- Is vacume advance needed (15 replies)
- ignition grounded? HELP! (3 replies)
- Ignition combo (0 replies)
- 70 Ls5 Help! (5 replies)
- timing problems msd (1 replies)
- To Gap or not to Gap? (4 replies)
- LS364 Ignition problems! (2 replies)
- Adjustable distributor slip collar? (2 replies)
- MSD help! (4 replies)
- crane street/race distributer cap? (3 replies)
- Looking for the best street/strip spark plugs (3 replies)
- MSD is pissing me off (10 replies)
- will i see a difference in performance (3 replies)
- Ignition curve 455 (7 replies)
- Tachometer issues (0 replies)
- Plug wire looms (3 replies)
- Procomp HEI Distributer - Group Purchase? (3 replies)
- msd e-curve (12 replies)
- Mallory Unilite...Use, upgrade or buy different brand? (29 replies)
- Weird.... only a few sparks (3 replies)
- Plug Wires (8 replies)
- Running like crap (2 replies)
- Push button ignition (2 replies)
- Accel shorty plugs made by NGK? (4 replies)
- LS1 system on older engine? (3 replies)
- Plug Wire Resistance (4 replies)
- All of a sudden runs like it's missing (3 replies)
- MSD Pro Billet ready to run distributor (3 replies)
- My Chevy centerbolt LT1 wire looms. (12 replies)
- How do you assemble Taylor LT1 ignition wires? (9 replies)
- Any opinion on pertronix second strike? (0 replies)
- ignition switch disassembly? (2 replies)
- Spark plug comparison? (0 replies)
- dist cap corrosion ARGHH! (8 replies)
- Startup issue (7 replies)
- Where to mount a MSD Box - 2nd Gen Camaro? (14 replies)
- Spark Plug Interesting Find (5 replies)
- Wont run, please help (35 replies)
- Anybody get a DUI? (1 replies)
- HEI Firewall clearance issue (13 replies)
- HEI..or a MSD Box (8 replies)
- Water...popping...dead! (4 replies)
- Acts retarded even at 20 degrees (3 replies)
- How I turned an points dist into electronis dist. (6 replies)
- Ignition Gremlens.. Need Help!!!!!!!!! (5 replies)
- New Crane Dist...anyone got it yet??? (8 replies)
- EMERGENCY! No Start! Help!! (18 replies)
- Do I need to use a balast resistor on the MSD ignition? (3 replies)
- Crane HI 6 ignition w/o GM-OE coil module (0 replies)
- new crane cams ignition (0 replies)
- MSD Distributors (1 replies)
- setting timing (1 replies)
- what to run for timing (4 replies)
- Tach not working w/ MSD ready-to-run distributor (6 replies)
- Types of ignition. (3 replies)
- What ignition to use??? (22 replies)
