View Full Version : Manual Transmissions
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. Bore & Stroke of GM Clutch master
  2. 2nd gen t56 crossmember
  3. Milky clutch master cylinder fluid?
  4. t56 behind a pontiac 400
  5. T-56 kit
  6. TKO-600 vs T56
  7. clutch pedal
  8. T56 Magnum
  9. American Powertrain TKO Set up
  10. Muncie M-22
  11. T56 magnum 6-speed - Tech and Availability Information
  12. f body ls1 clutch master cylinder bore
  13. LS1 clutch help
  14. T56 Part help?
  15. bronze pilot bearings
  16. 5 speed Q?
  17. T56 measurement
  18. Turning higher RPM's with TKO 600....
  19. LT1:auto to manual tranny=> Chip programming
  20. Mech. clutch adjustment- please help!
  21. G-Body manual trans conversion
  22. New Flywheel is Very Snug
  23. Hydraulic Clutch Questions
  24. what rear end gear to run?
  25. Hydraulic Throwout Kits
  26. Remote reservoir
  27. What is this T-56 Magnum Bell housing?
  28. tranny fluid in clutch
  29. GM Quick Connect
  30. T56 clutch master cyl - whos modified theirs?
  31. tranny jumpin!
  32. Z bar linkage or hydraulic clutch?
  33. 5speedtransmissions.com external slave cylinder
  34. tko 600 or t45rs
  35. TKO 600 and LQ9?
  36. TKO pigtail...where to get (see pic)
  37. T56 dust sheld needed
  38. super t10 behind a big block
  39. Flywheel Machining
  40. Hey Shafi...
  41. Keisler throw out bearing question
  42. Clutch plate for T56?
  43. Daily Driver Help. Honda Content Warning
  44. Tremec T-56 Magnum update
  45. Identifying a 4-speed Chevy Trans????
  46. smoke from tranny!?!?!
  47. TKO 600 Speedomrter bolt SAE or Metric?
  48. T56 Rebuild - buying used, how can I tell if it's a good transmission
  49. t10 hard downshift
  50. Tko 500 tunnel issue
  51. Which flywheel w/ t56, steel or aluminum?
  52. clutch fork removal on T56.
  53. t-56 master cylinder hose
  54. Is it possible? T56 Tranny to 4L60E
  55. clutch master-modified or Mcleod?
  56. LS1/LS2 Bell Housing Differences!
  57. TKO Parts. Where to get ??
  58. T56 Flywheel Explanation
  59. The Gear Box LS1 stle T56 to SBC
  60. New T-56 Magnums on the way
  61. T56 crossmember for my 67 camaro??
  62. Muncie questions?
  63. Clutch/Flywheel Decision for Auto to TKO swap
  64. Billet Keys and Bronze Fork Pads in a T56
  65. Keisler T45RS v. Muncie side by side
  66. which tranny is best for my app?
  67. shift knob????
  68. DSE clutch firewall bracket $25??
  69. TECH VIDEO: GM Mechanical Release Bearing
  70. is this a good deal?
  71. Flywheel weight
  72. First install of the new T56-Magnum
  73. Who has a D&D Chevy/Viper T56??
  74. 68 camaro t-56 clutch question
  75. T-56 install - 1st gen camaro
  76. New Hurst shifter for GTO
  77. Anybody got a new McCleod clutch master PN139000 in stock?
  78. Just picked up '04 GTO T-56
  79. T56 Clutch Master & Slave Cylinder Help!!
  80. Mounting hydraulic clutch master cylinder question
  81. T56 Swap - Complete cost?
  82. Autogear's NEW Muncie M22Z 2.98:1 Gearset
  83. LT1 T56 throwout bearing
  84. Ok need a little flywheel advice on a tr-6060.
  85. Another Clutch Recommendation Thread...
  86. T-56 crossmember for 65 Chevelle A-body??
  87. McLeod clutch tourque specs
  88. Clutch smell when it is shot?
  89. Help With A Remote Reservoir
  90. 454 with a 2002 T-56
  91. Adjustable Clutch Master
  92. TKO Cross member Question?
  93. .50 6th gear T56, what rear gear you running?
  94. T-56 Magnum Install
  95. T56 MC bracket for 2nd gen
  96. 350 Gen I sbc to LS1 styled T-56 conversion
  97. ford vs gm T5's
  98. Input Shaft and Tail Swap on a T56, anyone actually done it?
  99. 68 Camaro ls2 with T56, how much to cut?
  100. clutch help?
  101. 6 speed into 72 Chevelle.
  102. 2nd gen T56 swap. pedal ratio questions
  103. Correct info on magnum installation
  104. Clutch issue w/ '95 Prelude
  105. muncie 4 speed
  106. Doug nash 4+1 manual
  107. Need Part Number- Pilot Bearing SBF with Tremec TKO600
  108. OH DAMN! Broke my Transmission today!
  109. 1969 camaro neutral safety switch
  110. t56/t55 same?
  111. DNE 4+1 cross member
  112. Manual to Auto - Is this all I need ??
  113. Keisler t56 magnum hydraulic slave cylinder help
  114. Keisler t56 magnum hydraulic slave cylinder help
  115. t56 Slip Yoke Install question.
  116. TKO 600 Vibration
  117. Jay Leno video on Tremec TKO 5-speed install
  118. Keisler Engineering and Car Craft Summer Nationals
  119. 429 Ford hydraulic clutch conversion
  120. Transmission dimensions
  121. Help me choose a clutch
  122. T56 pilot bushing help
  123. Difference T-56 F-body and 02 Corvette?
  124. T56 Install woes
  125. muncie swap 71 z
  126. What lube are you using in your Richmond 6 spd?
  127. Trouble tracking down T56 install pictures
  128. Keisler or classic 5speed
  129. TKO 600 hot shift knob
  130. What fluid for T56?
  131. Who really beats their TKO?
  132. tko 600 pilot bearing
  133. Using a Muncie with LS engine
  134. overdrive muncie
  135. Hydraulics clutch help
  136. Keisler on Speed Channel "Chop Cut Rebuild"
  137. Manual Tranny Tech Videos
  138. Chip Foose's TERRACUDA - way cool
  139. Notchy clutch pedal
  140. t56 shifter question about bolts
  141. hydraulic clutch resevoir
  142. t-56 shifting question
  143. who has done a t56 in second gen camaro? what did you use hydraulic or mechanical?
  144. bellhousing alignment
  145. need pics of firewall brake area.
  146. What clutch disc to use?
  147. What's the best clutch?
  148. Keisler hydraulic actuator kit and LS style clutch??
  149. Adjusting clutch fork angle underneath the car?
  150. Moroso adjustable bellhousing dowels question
  151. Moroso adjustable bellhousing dowels question
  152. Can't remove tranny
  153. LS1 T56 in a SBC - Install question
  154. T56 SBC install help! Clutch/Flywheel/Hydraulics install question
  155. T56 Magnum into A body
  156. 2000 T-56 to 1969 GTO
  157. Monster clutches
  158. transmission upgrade help
  159. american touring specialties
  160. TREMEC TKO600- good trans??
  161. Classic Motorsports vs Keisler trans swap kits
  162. T56 Throwout Bearing Stuck in Extended Position
  163. Clutch doesn't want to downshift when warm? TKO600
  164. t-56 measurement question
  165. Driveshaft loop for TKO
  166. TKO Crossmember First-Gen Camaro
  167. TKO 600 Speedometer Cable
  168. Impossible clutch fork alignment dilemma
  169. Hydraulic Thowout Bearing, Special Case
  170. T-56 crossmember question for 2nd gen camaros
  171. need help for driveshaft specs
  172. SBC Lakewood Bellhousing with TKO600
  173. Richmond DD 5 speed to TKO600
  174. LS1 to Viper T56 ??
  175. T-56 clearance with G-body
  176. T-56 model differences?
  177. T56 clutch master in orig. auto car
  178. Shorter OEM concentric slave/throwout? F-body v Vette v Fords v ???
  179. How to get hold of Red Roberts?
  180. TKO600 Shifts Hard in 1st Gear from Neutral
  181. TKO-600 Shifter Vibration between 2500 and 4000 RPMS
  182. Pilot bearing
  183. T56 Bearing retainer for LS1 or Viper possible?
  184. Sealing the Clutch Linkage Hole in the Firewall
  185. T-56 Switch Question
  186. General questions on C5/C6 transaxles
  187. Stock 1stgen F-Body Pedals for T56 swap?
  188. Clutch Adjustment - Clearances, Pivot Ball and Taller Bearing
  189. Looking to buy complete manual swap
  190. Noise - Clutch disengaged
  191. TKO not able to freely move into gear
  192. Crossmember ?!?!?
  193. 1st Gen Firebird (Camaro?) - TKO600 and T56 Fitment
  194. Manual clutch with LS?
  195. TKO 600 in a 2nd gen (NEED PARTS???)
  196. clutch not engaging
  197. question about dialing in Lakewood scattershield
  198. LS1 Bellhousing Question??
  199. Short shifter for a T-56
  200. Anyone make a trans crossmember for the t-56 in a GM A-body?
  201. Need Help!!! On T56 swap in 2nd gen!!!
  202. T56 behind a Pontiac 400?
  203. chevy truck crossmember
  204. Hyd clutch master linkage SNAPPED OFF?!?!?!
  205. Clutch adjustment for TKO
  206. Just went with a Tex Racing T-101 4spd -Any advice?
  207. Super T10 limitations?
  208. Bleeding LT1 T56 system
  209. 461 stroker
  210. Recommendation For Strong Reliable Trans
  211. ATS Cross Member...in a Nova?
  212. LT1 T56 with vortec 350
  213. Richmond 5 Speed Hydraulic Conversion?
  214. T56 hydraulic slave cylinder bracket question
  215. T56/Clutch Combo Help
  216. TKO600 Extreme
  217. question about installing pilot bushing
  218. Classic Motorsports Group changes name to Hurst Driveline Conversions
  219. How to dial in bellhousing/scattershield - Lots of pics
  220. Any Abody mopars with a viper t56?
  221. Clutch pedal stops.......
  222. Clutch Master Cylinder Specs for Viper CSC??? & Mcleod Clutch PP Travel?
  223. 68 camaro, lq9, t56 trans question
  224. Mounting T-56 in a 1st gen,
  225. Richmond 5 sp in a 1st Gen Camaro?
  226. T-56 in an A-body
  227. LS1 & LS2 T56 Bellhousings Interchange???
  228. 1970 1/2 Pontiac Trans Am
  229. Hydraulic clutch gurus--need help putting together a plan of attack
  230. Help selecting T-56 Magnum Gears
  231. Quick time Bellhousing info needed
  232. McLeod M-800 - any new info
  233. Viper T56 6 Speed in a 1966 GTO Install Guide (long, lots of pics!)
  234. Hydraulic Clutch Fluid?
  235. 2010 Camaro SS TR6060 problem.. ideas?
  236. Changing automatic to manual
  237. T56/TR6060 help
  238. Hydraulic Clutch Smarties Needed
  239. Need Help 6 Speed for an LS3 in an F-Body
  240. Flywheel bolts
  241. Hydraulic Clutch in 69 Camaro
  242. Hydraulic vs. mechanical w/TKO
  243. Driveshaft length w/ t56?
  244. T56 Input Shaft Size Please!!
  245. My TKO won't let me shift
  246. Any experience with a doug nash 5 speed?
  247. T56 for my 69 Camaro help...
  248. M21 4 speed crossmember
  249. Bellhousing, clutch, pressure plate for SBC TKO600
  250. Electronic Speedo Question
