View Full Version : Manual Transmissions
Pages :
1
2
3
4
5
6
7
8]
9
10
11
- t45rs pics
- Borg Warner t5 Issue with BBC.
- Different T56 Clutch Line Quick Disconnects?
- Did I F up my clutch?
- Best Way to attach T56 Master Cyl to Pedal?
- Quicktime RM-6023PB bellhousing/LS1 T56
- tko crossmember wont fit! what cross member can I use??
- Mustang T-5 question
- T56 shifter leaking.
- New Tremec (TKO600) won't go into neutral... ??
- Calling all American Powertrain White Lightning Shifter Users
- How to attach hydraulic lines on throwout bearing? (new install 69 Cam)
- TKO to T56 Crossmember
- T56 tranny mount for 1975 Trans Am
- C5 Trans into a Porsche 928
- Master cylinder plumbing
- Understanding the T56
- tko 600 vs T56
- TR6060 Transmission mount
- T56 Magnum Shifter Fitment
- intermittent hard clutch
- Attempting to rebuild a T56, can't get the counter shaft extension out
- T56 to a Pontiac 400
- Tko 600
- looking to convert to 5 speed.
- Need More Gears...
- where to get a a body tko crossmember?/
- Clutch problems bad
- Tr-6060
- Ctsv t56 in 1969 mustang
- TKO600 Hydraulic throw out bearing options
- tko trans
- Keisler RS600 Noise
- clutch for a tko
- pic of a tko shifter in a 70's chevelle or monte with console.
- Modified T-56 Magnum questions?
- Calling All 2nd Gen Camaro Owners
- T56 Hydraulics Issue
- T56 magnum noise
- American Powertrain T56 SBC to LS swap
- ??? about what bellhousing to use with mcLeod Street Twin Clutch...
- Clutch brand? Mcleod or RAM Dual disc
- 5 Speed t3550 trans in 71 Camaro question?
- Shift information on the T56 Magnum anyone with 7000+ RPM shift points running one?
- Any clue if you can use an automatic computer with the t56
- Can I rebuild/upgrade my own T56??
- Auto to Manual on a 67 Camaro
- t56 swap
- need T56 Magnum Input Shaft
- tremec t56 magnum 6 speed
- Clutch help!!!!
- Anyone have experience with buying a T56 Magnum from Summit?
- Clutch Pedal Engineering - T56 Swapped 3rd gen
- Hydraulic Clutch MC Leaking at 200 miles!
- Clutch will not disengage
- T56 Magnum speedo gears?
- 68 camaro SBC Muncie to TKO600
- Help me spend my $$ Pontiac/T56
- Will late 70's eaarly 80's peddal assy work in 69?
- Adjustable Shift Handle Install Video
- clutch change gone wrong
- T-56 questions...
- Coyote with a t-45 clutch question
- 68 Camaro, Speed Tech frt clip, Speed Tech Torque arm rear, Bbc, Thinking of a T56?
- T56 Leak
- Locked up 5-speed
- Hydraulic clutch set up for a Super T10
- Which 5 or 6 speed?
- 5 speed for a factory manual 69 Impala?
- Clutch pedal travel limiter
- 4 Speed Manaul for 600 lbs torque Engine
- DNE2 - tired of rowing a boat. Can I shorten the throw?
- t56 will not install on sbc help!
- TKO 600 crossmember 69 Camaro
- T-56 shifter compatability question
- Clutch Help
- tko 600 wont go into reverse
- AAW classic update / TKO speed sensor
- T-56 Magnum noise at freeway speed - HELP!!
- T56 meant for mustang in a first gen camaro?
- R.A.M. Hydraulic clutch issues help? Tko 600
- T56 wide ratio w/.80 5th and .65 6th OD gears?
- Lakewood Bellhousing Muncie Input Shaft to short
- Tremec 5-speed from Auto, and SBC..ADVICE?
- LT1 T-56 in a 2nd gen T/A behind a 455
- T56 Hole Question
- clutch/tranny install...Please help!
- How to remove reverse gear ignition lockout on GM manual?
- American Powertrain Tremec Issues Thoughts?
- Options for Big Power 6 Spd Transmissions- T56 Magnum, TR6060, V160, Etc. Discussion
- ford toploader 3 speed in 69 olds cutlass help with clutch choice
- LS/T56 Throwout Bearing Carrier
- want a new shift handle to replace the Keisler type
- Confused Straight shifter or Bent
- T56 magnum pigtail part numbers??
- T56 Magnum
- Any recommendations?
- T56 gets stuck in 3rd
- What’s the lowdown on the 6060 trans that comes on the new Camaros?
- Fitment of T 56 in a third gen nova and a SBC.
- LS1 GTO slave cylinder to -4AN fitting
- Keisler Engineering - T56 Magnum Problem
- ZR-1 Clutch
- new T56 install : 5th gear issue
- need help...
- NASCAR 4 speeds in a street car. What kind of longevity can I expect?
- t 56 swap from m 21?
- What's a good shifter bezel to buy
- tr6060 and a 5.3/6.0
- 67 c10
- T56 Shifter location for 1st Gen Camaro
- T-56 or 6L90 w/ paddle shift
- T56 Magnum VSS Question
- Preferred clutch weight
- Bleeding T56 Clutch??
- Measuring bearing clearance on T56 Magnum?
- t56 horsepower ?
- Replacement Speedo Cable - T56 into '69 Camaro
- What transmission yoke for T56 Magnum?
- 3 on a tree shifter arm
- American Powertrain's New Universal Crossmember
- Clutch Problems on a TKO600 swap
- T56 oil capacity?
- Trouble mounting T56 mag to stock bell housing behind LS2
- T56 Magnum reverse lock out solenoid plug
- A transmission Tale - help
- Throw out bearing t-56
- T56 Magnum Reverse Lockout Solenoid polarity?
- Identifying connections on Magnum T56
- What clutch to use with ZF 6 speed in 67 camaro 327
- Clutch pedal won't come back up
- Monster/TKO shifting problem
- T-56 Crossmember 69 Camaro
- whats the best for a comfortable drive and race b&m?
- Bell housing t56
- tko does not like to shift into second gear!
- Under dash clutch/brake pedal assemblies
- olds 5 speed ?
- ZF6 trans mount?
- Tremec T-56 Magnum Shifter
- Trouble with a vendor... need help.
- T56 w/ Scattershield
- 67 Camaro Auto to Manual
- Is this a LS1 T56?
- Body Mount Bushing with T56 Magnum clearence on 69 Camaro
- Need help with hydraulic clutch master cylinder
- Bleeding done, what else could be a reason?
- Source of Keisler Slave
- Pilot bearing for TKO/LS1/QuickTime bell
- 2013 coyote 9 bolt pressure plate
- APT hydraulic clutch DOT??
- Keisler hydraulic clutch brake fluid question
- T56 which one?
- A great alternative to hacking up your tunnel
- T56 Vette trans
- Convert Console to Powerglide configuration with T56?
- SPEC clutchs?
- T-56 Magnum shifter question
- my t56 magnum with 600 miles on it is broken
- transmission Q
- Is this "normal"?
- Dual Disc Clutch
- Tr6060 swap
- Tko 600 ???
- TR6060 Case Design Question
- 6 speed from a 5th Gen Camaro
- T56 fluid
- How to: T56 Magnum Quicktime bellhousing dial-in
- T56 Magnum Questions
- T56 Magnum / LSX376 / LS7 clutch issue I need assistance please.
- Could use some help.... T56 Magnum tunnel clearance and angle mock-up w/ no engine
- 5 Speed 1:1 or 5/6 speed OD
- Which is a better Neutral Safety Switch set up for TKO?
- 67-68 muncie shifter on 1970 muncie Trans
- 5 or 6-speed overdrive tranny in 2nd Gen Camaro w/o cutting floor?
- T56
- TKO to a LS
- Question about Pinion Angle on Camaro
- Is a Drive Shaft Loop Needed in a Street Car?
- Which shifter to use?
- Hurst Shifter...
- Auto Console in 2nd Gen F Body TKO Conversion
- T-56 hydraulic clutch- where to buy
- Hydraulic master cylinder setup for first gen Camaro
- Which trans for track car?
- T56 lower shift boot/cover
- Easiest way to install 6sp to a BBC?
- Tko 600 hp
- Quaife Six Speed
- T-56, Where to buy?
- Second gen camaro t56 magnum swap kit?
- Hurst Driveline Parts
- Richmond 4+1...will it stand up to auto X events? Is anyone running one?
- 2002 camaro t56 max Hp and torque?
- T-56 +LS9 - what clutch kit?
- Questions on T56 Mag. before I pull the trigger.
- T56 Magnum Tremec shifter question
- How to convert a C5 Corvette T56 to a Fbody one
- Factory 67 console with t56 in 1st gen
- T56 Remote bleeder
- 85 camaro z28 5-spd transmission
- TKO600 or T56 Vendors?
- American Powertrain ISO-X Transmission Mount
- 1st gen camaro T56 cross member flex
- BBC T-10 to T-56 CONVERSION
- 68 firebird automatic to manual conversion
- T56 Magnum VSS question
- 68 camaro ls6 zo6 motor and was 4l60 e now going t56 need info
- 65 mustang with lsx and tr6060
- pontiac 461 behind a t56 magnum
- Legend LGT-700 Shifter Locations Under Development
- Keisler TKO-600 Trans Modified for GM A-body fit in a 2nd gen F - Body?
- C4 corvette zf6 install help
- TKO 600 .64 or .82 for 68' GTO build?
- Is this correct
- Transmission Swap
- 69 Camaro T56 Help
- Where to buy T56?
- T56 hydraulic TO bearing hose fittings?
- What T56 Magnum yoke?
- Help id part
- speed tech crossmember question/HELP
- Nearly New T-56 Mag - Noise above 70mph
- Gto t56 shifter to f-body shifter
- Help - Ram Clutch
- Viper T56
- T-56 in LS 67 El Camino
- Used t56 on Craigslist
- American powertrain science friction clutch
- McLeod hyd clutch conversion for 69 Camaro ls conversion
- lt1 t56 and sbc starter/flywheel question
- possible to install T56 TO bearing bleeder hose with trans in car?
- Pro's & Con's of 5 speed vs. 6 speed ?
- Studs not long enough for Hurst Driveline hydraulic clutch bracket?
- T56 vs tko vs magnum
- LT1 style clutch install issue
- '72 Nova needs engine/trans
- T-56 Magnum Issues Continue
- Help Needed with Throwout Bearing
- viper t56?
- Transmission help
- 15200 lakewood ford top loader bellhousing
- T56 sbc swap
- t56-sbc pressure plate bolt size?
- T-56 Slave Bleed Questions
- Difference between a Long hb-1000r vs ht-4000?
- high speed vibration and pedal issues
- T-56 Magnum Mock Up Transmission?
- good clutch setup for t56 magnum swap
- Throw out bearing?
