- American Powertrain Hydramax Question
- 2005 vette tranny is a t56 6sp?
- T56 magnets
- t56 magnum parts
- T56 A-Body
- 6 speed swap
- T56 Magnum Throw out bearing: Ideally GM parts
- t56 cross member
- Clutch Bleeder Leaking
- First Gen TKO 600 Swap Questions
- LS3 engine with a TKO 600 (what clutch kit and flywheel to use)
- Setting up mechanical linkage for T56 magnum
- LS3 flywheel weight
- TKO, unable to mount to LS 621 Bell Housing
- Billet Specialties Shifter Lever for Tremec TKO500, TKO600 & Borg Warner T-56 Trans
- Transmission Tunnel Clearance
- Transmission Value
- Can I make my own transmission faceplates?
- T56 SUPER Magnum
- T56 Super magnum purchase
- LT1 to LS1 conversión questions
- t56 Magnum Hits Nose cone on Starter...
- T56 Magnum Shifter Rattle - Only under high torque, not speed-related w/video
- Mcleod RXT clutch disc thickness
- Which Magnum Ratio?
- brand new out of box TKO 600 stuck in gear
- McCleod RXT vs Centerforce DYAD
- Which fluid for TKO?
- Who Makes a COMPLETE kit to install a TKO600 into a G-body?
- Bowler Trans Tunnel
- Synchronizer Assembly Interchangability
- Ford 9" rear ratio discussion
- Ls9/tko 600
- Anybody Using a Saginaw 3 Speed Manual?
- Pics Inside - T56 Magnum Do I Actually Need To Raise My Tunnel?
- Tremec magnum shifter
- Installing a CTS-V T56 behind a 5.3L truck engine
- Raising Trans Tunnel For T56 Magnum - W/ Pics
- LS7 clutch noise...
- T56 Chevelle question
- Mc Loed mid shift
- Cheapest Way to get Manual and Overdrive
- 6.1l hemi manual trans help
- Dual disk Fidanza 33 lbs setup ok on street?
- LS 4.8 - T56 - Clutch setup - Mechanical / Hydraulic - Sachs1050
- Used T56, what to look for...
- Single vs twin disc clutch
- O.E. TR6060 to Magnum ?s.
- Challenger Tr6060 using t56 clutch/flywheel?
- which flywheel for LT1 t56 bolted to old SBC
- external Slave T-56 magnum?
- T56 install - where are you connecting your back up lights?
- Having a hard time deciding TKO 600 or T56 69 for my mustang.
- American Powertrain HRB shim question. Shim bell housing or tranny?
- Help with bleeding new clutch MC.
- T56 Magnum master cylinder
- Best T56 bleeder extension?
- 5 Speed OD opinion. TKO 600 vs Richmond Super Street
- LS3 clutches!!!
- Gear indicator
- tremec guide pin backing out
- LSA swap in 69 camaro
- TR6060 in a 68 camaro?
- T56 advice needed
- T56 magnum info needed
- Tko600 shift stick rattle
- First Gen Camaro Clutch Pedal Height
- Finally found a T56! But have some questions...
- T56 Magnum BBC Pilot Bushing
- Hydraulic clutch master cylinder alignment
- T56 magnum with ctsv bellhousing oil pump question
- Stock LS bellhousing or Quicktime?
- Can you ID this trans????
- Lakewood scattershield working with LQ9 LS swap / TKO600?
- G Force modified Tremec 3650
- NEW TKO Install- (Grease what?)
- T56 magnum input shaft into pilot
- TKO600 Noise in 66 Biscayne
- Bowler All-In-One Wrong Speed
- CTSV/ZL1 Bellhousing / T56 Magnum input shaft
- TKO 600 Install.."the bolt"
- Nova with T56
- Tremec TKO and 1969 console shifter stick
- Auto to manual swap questions
- Any aftermarket DCT transmissions on the market
- Question for the drive line Gurus.
- TKO 600 Second Gen Speedometer Calibrate
- used T56 or Magnum
- McLeod T/O bearing 69 camaro TKO 600
- Hydraulic clutch in 1970 chevelle
- clutch recommendations
- 68 Camaro Richmond 4+1 street speed question
- Parts needed for T56 in 67 Camaro...
- LS9 T56 Swap
- TR6060 swap - clutch disengagement question
- Sealing shifter hole?
- Question on T56 speed sensor
- T56 magnum transmission
- Shifter boot base install
- Help with transmission decision
- Move shifter closer TKO600
- LS7 Clutch TKO Master Cylinder Bore size?
- TR6060 MG9 clutch setup for 1968 Camaro
- Auto trans to TKO 600 conversion - clutch cable options?
- Shipping a trans????
- T56 bellhousing alignment - Quicktime
- Clutch line size
- T-56 install in a 1980 Firebird - Change from Auto to Standard!
- TKO600 install
- clutch pedal slop
- Speed sensor question T-56
- TKO 600 not smooth between 1st and 2nd
- Best Clutch for LSA
- clutch pedal stop suggestions
- 1st gear ratio choice TR-6060 for big power
- T56 Magnum Bellhousing Alignment Help!!
- t56 help
- t56 Magnum with 370 gears and wide ratio
- Transmission crossmember ‘67 camaro TR6060
- T56 Magnum - am I the only one frustrated by the gearset choices?
- Magnum swap woes
- TR6060 driveshaft for 69 Camaro
- T-56 Adjustable Transmission Crossmember Flex?
- American Powertain T56 Magnum kit - going road racing
- t56/ls7 clutch - Stiff clutch pedal after bleeding hydro master cylinder
- tr6060 fast bleeder install advice?
- Clayton pedal assembly worth it?
- TKO 600 to BBC Muncie Conversion
- Shifter length - 8" or 10" ???
- tko600 to t56 magnum for autocross
- 383 SBC to LT1-T56 HELP
- Rubber transmission mount, TKO 500/600 type - some info
- T56 magnum shifter location for factory console 1970 Firebird
- Dakota Digital speedo calibration frustration!!!
- t56 magnum external cooler
- ls3 and tr6060 in 1967 camaro
- T-45 Question
- Transmission shop in LA
- TKO Shifter Upgrades
- Not sure if it’s a trans issue
- Tr6060 slave to -4 adapter needed
- Which McLeod clutch to go with?
- T56 Magnum trouble
- Magnum Shifter Gate
- Magnum rear seal
- American powertrain six speed swap help
- Tko600 csc
- Spin driveshaft by hand to test clutch disengaging
- 1st Gen Clutch Pedal Geometry (4th Gen) Template or Measurement info..?
- TR6060 w 6th gen console shifter
- Tremec trans id
- Clutch disengaging too far?
- T56 2nd gear grind
- Throwout bearing Spacers
- Dual Clutch Transmission (DCT)
- LS vs LT T56?
- 5 SPEED- Transmission KIT for GM A-body 64-67
- TKO 600 whine in 4th and 5th
- Which cross member to use? Limited options.
- Should I have shimmed the clutch slave?
- ST 10 to TKO 600 swap
- Clutch master mounting
- GM/Tremec ACD 12453263 bellhousing dial in needed?
- ZZ4 - Lt1 T56 Flywheel? Help!
- Anyone convert a Muncie M21 to an externally mounted hydraulic slave set up?
- T56 magnum VSS question.
- T56 Magnum slave cylinder measurements
- LS7 T56 magnum and LS9 clutch
- TKO 600 BBC Which gear?
- Leaking T56 Shifter
- Help with Broken TKO 600----5th and Reverse Shift Rail (Part Number 2605823)
- Bellhousing for L92+ T56?
- T56 Slave shims and centering of teh slave after install?
- Trans Mount ID Help Needed - T56 Magnum
- T56 Magnum - temp sensor location?
- Pressure building inside transmission
- BAD vibration TKO600
- Questions on swapping 68 Camaro from Auto to Manual trans.
- Silver Sport T56 Magnum in 67-69 Camaro
- Bowler Nightstick offset shifter T56
- Tremec TKX
- Bell housing recommendations...
- Clutch and flywheel recommendations...
- T56 Magnum Short Throw Shifters?
- Hurst T56 Magnum Shifter Exploded View of Design
- Tremec T56 Magnum 6sp Problem (Won't engage 1st or 2nd Gears)
- New Tremic 5 Spped
- tkx or t56mag to replace ar5
- LS clutch pedal travel
- Hydraulic Clutch or Mechanical
- Speedtech Trans Crossmember Mounting Location
- Tremec - Swapping out .64 for .82 5th gear in TKO 600
- What Clutch Master to use?
- Bell housing alignment analysis...
- Clutch over hang on flywheel
- T56 long term storage
- Removing factory bell housing dowel pins?
- Pilot bearing for T56...
- Clutch Slave Height
- Tunnel cut for shifter...
- T56 Magnum Yoke confirm.
- 67 Camaro tunnel question
- 71 Nova Hydraulic clutch help.
- LS3/TR6060 swap into a 68 Camaro
- Advice on close or wide ratio T56
- Driveline shakes BAD
- T56 magnum upgrades for big HP
- LSA to Magnum F Clutch and Bellhousing Fitment
- Clutch Self bleeding
- Clutch Pedal too light t56 Mgnum
- Holly Clutch master cylinder. Looking for feedback
- Ideas for clutch pedal stop Gen 1 Camaro
- Pilot Bearing Install Question for LS Engine. How do I know if this is right?
- Lt1 t56 to gen1 sbc
- putting a t56 magnum in my 82 c3 corvette
- Bowler vs sst shifter
- LQ4 to TKO600
- Tremec tr6060
- Indexing Plate T56
- Gen 5 LT5 / T56 Clutch choice
- Feedback on the MDL Quik Stik Shifter on a T56 Magnum?
- TKO600 upgrades? Service? Parts?
- T56 magnum VSS sensor part #?
- Hydraulic clutch pedal needing adjustment.
- Tkx vs t56 magnum
- G8 TR6060 vs Camaro TR6060
- T56 shifter clearance
- T-56 old & new, difference?
- T56 rattle
- Used TR6060 out of a '15 Camaro questions
- Hdy Clutch Master firewall bracket issues
- Muncie rebuilding recommendations
- T-56 Fluid pump and cooler, Why and how?
- Which GM bellhousing for a GenV L87/T56 Magnum pairing
- S1 Sequential T56 Magnum
- T56 shimming questions..
- New Bowler Magnum F shifter install
- Advice needed for switching to hydraulic clutch system
- TKX or T56...Looking for input
- 69 Camaro Hyd clutch!!!!
- Hyd clutch questions
- T56 magnum with Ctsv bellhousing with pump
- Hydraulic clutch pedal adjustment
- Damaged bellhousing dowel holes - very loose offset dowels
- Hydraulic throwout bearing suggestions?
- 69 Firebird L92/T56 Wilwood Hydraulic Clutch - Yeah that's a problem
- Help with bleeding hydraulic clutch
- Tremec t56 Magnum or Chevrolet t-56 Super Magnum?
- T-10 Transmission and High torque starter issues.
- Any one with opinions on Modern Driveline’s Superior Kevlar clutches?
