View Full Version : Manual Transmissions
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. HELP me PLease...T-5 choice question
  2. 5 or six speed in my 1966 Chevelle wagon?
  3. New 6.0 GTO shifter housing
  4. tremec 3550 vs TKO 500/600
  5. Running TKO up to speed with no driveshaft
  6. Ls1/t56 In 62 Vette Speedo Help
  7. t56 flywheel dust cover
  8. Difference between the Ford and Chevy T5 transmission?
  9. richmond 5 speed in a 65 impala?
  10. Free Shipping for November
  11. TKO 500/600 question
  12. T-56 in a 57 chevy
  13. Classic Chevy Free Shipping Extended!!!
  14. Classic Chevy Free Shipping Extended!!!
  15. need a custom bellhousing
  16. Clutch hole in the firewall (69 El Camino)
  17. t56 swap
  18. 331 with t56
  19. short shifter for T56
  20. Super T-10 in '69 Camaro?
  21. My clutch wont disengage. Need help.
  22. TKO shifter swap
  23. T56 into A-body
  24. Shift handle options for first gen Camaro
  25. clutch???
  26. T-5 Conversion
  27. 68 camaro 6 speed
  28. calling Jim
  29. Can you ID my t56?
  30. tko600 speedo
  31. Who's running a 5 speed Richmond?
  32. Richmond 4+1 Pontiac swap
  33. Muncie Rebuild-Atlanta Area
  34. few questions about ATS LS1 T56 hydraulics
  35. flywheel for l99/lt1
  36. 05-08 Mustang 6-Speed-Question/Help
  37. LS1 T56 master cylinder questions
  38. Anyone interested in ATS GP??????
  39. Richmond ROD 6 sp
  40. T56 conversion
  41. 4 Speed Manual Transmission
  42. Another T-56 into an A-Body Thread
  43. Viper t-56 with a blow proof
  44. Mopar TKO 500 Kit
  45. Best place to buy t56 parts????
  46. Saginaw trans swap
  47. t56 clutch bracket
  48. 454 bbc, what box?
  49. Gm T-5 Swap
  50. clutch not disagaging.
  51. pilot bearing source
  52. t6 pigtails needed
  53. T-5 help?
  54. Has anyone put a T-56 in a 1965 mpala
  55. Tremec Aftermarket T56 ????'s
  56. multidisc clutch
  57. TKO600 what's the clutch of choice
  58. Spec Stage 3 or Centerforce DF
  59. 67 Camaro return spring relocation help
  60. Need some help, my head is spinning over this T56
  61. T56 going extinct?
  62. Warped McLeod scattershield ?
  63. plasma cutter and chevellw trans hump
  64. viper T56 behind Gen 1 SBC
  65. T56 conversion items for 70's F-bodies
  66. Best Clutch??
  67. LT1 T56 fluid question
  68. 4L60E to Manual Conversion
  69. New TKO600 stuck in gear
  70. speedo 4sp manual
  71. Manual trans swap into 73-77 A-body (GM)
  72. Manual Trans Linkage - Gen VI Block - No Hole??
  73. Hurst Linkage Rebuild Kit - Where Can I Buy It?
  74. Clutch Advise
  75. High rpm shifting..
  76. spherical shifter rods
  77. 67 chevelle pedal assy.
  78. LS2 with t56 wanting to switch to TKO600
  79. Can you identify this 4spd?
  80. clutch and flywheel help please
  81. How Much Gear Oil - Muncie 4spd ??
  82. T-56 speedo teeth
  83. will it work?
  84. t-5 install questions
  85. Stick for a Gen 1 SBC T.T.
  86. "621" bellhousing
  87. z-bar bracket 64-67 a-body
  88. Question on sealant after T-56 rebuild
  89. How Much Cutting To Put In A T56
  90. Help needed T-56 in `99 Mustang
  91. TKO to LS1. And short shifter?
  92. mcleod bellhousing
  93. '68 Camaro clutch pedal questions
  94. T56 viper transmission
  95. 1st gen LT1/T56 Header clearance
  96. 66 A-Body clutch adjustment
  97. Tremec, McLeod, mechanical clutch linkage
  98. Twin Disc Clutches, Hydraulic T-56 & pedal feel
  99. Dog box conversion for T56?
  100. TKO Swap on a budget
  101. Removing Lakewood Clutch Fork While Keeping Bellhousing Bolted On - Can It Be Done ??
  102. Lakewood & GM 3892632 Do NOT work with Lakewood Bellhousing - Suggestion??
  103. Proper Way To Remove Lakewood Clutch Fork (PIC)
  104. Some T56 questions...and flywheel questions...
  105. TKO Install - Hydraulic TO Bearing
  106. Clutch issues
  107. T-56 Questions
  108. 1969 Camaro Auto to Manual
  109. Installing a McLeod RST Street Twin and Bellhousing in the '67
  110. TKO-600 Leaking with only 300 miles on it WTF!!
  111. Help with pedal ratios
  112. Hydraulic vs Mechanical clutch
  113. Dual-disc, 6-speed stick tranny info.
  114. Pilot bearing problem???
  115. '69 T/A, T-56 & original center console?
  116. Need a McLeod dealar
  117. muncie linkage question
  118. Clutch problem....Need help
  119. Flywheel for 1 Piece Rear Main
  120. Clutch Hydraulics in 1965 GTO
  121. Transmission Fluid - Which To Use?
  122. Custom T-56 crossmember Help
  123. Viper T56 to LT1 T56
  124. Which Clutch to back up 500+hp
  125. how is the t56 reverse lamp switch wired?
  126. Mcloud Shield, CLUTCH FORK BALL HEIGHT
  127. muncie 4 speed
  128. Availability of the RST clutch from McLeod?
  129. super t-10 steel mid plate
  130. T56 Clutch alignment tool??
  131. Any experience with "The Driven Man"?
  132. Flywheel for LT1 T56 to 68 model 350 engine?
  133. Problems with viper t56
  134. McLeod vs Centerforce
  135. threading t56 knob onto shifter
  136. Quick Time bellhousings
  137. Hurst shifter reassembly
  138. Where can I get a hydraulic clutch kit for my tremec TKO behind LS1
  139. Clutch Hyd. Master and Firewall Mount
  140. LS1 Style T56 Swap in a 71 Nova
  141. t-56 HELP!
  142. Has anyone done a T56 Mid-shift conversion
  143. T56
  144. 95 LT1 and T56 in 68 camaro hydraulic questions.
  145. Anyone know a good muncie rebuilder in the Milwaukee, WI area
  146. Grease on the Throwout Bearing Face?
  147. Hyd. clutch issue
  148. LT1 T-56 or LS1 T-56.. trying to plan ahead
  149. ATS T56 Crossmember help
  150. T56 Reverse Lockout Assembly
  151. t5 hydraulics in a 69 firebird questions
  152. hydraulic setup for a doug nash 4+1
  153. Dumb Question, LS1 vs LS2 Flywheel?
  154. TKO-600 installed
  155. TKO 600 Speedometer cable retention
  156. Ford TKO600 to Chevy engine
  157. Clutch not disengaging
  158. T56 Oil Fill
  159. TKO 600 Problem?
  160. T56 chatter at idle in neutral?
  161. Keisler TKO-600 Sloppy Shifter
  162. Mating a 392 hemi to a LS1 style T56
  163. Any TQ spec on TKO to bellhousing?
  164. lenco for the street?
  165. Dial indicator on aluminum flywheel
  166. T5 Transmission for SBC help please!
  167. Shift knob help
  168. t56 clutch won't disengage
  169. Tko 600 ?
  170. What thread size rear trans mount TKO600?
  171. clutch cable insulation
  172. T56 in First Gen Camaro Question
  173. 2004R Rebuild
  174. 66 BOP A-body clutch linkage problems
  175. 1000hp transmission
  176. DSE 2nd gen T56 crossmember - neat
  177. Hydraulic TOB kit for M20
  178. Can anyone tell me what kind of 4 speed this is?
  179. Hurst shifter jams between gears
  180. New GM repro Bellhousings
  181. LS1 T56 Hydraulic Throwout Bleeder
  182. T-10 pressure......breather problem
  183. Gear ratios... suggestions?
  184. T56 Pilot Bearing and Bellhousing issues.. Please help!
  185. opinions of this shifter? anyone seen it?
  186. Lowest Cost complete T56 for 550ft-lbs
  187. T56 reverse lockout & skip shift solenoids?
  188. LT1 T56 help needed
  189. Jeg's T56 crossmember
  190. lt1/t56 HELP!!!
  191. T-56 5th and 6th Gear
  192. '93-'96 F-body T56 console dimension
  193. Wrong Crossmember??
  194. auto to man trans conversion
  195. Hydraulic Master for LS1 T56 conversion
  196. Mating a LQ4 to a D&D T56
  197. How much fluid in a T-56
  198. I need a T56 reverse lockout solenoid...
  199. Keisler kit, WTF?
  200. What fluid for LT1 T56?
  201. New bell
  202. Repro clutch pedal setups any good - 68 camaro?
  203. T-56 with L98 (350 TPI)
  204. BRP Performance Trans Crossmember
  205. Strange noise - LT1 T56
  206. .82 or .64 TKO?
  207. TKO600 with LSX???
  208. Bolt spacing for flywheel
  209. Classic Motorsports FREE SHIPPING!!!
  210. Ford TKO-500 in a chevy
  211. T5 behind an LSx motor?
  212. Ugrading a TKO transmission
  213. T56 swap flywheel question.
  214. TKO 600 Shifters
  215. Alston tranny cross members
  216. Dual-Disc Clutch Install
  217. Lightened flywheel
  218. clutch failure after 1000 miles...huh
  219. Can this be done?? Tailhousing swap T56
  220. KEISLER BlockBuster SALE on 5 & 6-speed Manual Transmissions: Tremec TKO T56 T45RS
  221. Happy Holidays
  222. What are these T45RS?
  223. Noisy Tremec
  224. Hydraulic clutch info
  225. Hydraulic throwout bearing w/ T-56
  226. Offset dowel question..
  227. Using aftermarket Hydraulic Thowout bearing
  228. ARP Flywheel Bolt torque
  229. New Tremec TKO take off shifters. $25.00
  230. t-5 help
  231. 98 ls1 pilot bearing help
  232. Centerforce
  233. ALL T56 trans the same ??
  234. What is the 6th gear ratio in a T-56
  235. Clutch recommendation
  236. Clutch - Throwout Bearing Problem (I think?)
  237. flywheel question for t56 swap.
  238. upgrade ?
  239. richmond super street or tremec tko
  240. 6 speed from a 94 trans am
  241. Need help with parts list Tremec 6-speed
  242. Close or Wide Ratio Trans?
  243. Is there a t56 scattershield yet?
  244. best place to get a ls1/t56 bell housing
  245. See Keisler at Super Chevy Baton Rouge 6-8th!
  246. TREMEC TKO Install Videos - Swap from 700R Auto
  247. TKO 600 prices?
  248. MGW F body shifter
  249. Carbon Fiber Shift Arm
  250. Anyone do a T56 in a 65 Skylark
