- Richmond 6 speed with lq4, which flywheel is best?
- white lightning shifter
- T56 not shifting to 4th
- Viper T56
- Rebuiult T56 - no 1st or 2nd (help!!)
- Are you running a Tremec TKO-500, TKO-600, or T-56?
- LT1 L83 with T56
- Ls to tko600 throwout bearing
- Fall into Gear
- Crossmember
- LS T56 onto 455 (1972 Skylark)?
- Rear Gear Recommendation For Viper T56
- F body LS T56 - Mid Shifter Options
- custom drive shaft/propshaft help please
- LSA to LS1 Style T56
- T56 alignment question
- American Powertrain X-Factor
- T-56 Magnum leak??
- Flywheel dowel
- 66 a body hydraulic clutch mount
- T56 Magnum - American Powertrain Reverse Lockout Module
- Best T56 Magnum Hydraulic System and Mount?
- T56 tunnel conversion from bowler.
- Ask a Hurst Driveline Conversions Tech: Tremec Overdrive Transmission Resource Thread
- Hurst Driveline Conversions: '78-'88 GM G-Body 6-Speed Conversion Kits
- LS7 clutch kit for my LS3 480 Aluminum Flywheel or no ??
- Twist Machine shifter
- T56 behind BBC with Mechanical Linkage HELP
- Ice man transmission cross member
- Need Help rebuilding a T56. GTO main shaft, 2001 c5 will be used as donor trans.
- Broke my Super T-10 4 speed, how easily can I upgrade to 5spd or T56?
- 4l60e conversion to TR6060
- LS7 clutch and flywheel on an LQ4 with a TKO600
- Trans crossmwmber for TCI subframe
- Thanks McLeod !
- Bellhousing alignment
- Bowler vs. Hurst vs. American Powertrain?
- Hydraulic vs. mechanical clutch for T56
- Hurst Driveline Conversions Crossmember Kits for 64-66 Mustang w/AOD or Tremec T5
- What Shifter/Tranny Do I have? STIFF SPRINGS!
- Dropping a T-56 into a 69 F-Body
- First T56 Rebuild - Is my Countershaft OK (PICs Included)?
- Offset shifter
- LS T56 BBC stock bell housing and linkage 70 Chevelle console
- LT1 / T56 vs Tremic Magnum Shift differences
- ? size flywheel need advice
- Ram 2555 Aluminum Flywheel reviews please
- Making Room for a Tremec Transmission
- Leaking TKO 600
- T56 5/6 Synchro Slider Direction
- T56 parts list. Will it hold up?
- Should I replace this blocker ring that I dropped?
- Hydraulic clutch master bracket
- Fresh T56 Build - Stuck in Neutral
- Is it possible to mate a 2nd Gen Viper T-56 to a TPI L98 SBC?
- Speedo not reading correctly... vss issue?
- Rear of trans is leaking badly
- Mopar to TKO Pilot Bearing
- 69 Muncie clutch adjustment
- tr6060 reverse solenoid
- Problems with my Hydraulic Twin Disc/Tilton and Wilwood set up with TKO600, stiff
- c2 Corvette Hydraulic clutch
- Problems bleeding clutch t56 magnum
- gear ratio question
