View Full Version : Exhaust
- yet another exhaust opinion needed!!
- dynatech headers with bbc and clutch
- side b-pillar exhaust dump
- header coating discolored
- Who around me does full stainless exhaust work?
- need help with headers on my firebird
- heat sheilding material for gas tank?
- Where can I get these rubber isolators?
- Altering Header Resonance
- Help picking headers
- What headers for ChassisWorks subframe
- 67 Chevelle headers with a big block
- Weld or clamp mufflers to pipes?
- NEED HELP! full length headers hit upper tubular arms
- I want to have a full exhaust sysyem done in Cincinnati area.
- G-body LS headers
- Anyone used these guys for V band clamps?
- header fitment issues
- 02 sensor placement on single turbo v8
- Anyone used Kooks in Chevelle w/ LS swap?
- Chevelle pre bent tailpipe options?
- looking for full exhaust builder in SF Bay
- kooks headers
- Hanging low header solution
- Hedman header issue.
- Stainless Works mufflers
- Headers for 1963 Impala with 350
- Looking for Boom Tubes, any sources?
- Band clamps...preformed? (stepped) Or just standard?
- 68 Camaro w/ Heidt's 9" 4-link-how to route exhaust -please help!!
- LS Dynatech Headers fitment problems with Street and Performance crossmember
- Header coatings, which one?
- Aluminized vs stainless
- Exhaust exit underneath
- Exhaust too loud - please help
- ls2/DSe header fitment
- 600HP - Is 3" exhaust worth $700 additional cost over 2.5"
- Thoughts on preventing drone?
- What muffler you running and why.
- 67 ls1 camaro header clearance
- 1968 camaro BBC and Heidts pro g suspension front and rear- looking for HEADERS
- Wrapping headers
- Anyone take issue with exhaust under the axle?
- magnaflows or flowmasters?
- Popping Noise During Deceleration
- Exhaust wall thickness and exhaust note?
- Aluminum Pipe?
- what am I in for? pic
- Exhaust comparison
- best way to make exhaust black?
- Q: Header flange not flat
- Suggestions for 383 sbc
- Couple of header questions.
- Anyone run Magnaflow 3" system on GM A body?
- Best place to buy Stainless exhaust pieces?
- Tail pipes and G-link
- Stainless steel exhaust kit..?? Suggestions?
- NEW 2" primary Tri-Y's for 70-81 firebird & 68-73 GTO/Lemans/Tempest
- Dimensions for factory alternator mounting on first-gen Z28 exhaust
- does anyone use techline on headers/turbo headers
- What Mufflers are you using?
- Stainless Welding
- Headers/exhaust on a convertible '67 Camaro (with A/C)
- James Dean Muffler & Brake
- The best header discussion ever....
- 69 Camaro Header Solution
- Borla XR 1 vs Flowmaster 40's
- ls swap headers shorties, half or full length clearance?
- Circle ports on header, square ports on head.....
- Tailpipes with Alston g-link 1969 Camaro
- auto cad
- exhaust for '68 firebird with LS1
- Anyone build their own headers
- Has anyone used these headers? 69 camaro ls swap for under $225.00
- Kooks headers for Detroit speed subframe
- 2 into 1 Exhaust
- Ceramic Coating Vendor Needed
- my exhaust is bugging my neighbor, HaHa
- V-Band - Can you mate a machined flange to a Formed Sheet Metal?
- Rivet Nuts? How big is too big?
- What happened to flanged header collectors
- BBC first gen camaro header question
- magnaflow
- Anyone a Spintech dealer?
- Dr. Gas is still in business
- Any West Chicagoland Custom Exhaust Shops.... I need Stainless bent and Flared
- what hits and what fits! ls headers
- mid length vs full length.
- magnaflow
- Problem with Vibrant flex joints, what are you using?
- J-pipe or J-bend exhaust
- header options????
- 455 in a 68 Firebird with Heidt's frame Unisteer R&P
- Opinions on Stage 8 Locking Fasteners for LS Engines?
- Hedman 28150 Header Install on 76 T/A 400. This is how it worked on my car.
- 2nd Gen Exhaust system with DSE Quadralink
- Ceramic or Stainless?
- 2nd Gen Firebird exhaust advice
- Dougs d368 Headers 69 Camaro
- ridetech rear exit exhaust 69 camaro? any options besides SW
- FREE Headers for GM G Body
- Seal at header to exhaust pipe ?
- Heat expansion - fixed Magnflow exhasut at tail pipe?
- flowtech headers
- Looking for a Weld up Header kits for sbc
- Damn Header clearance
- Side exit exhaust
- Magnaflow mufflers, what size?
- Fun with Speed Bumps!! Header clearance help, please!
- 1969 camaro with g-link in need of some tailpipes!
- flowtech
- Can You Identify These Mufflers?
- I've got 2 exhaust questions...
- Summit Street strip Racing mufflers
- header
- exhaust question
- first gen exhaust
- A question for anyone with black headers...
- Eliminating crackle & pop on decel
- Shorty or long tube on BBC
- clipped corners on gas tank in 67 camaro
- 383 Stroker with Corvette-like Exhaust Soumd
- Its time to change the Magnaflows! Help
- finding headers for a 66 Galaxie convertible should'nt be this hard,or should it?...
- 1970 Camaro Header Help
- How close is too close?
- exhaust muffler help 67 camaro
- '69 camaro exhaust
- -65 Chevelle Ls1 Headers
- Flowmaster Delta Flow 50's - 1968 Firebird
- Exhaust Clearance
- ls best sounding mufflers
- Looking for Hooker 2238 sidemount headers
- Considering Transverse Muffler Setup
- headers kickin my a$$
- GM A Body exhaust 3" or 3.5 inch maybe oval? Help
- Header clearance
- Flowmaster Scavenger Series Elite Headers 814112
- Looking for headers to fit LS1 in a TCI sub frame
- Borla XR-1's so many options
- custom tri y headers
- magnaflow's too loud.....
- Any venders having a Stainless Works Exhaust Sale
- Help With Headers 69 Camaro
- Recomendation for Magnagflow CATS?
- i need exhaust help
- Stainless Works headers
- New Muffler Choice
- Stainless or steel exhaust system
- How do you weld the header tubes to a merge collector?
- Badass or Bad taste???
- Any mid length headers for 2nd gen Camaro with 4 speed?
- SpeedTech/SW headers + AFR?
- Hooker Headers 2473-HKR Install
- X-Pipe Design
- V6 Exhaust
- Dougs headers in 67 Gto
- What exhaust pipe and header diameter for GMPP LS9 engine?
- Quiet, but strong exhaust for Mast Black Label LS7?
- Varex Remote Controlled Sport Muffler
- Sidemount angle plug headers
- 86 Elcamino with LS3 Engine need feed back on oval Exhaust!!
- C3 Corvette sidemount headers
- X-pipe or no X-pipe?
- Do ceramic headers lose their luster
- 2.5 dual vs single 3.5. pros cons
- Muffler help
- Camaro exhaust on a g-body
- light weight exhaust material?
- Hooker VR304 Muffler
- 383 all roller super charged (best exhaust)
- xpipe ?s
- First Gen Camaro Exhaust with a minitub and T56
- Z06 Flanges
- head/ header alignment
- Dougs Headers in 72 Pontiac LeMans
- Heidts 4 link and exhaust. Help!
- 1971 camaro ls2 swap header help
- trans am buick headers help please
- Custom Headers - Mustang
- what does sap port mean
- dougs electric cut outs
- Magnaflow muffler hanger
- Modifying Kooks race ls tri-y headers for g-body???
- exhaust cutouts, best?
- Pictures of exhaust through the rocker on 1st gen camaro???
- Quiet exhaust without tailpipes?
- Three link exhaust routing
- Which LS swap headers with TruTurn? 69 Camaro
- Looking for G-Body Elcamino Headers Long tube any Suggestions, I will be Running a LS
- Flowmaster 40 or SLP Loudmouth 2 Bullets
- Heat shield
- Kooks headers seem a little low....
- low vert f body with injection
- Where to find exhaust tech info?
- How to quiet down a loud exhaust?
- HELP PLEASE Exhaust smell is bad inside car
- 78 trans am hi flow cats,cutouts, x pipe, hemi super turbos under axle
- exhaust kit vs shop install
- Borla Xr1 for First Gen Camaro
- Looking for some insight - 5.3, 76mm turbo - '68 Camaro
- Stainless works exhaust
- HELP!!!mid length or full length headers on 69 camaro!?
- 69 camaro ls3 header help pleez
- 69 Camaro LS2 header suggestions
- Pypes exhaust dse quadralink tailpipe kit
- My Magnaflow pics
- holley 3" exh with hotckis xbrace 68 conv
- Looking for a little more rumble
- 68 mustang tailpipes on a 1st camaro 4 link
- Exhaust Help Needed
- exhaust size 2 1/2 or 3 inch
- Exhaust through rear quarter
- 1969 camaro exhaust idea. Corvette or 5th gen exhaust.
- ideas on SS expansion, 69 3" rear exit with ridetech
- Too big ???
- Header coating recommendations
- V-band header reducers/DSE headers
- long or mid headers?
- X Pipe vs Choppy Idle
- 1979 TA, DSE subframe and Pontiac motor, What Headers fit
- best type of cutout?
- What Headers fit a 1st Gen Camaro with an LS3 and TCI subframe?
- 2nd gen Firebird w/LS2 options
- Try Y to oval pipe
- exhaust design for try ys and oval pipe
- New Hooker 2nd-gen F-body/DSE headers and exhaust system
- Hooker 1st-gen F-body/3rd-gen X-body headers and exhaust systems
- ok boys and girls check this video out and think about it when buying headers
- nova /camaro headers???
- Exhaust Fabrication - Detriot area
- turn downs or side exhaust?
- Triangular exhaust clearance cut outs in trunk pan for DSE quadralink -69 Camaro
- Front tire exit?
- Question about hooker 42503hkr exhaust system
- Pypes DSE tail pipes don't fit!!
- Dynomax 3" Super Turbos & 500hp?
- Flexible exhaust coupling (Stainless)
- 1981 T/A 301T swap to GM Gen 6 454/440 needs headers
- Engine Swap 1981 Camaro/Firebird F-Subframe t/ ZZ454 with TH350 Trans
- Header Options for '69 Camaro, LS3 and Roadster Shop Subframe
- LS Manifolds / Headers Search
- magnaflow 15896?
- Custom header cost
- Magnaflow Borla Flowmaster
- custom headers
- Nice header to fit 65Comet/Falcon with AFR heads
- GEN1 CONVERTIBLE 3" exhaust, X member, xover balace tube, rear tie exit? no problemo!
- Safe Muffler Distance from Gas Tank?
