View Full Version : Manual Transmissions
Pages :
1
2
3
4
5
6]
7
8
9
10
11
- T-56 Magnum ... mechanical speedo adapter?
- 5 speed behind a big block Mopar possible to do without "kit"?
- easy way to identify year of viper t56
- Need Help Removing Hydraulic Line From Slave
- 70 Chevelle (Tunnel for a Tremec 5 SPeed) who sells it?
- Muncie M21 Might sell??
- best hydraulic throwout bearing?
- TKO 600 rubber shift boot
- Anyone test the limits of a Richmond 4+1?
- TKO 600 auto to manual - hydraulic??
- have to decide by monday--would you reuse this clutch??
- t56 bellhousing
- Transmission swap questions / advice
- need a master cylinder!
- hydraulic release bearing for an LS-T56
- Photos of hydraulic clutch install?
- 67 fastback TKO 600 Howling noise
- Under Dash Clutch Master??
- strange grinding noise in T56
- sfi bell housing
- Clutch Recomendation for M-20 muncie w/ 400hp sbc?
- 1st Gen T56 shifter
- Need some T56 Yoke info
- t56 popping out of reverse....in pieces help
- T56 Reverse Lock out
- offset trans mount?
- what gears to use?
- T56 Magnum
- Flywheel for LSX 454 8 bolt crank
- Tko 600
- Will my Muncie hold up?
- Trying to get this m-20 in my camaro, Help!
- is this a bad clutch?
- Tko 600 Car Prep prior to painting 67 Camaro
- LT1 clutch kits
- ATS and DSE body mounts
- T-5 rebuild
- Will zo6 cluthch fit a ls1
- Surface Rust on Flywheel
- clutch master
- AMC 360 to WC T5 ???
- 1976 laguna
- Quick Disconnect Hydraulic Clutch Fitting?
- Trans in a convertable camaro
- Do I need to shorten the reservoir hose on stock t56 hydraulics?
- Clutch pedal too far from floor?
- Tremec....
- T56 Neutral Saftey Switch?
- BOP Engine with a fatory T56 (LT, LS, Viper) Anyone Done it?
- Budget ls1 t56 to sbc adaptation
- TKO offset shifter for 68 camaro
- t-56
- SPEEDO Sending unit! Please help..
- Ever seen a bellhousing like this?
- T56 in a 1st Gen Camaro
- Keisler T56 magnum crossmember
- Speedo DRIVE GEAR ON TOPLOADER PLEASE HELP!
- bell housing alignment question
- MGW Shifters
- T56 Magnum choice
- 69 camaro Shifter bracket
- TKO600 Price
- SBC 400 Flywheel swap out of balance?
- TKO-600 Exploded View needed
- C4 vette ZF tranny on 74 NOVA
- T-56 retro-fit Stand alone harness
- T56 with 2:29 First Gear
- Muncie experts
- T56 question
- Clutch fork hitting firewall! Help!!!
- LT-1 T56 to LS1 T56 conversion
- What kind of clutch, bell housing, throwout bearing do I need?
- TKO500 speedo adapter-where to get one?
- clutch and flywheel compatability question
- Help!! Need to go to Hydraulic Clutch
- new tremec clutchless shift 5 speed / 6 speed
- t5 help
- Lakewood Bellhousing Setup
- Synchromesh?!?!?!?
- LS 6.0/TKO ?'s
- Flywheel for LSx swaps
- ATS LS converion plates and T56
- 69 camaro crossmember
- transmission options
- gear options
- Question about driving with a GForce T101 G101 GF4a
- Do I really need to replace my clutch?
- which trans??
- TKO midshifters?
- tko no floor clearance
- Plastic mock up
- 1969 Camaro Clutch Return Spring Mounting
- Tranzilla T56
- which t56- magnum or transzilla?
- TKO pops out of gear
- T-56 or 700r4?
- t5 question
- T56 vs Richmond ROD
- Chattering Clutch
- LT1 T56 clutch retrofit 67 to 69 Camaros and ?
- tremic tr-3550 what kinda of power can it handle
- which clutch for tko600 on FE
- TKO 600 Slip Yoke
- auto trans to manual conversion for endurance racing
- 13/16" bore vs 3/4" bore cluth master?
- T56 Chevelle Setup
- Shifter relocation
- T56 Floor Replacment
- Centerforce clutch vibration......
- T-56 clutch hydraulics/pedal question
- planning a t56 swap like everyone else
- TKO wiring harness plugs/adaptors?
- t-56 to LS1 transmission bellhousing? where is the best place to get one
- Short Transmission Mount
- Announcing T56 Manual Clutch Linkage
- No Reverse
- T-56 Tailshaft bushing
- offset shifter for stock 69 console?
- Shifter Clearance Problems
- Shifter hole size & boot for t56 install
- wow- TKO 600 screwed up
- tko 600 hydraulic
- T-56 install
- TO bearing question
- T56 Delema. need rebuild or exchange quicky
- Dualfricion slipping
- clutch fork problem
- clutch fork
- Need Help please
- Has anyone rebuilt a T56
- tko 600
- Anybody tried the Keisler
- Hydraulic Clutch Problems
- Issue with Muncie 4 Speed
- High Pedal Effort on new Hydraulic Install
- LT1 T56 clutch fork installation question
- Reflections on a TK0-600
- Chevelle T56 Install - WTF
- Borg Warner 6 speed
- LS1/T56 help needed- TO,scattershield,etc
- Pedal difference between pin style & bolt-in
- 88 IROC manual trans into 70 camaro?
- Anyone recognize this T56 crossmember?
- T56 - intermittent grinding sound when releasing clutch
- Tremec older TR3550 shifter
- m21 m20 questions
- clutch issue
- saginaw 4-speed
- T56 Manual Clutch Linkage For Buick Olds & Pontiac
- 6 speed swap to a 2nd gen
- 70 Chevelle LS3/T56 Crossmember question
- T56 Crossmember 70 Chevelle
- Found an interesting t-56 replacement
- Cost of TKO 600 Install?
- Trouble Installing Tremec 6sp
- ??? Crossmember Bounce ???
- TKO600 or T56 Magnum??
- How many of you have had clutch come apart?
- T56 clutch will not disengage
- g body shift assembly
- Can you please tell me if this is a muncie transmission?
- slipping clutch?????
- need help with a part number please
- Leaking Ram Throwout bearing...
- ZF 6 speed throwout bearing...DEFINITE answer???
- keep my tko600 or go to a T56?? LS swap going in from a BBC
- Which Clutch Master Cylinder to use???
- Oil cooler manual race transmission
- Shifter distance from rear of engine camaro
- Clutch help...
- Broke my Richmond what to do? Need a stong stick!
- new guy, dumb questions about T56 Magnum
- Questions about an auto to manual swap...
- TKO500 first drive
- TCI 6x vs Tko 600
- TKO 500 Gear Advise.
- cross member modifications for a TKO in a 72 Buick Skylark
- Richmond 6 speed for '73 TA
- Viper T56 clutch line adapter?
- Keisler RS600
- B.O.P bellhousing adaptor plates
- hurst shifter assembly disassembly and linkage for BW T10 and muncie
- how long is a t56
- Any experience with 5 speed Richmond Super Street OD?
- 6 speed
- First gear selection
- m22
- What speedo gear do I need?
- 96 T-56 behind LS motor?
- looking for a blank flywheel for a 302 ford
- T56 in an A-body
- Concentric Slave Cylinder Force on Pressure Plate
- GTO 6 spd
- Which pilot bearing to be used with Quick Time RM-6023
- Pontiac 455/LSx T-56 in a 1979 TA
- How do I hook up my speedo (T-56)
- Difference between Tremec 5 and 6 speed?
- Cts-v 6 speed trans
- Please Help: T56 (Hurst Driveline Conversions) Install into 70 Chevelle
- Shifter for GTO T-56
- t56 number
- what to look for when buying a t56 used
- ats or brp t56 cross member for fbody?
- TKO is a noisy box of rocks - T56 better ?
- billet shifter handle
- Anyone, swap an LT1 T-56 to a Pontiac Motor?
- Muncie 4 speed help
- wiring 6 speed trans
- T56 swap in to 72 LeMans
- 69 Firebird - Auto to Manual - Pedal Mounting
- Trade my mild rebuilt TH350 for a T5?
- 1st gen complete t56 swap kit
- T56 Slave Cylinder hose - where to get one?
- Wilwood master cylinder for LS/T56 clutch setup???
- T56 vs. RS600
- TKO 600 for Chrysler
- T56 or TKO 600 in a first Gen? Opinions?
- What T56 trans fluid are you using?
- Pro5.0 shifter handle?
- tko600 or t56
- LT1 model T56 work on an LSx?
- LS1/T56 into '66 GTO...need DETAILED instructions/photos of slave-master cylinder
- What mount for T56 crossmember?
- Should I get a T56 magnum or wait??
- shifter stick quandry
- What manual transmission for big cam BBC?
- Thinking of swaping the turbo 350 behind my 406 sbc to a t56, What do I need to know?
- T56 LT1 Pressure Plate Bolts.
- Used TKO600 ?
- T-56 clutch selection and Tick adjustable master cylinder
- Clutch disc and pressure plate 'interchangeability'
- Wide vs close ratio tranny?
- Pilot Bearing v. Pilot Bushing
- Lt1 t56 electrical plug questions
- Safe to say this is where my stock shifter cutout is?
- W.C. T5 in Slightly modded '78 camaro
- AWD CHarger with manual
- Best fluids for t56
- Borg_warnere t-10 1963 Aluminum
- T5: will it live?
- dse clutch master cylinder bracket / pedal mounting help!!!
- I need some help on the transmission connectors for TKO 500/600 Neutral safety switch
- Match made in heaven?
- LT1 pressure plate and clutch install helpp
- T-56 in a 70 Buick Skylark GSX
- Anyone with Carb and overdrive
- Corvette T56 questions
- 5 or 6 ?
- Wide or close ratio transmission gears & why.
- slave cylinder for 67 camaro/t56 wilwood pedals
