View Full Version : Manual Transmissions
Pages : 1 2 3 4 5 6 [7] 8 9 10 11
  1. T56 not shifting??!!
  2. Anyone here used LS1-T56 Hydraulic Clutch Linkage on a SBC/M20?
  3. Auto vs. Manual Tranny Predicament
  4. Bleeding the slave cylinder
  5. T-56 in a Pontiac?
  6. Will a TKO600 from 68 Nova fit 70 Duster
  7. Please help 69 Camaro turbo 350 change to Muncie driveshaft length same?
  8. McLeod 5 speed
  9. Time for an upgrade!
  10. hydamax hydraulic clutch set up from american powertrain
  11. t56 hydraulic throwout bearing heights
  12. LUK clutch kit? Are they any good?
  13. Borg-Warner T5 Transmission in a 69 camaro???
  14. T56 first gear grind
  15. TKO600: keep it or sell it?
  16. T5 WC transmission from 96 Camaro V6 swap to 69 Camaro
  17. ZF skip shift question
  18. T56 Hard to shift 3,4 at high speed ,RPM, Vibrates
  19. Will a '95 Camaro T56 6-speed manual transmission fit in a 1969 Chevelle?
  20. Hydraulic clutch line ruptured
  21. Used T56 vs New RS5/600
  22. Is a Tex Racing T101 Ok for Some Street Use?
  23. classic mustang T5 swap
  24. 2010 camaro 6 speed
  25. Hydraulic Clutch Bleed valve
  26. setting up a clutch on a t56
  27. act clutch
  28. Muncie or Super T-10
  29. Automatic to manual?
  30. lt1 t56 in 68 camaro need help
  31. Gearing
  32. What would be a great Manual Trans then? Advice---
  33. Throwout bearing needed for LS Muncie swap
  34. Best place to buy a T-56 Magnum
  35. Best place to get T56 rebuilt?
  36. Recommendations for Hydraulic Clutch kit
  37. Trailblazer LS2 with T56 clutch setup? Which one?
  38. T-56 in first gen Camaro
  39. Throwout bearing getting noisy
  40. Camaro LS3 clutch on a Trailblazer LS2 & T56 magnum trans?
  41. A-body bench seat with a t56?
  42. TKO 600 help!!!
  43. reverse lockout solenoid
  44. z-bar
  45. Which tranny to run - TKO 600, T56 Magnum or RS 600?
  46. t56 pedal disengages high?
  47. TR6060 - flex converter removal??
  48. The gearbox.org
  49. M-21 Clutch / Flywheel Recommendations?
  50. Rs 400/500
  51. Help! Which transmission for my '69 Mustang?
  52. 3550/tko what fluids to run
  53. '69 tunnel cut for T56 mag
  54. Tko 600 not shifting
  55. Flywheel dowel pin question
  56. beefed up clutch needed????
  57. Chevelle trans
  58. fabbing a trans mount
  59. I need a 5 speed that will handle 700lbs of tq.
  60. t5 durability
  61. new rst grinding noise?????
  62. searching for a 5 or 6 speed to live behind my big block ford ...
  63. Need opinions on MC and Booster for T56 in a 67 Chevelle
  64. 71 Cutlass S pedal install How?
  65. Tranny shop in NJ?
  66. Adapter for LS T56 to Ford Modular Engine?
  67. Bellhousing runout
  68. T56 and TR 6060 bell housing the same?
  69. New- NEED HELP with LS1 T56 6 speed to 350/2piece rear main seal
  70. T56 Clutch pedal return spring needed?
  71. ZF Tranny as an option
  72. Piece together T56 parts or buy a kit?
  73. My "budget" T-56 Camaro Install
  74. T56 in a 2nd gen camaro
  75. What shifter are u using w/ t56 and no console? (68-72 GM A-body)
  76. 79' Camaro- Vibration in clutch pedal issue.
  77. T56 Install - Engine vibration
  78. Pilot bearing availablity
  79. 350turbo to t56
  80. T 56 what did it come out of??
  81. F body T5
  82. Trade my TKO-600 for the RS600?
  83. 66 Impala - I need help/ideas on my linkage issue
  84. Chevy Cobalt 5-speed trans question
  85. Need directrion on a new clutch set....
  86. Direct fit trans. for a 2nd gen 'bird?
  87. I need Muncie 4 spd help
  88. LS3 flywheel and clutch behind LS1?
  89. rs-600 perfect fit " not quite"
  90. Super T10, how many needle bearings?
  91. Changing 6th Gear
  92. Clutch linkage issue while at Ocean City...
  93. Hydraulic TO Bearing and clutch pedal travel Help...
  94. ford/mustang help, flywheel and bellhousing
  95. 4 Speed HELP
  96. corvette transmission between c5 and c6
  97. T56 hyd hose size
  98. T-56 Rebuild & Mechanical Speedo Conversion
  99. Quaife
  100. Saginaw good or bad
  101. t56 in second gen camaro
  102. T56 Install in a 66 El Camino
  103. T56 Magnum evaluation [long post]
  104. LS1 flywheel spacer/long pilot
  105. t56 extended bleeder
  106. ATS/Speedtech M/C bracket for 2nd gens?
  107. T56 swap trans mount tab relocation
  108. 1967 Camaro Small block T56 Swap Help
  109. What fitting on Keisler actuator
  110. Mcleod 8710-00 Bellhousing runout
  111. 04 gto t56 into a 69 camaro with a ls
  112. 06 T56 in a 69 Camaro with LS1
  113. LGT-700 5-Speed Manual Transmission
  114. Is there are way to align a stock stock LT1 Bellhousing?
  115. 6speed trans advice? for 69 camaro
  116. gforce transmission
  117. 66 Nova Hydraulic clutch install help needed
  118. t56 mag or tko 600
  119. Will a LS T56 Bellhousing mate up to a SBC perfectly?
  120. need help with tranny gear ratios
  121. Is 1/2 inch yoke clearence enough?
  122. T56 in 1965 Mustang Fastback
  123. Mustang to GM T56?
  124. SHould I run mechanical or hydraulic in my TKO600?
  125. t56 no 2nd,4th, or 5th help
  126. Help me make sense which T56 into a 1969 camaro with big block
  127. T56 slave cylinder install ?s from newbie; in middle of install & need counsel!
  128. Ideal pilot bearing enagement
  129. Clutch suggestions for LT1 T56
  130. saginaw 4 speed
  131. Help with TKO 600 and TO bearing
  132. 67 Firebird -t56 mods??
  133. T-56 Crossmember LS Swap
  134. Best shifter for A TKO 600
  135. T56 Magnum in a 1967 Camaro Convertible - Issues! HELP
  136. Brake & Clutch assemblies
  137. Ugh! NV3500 slave
  138. Muncie clutch fork issue?
  139. 6spd Tremec ?
  140. BMR Releases New Product: Transmission Conversion Crossmembers (TCC005, TCC030)
  141. Where to buy a new Muncie
  142. Need help identifying a clutch slave cylinder
  143. press plate - T/O bearing clearance issue
  144. Viper slave height???
  145. T56 Magnum Hydraulic release bearing
  146. t56 magnum gear ratio dilema
  147. American Powertrain 65-73 Mustang X-Factor Transmission cross member!
  148. t56 on a budget
  149. ls1 t-56 slave cylinder fittings options
  150. GTO 6 Speed mated to Small Block Chevy SBC in a 1957 Chevrolet
  151. Difference in Length of Input Shaft Tremec 2066 (GTO Tranny) VS T-56 from LS (F-body)
  152. Swap to flaceplated TKO 600??
  153. Where to find a LS T56 & How much
  154. LS1 T56 master cylinder to clutch pedal attachment
  155. Ls6 t56 magnum QuickTime 8020 bellhousing no match
  156. Easy questions regarding T56 & T56 Magnum...
  157. Question about Keisler hydraulic clutch with Hydroboost
  158. T56 Magnum leaking from shifter - HELP
  159. Clutch pedal STOP ?
  160. NOISY T-56... please help!
  161. Best shifter for t56 Magnum into a 69 Camaro
  162. T56 shifter handle options
  163. vibration with t56 at interstate speed
  164. American Auto Wire clutch switch problem sec gen camaro
  165. Trying to find out if t56 is LS or Lt1
  166. Pinion Angle '69 Camaro?
  167. keisler driveshaft
  168. Backordered T56???
  169. GM-TKO Conversion peices best place
  170. Camaro t5 Swap!!! Speedometer Help
  171. mopar 4spd + gear vendors vs hemi OD 4spd?
  172. T56, shifting into gears when motor off?
  173. Hydraulic TOB with Mcleod Soft-Lok clutch..
  174. T5Z Input shaft shimming
  175. TKO-600 Spicer (31-spline 1310 vs.1330) yoke part numbers ??
  176. Need help setting up my hydraulic clutch!
  177. GTO T-56 whats it worth?
  178. Input shaft bearing super t-10
  179. Hurst TKO600 Driveline install question?
  180. Auto to M20 possibly future t56
  181. TKO 600...where's the neutral safety switch and backup light switch?
  182. Keisler RS600 issue
  183. Best Price on a Magnum?
  184. T56 Magnum countershaft shimming? How important?
  185. Quicktime Bell for Viper T56 to LS?
  186. Time for a manual...opinions??
  187. bad vibration and noise tko600
  188. Rattling/tapping noise from TKO
  189. Who to get a T56 Magnum from?
  190. Tremec TKO600 in a 67 Camaro convertible, any fitment issues?
  191. TR6060 Questions - from Corvette
  192. KeislerJeff is back
  193. C6 shifter linkage operation
  194. Need a little help. very heavy pedal
  195. Buying a T56 Magnum from Summit Racing?
  196. Cooling Mods for T-56 Question.
  197. Auto to manual conversion 71 A body wagon? what clutch linkage to use?
  198. Shifter ID help
  199. Clutch Master Cylinder - Brand? From who?
  200. T56 shifting
  201. Advice please, TR6060 vs Magnum T56 vs standard T56?
  202. What gears you using with a close ratio T56 Magnum?
  203. Complete Hydro clutch kit? From who?
  204. clutch pedal setup for a g-body
  205. t56 trans from 1993 T/A. ID Tag ends 007. = 2.97 1st gear why no good for LS?
  206. Flexplate to Flywheel, 1986+ SBC
  207. Sbc to ford t5
  208. What Speedo cable length and routing for Tremec(TKO600)? (67 Camaro)
  209. Question about T56 Magnum Shifter Mechanism
  210. Borg Warner problems
  211. Floppy Transmission Crossmember
  212. X-Factor Crossmember Concern!
  213. Sec Gen Camaro Hydro Clutch...HELP!
  214. tko 600 install
  215. Keisler T-56 Magnum Surefit Kit
  216. T56 speedo to Racepak dash question
  217. T-56 or Super T-10 w/Gear Vendor OD
  218. T5 to LS3
  219. TKO electronic Speedometer connector.
  220. tko 600 owners
  221. Linkage on borg warner t-10
  222. McLeod Hydraulic Clutch
  223. T56 Magnum - vibration in 5th & 6th at highway, anyone else?
  224. Keisler RS600???
  225. Hydraulic Clutch getting soft - T56 Magnum - que?
  226. Where's the best place to purchase a t56 magnum
  227. 4 speed saginaw
  228. t56 from a 03 mustang cobra for BBC 69 Camaro
  229. Quicktime Run-out off....Normal?
  230. Clutch Master Cylinder--Waterproof Seal?
  231. Difference in clutch masters?
  232. Does anybody make thinner throwout bearings?
  233. hydaulic throw out bearings- Tilton? Macleod? Keisler?
  234. clutch dilemma - Need your 2 cents
  235. Cost of a 6 speed swap in 69 camaro?
  236. just wondering-manual trans swap 96 Z28
  237. t56 swap into a 69 gto shifter questions
  238. Keisler SS 700
  239. 4 speed help please
  240. T-56 into first gen F-body mount issues
  241. TKO 600 Crossmember Pic Needed
  242. How to identify Keisler RS600??
  243. bbc clutch on ls2
  244. Quick help needed on hydraulic clutch
  245. What is this?????
  246. 5 speed
  247. T56 Slave Connector, can you buy them alone?
  248. Auto to Manual. What does it take????
  249. TR-6060 VS T-56 Magnum...
  250. converting a auto 85 camaro to a manual
