View Full Version : Carburetion
- Holley Electric Fuel Pump Making Weird Noise
- Carb assembly question
- what is causing my demon to idle +200 rpm after a drive?
- Component selection.
- what should my air fuel be??
- Aeromotive A1000 Regulator - No Pressure?!?!
- Gen 1 linkage question
- Have a unusual Question
- 1/2" sending unit for first gens?
- Weber Carbs
- Leaky fuel cell help.
- Carb Recommendations
- fuel tank pick up
- 468 BBC with a 950 HP Holley- jet help
- q-jet rebuild kit
- Can you guys help me identify the model of Holley Carb on my car?
- Plugged are fouled in Cylinders 5, 6, 7, 8 - Suggestions?
- anyone know Rochester 2 Jets?
- Carb Problem..
- Is a totally rubber fuel line wise or foolish?
- weber
- Carb Idle - w/ AC Running & Without
- Why does engine run so lean on cold start up?
- 4 Corner Idle - Should all mixture screws be the same?
- Has anyone ever used holley adjusta-a-jet metering blocks?
- I can run a carb leaner at cruise than EFI correct?
- demon issues/quick fuel question
- Carburetor settings?
- qjet floods after WOT
- Popping through exhaust under partial throttle
- bonnie got a weird fuel issue, how can i fix this?
- Yet Another E85 Thread.....
- Coating for fuel tank after welding on tank
- Why lean under part throttle at low rpms? secondary diaphram?
- What's the fuel crossover tube do in a 4160 carburetor? why is it different than 4150
- High idle, secondaries not closing after driving, why?
- intake and carb installation need advice
- good place to mount fuelpump
- SBC mechanical fuel pumps
- BBC - Carb Fuel System suggestions
- How PSI drop with FPR in rear
- moon weber 48 ida manifold
- 750 Dominator HP
- Mix/match holley body and baseplate?
- Carb sucked dry after cutting off
- How to disassemble a Demon?
- Which carb for me
- Solenoid - Bump Up Throttle w/ Air Conditioning
- Valve cover breathers with dry sump system
- GM LS7 Corvette Engine ???????
- Cleaning/Polishing a Holley, what's the best way?
- What size jets should I run?
- Keep the Rochester?
- Fuel system reccomendation
- Just got my Barry grant Demon 750 DP, why is there no power valve in primary block?
- Holley 4150
- Carb. choice for Edelbrock top end kit
- 950 hp small block
- fuel system size aand parts
- electric fuel pump...where to mount
- Demon carb for 350 ho crate motor
- Need Tuning Help - Popping & Crackling Noise
- Q-Jet help!
- Barry Grant
- Return or Deadhead Regulator ?
- DEemon tuning issues, CANNOT get it to lean out, running wideband 02 whats wrong?
- Fuel pump pushrod?
- Anyone use a K&N stubstack?
- RobbMc fuel pump
- barry grant carb help please
- Fuel pressure problem
- cold air induction 67 impala with edlebork 1406
- 750vs on a small motor
- fuel line magnets
- Carb Flooding on Shutdown
- carb tuning help in CT?
- Idle Speed / Tap Throttle Back to Idle
- A/F gauge
- Need tuning advice
- squirter too big?
- revving at start up
- deletion of electric choke?
- E85 vs gasoline
- fuel issue
- Question - Location of a fuel filter.
- fuel system ?
- Best way to plumb a return line at stock tank?
- Fuel System
- vacuum line routing
- Tweaking jets on a Holley...
- Need a new Carb
- QFT parts.
- Carb Recomendation: 850CFM Double Pumper
- Fuel Question
- choke sticks...
- holley jet number?
- Holley Ultra
- idle problem
- Carb and fuel pump recommendations
- Hard Fuel Lines - 700 - 800 HP - Help Please!
- fuel pressure mystery
- Fuel Regulator
- Holley Ultra Double Pumpers
- anyone run one of these? (BG diaphragm bypass)
- Performer Vs. Air-Gap Intake
- Carter AFB tuning
- 570 SA carb
- Carb suggestions
- Weber help! 48 IDAs on a 289
- need help carb & timing
- BBC and Edelbrock Quadrajet carb
- holley 4011
- Need Help Carb Gurus
- ethanol based gas
- fuel line plumbing
- Chevy Dual Quad Air Cleaner Options??
- Bypass FPR mounted near tank
- Edelbrock Performer Q-jet ????
- Wide-Band Air/Fuel Gauge Recommendation
- Throttle cable for 69 Camaro w/Hollley 4150
- Need input on carb adjustment
- Can a factory Holley 4150 be made to work in autocross?
- Loading up @ WOT
- Data Logging for Engine Vacuum?
- YAY Holley Pumps
- Carb too big?
- 383 Lean condition?
- Need Help,Throttle Cable Set Up For 4150
- can you idenify this carb for me
- Holley Street Avenger Corrosion!!
- Sending unit w/ send and return first gen
- What Happen?
- Stalling under hard braking
- Fuel Tank Vent
- Gas Pedal-Cable style for 69 Camaro
- Suggestion on -8 line over axle
- Don't Bother With Mallory
- How much rubber fuel line can you run?
- walbro 255 (392 external) and a carb?
- Aeromotive Fuel Pump Controller
- q-jet help
- Holley Spread bore set up
- Blow-thru
- Computer controlled Q-Jet
- Opinion Please
- Motorcycle Carbs
- Holley 830 carb question
- Quality fuel sending unit?
- how to cleaning up a grimey Edelbrock Performer Carb????Help
- Doooo What......
- Fuel Feed Line Size
- Opinion on Edlebrock Carb
- Carb question
- Which carb should I be using?
- Carb Theory Help
- Idle mixture screws
- 454 tune
- Summit Carbs ???
- Poor Running zz383 Help Needed
- Carb Selection - zz383
- Throttle Plate Replacement
- Carb or EFI, If you were to do it over, would you?
- How Much Fuel Flow for 550 HP?
- sbc fuel line
- Reversion?
- Ricks SS tank for 1st Gen Camaro
- Intake Recommendation for 383
- Holley Support is no Help!
- vacuum leak test
- Aeromotive A1000
- Which Mechanical fuel pump?
- How to plumb 1/2" line to Tank?
- What Carb throttle pedal/linkage. assem/Pics
- interchangeable gaskets
- Help Correcting Strange Idle Issue
- Rick's efi tank to carb plumbing? Will it work?
- Carb suggestion for my 383 stroker.
- Off-Idle engine stumble (near stall)... how to troubleshoot/correct it?
- demon 850 idle
- full injection or carb
- Carb with better street manners for my BBC 540
- anyone have experience with Weber Carbs?
- Holley Tuning for E10
- carb tuning with wbo2 sensor...cant get it right
- carb breaking up under moderate throttle
- Custom Carburetor Spacers?
- Help Me with my Pinging issue... Please
- Gas Tank - stainless vs. zinc coated
- pro series carb
- Demon Carb needs heli coil insrts - need a kit
- Tank vs. Fuel cell
- Demon 750 problems
- Help guys!! 750 Holley Double pump over flowing on secondary side, Gas everywhere!!
- tweaking an edelbrock carb for autocross
- Carburetor Tuning in Southern California
- Help! Who knows someone at Barry Grant??!
- throttle linkage.......
- Linkage Pics
- which carb to get?
- Carb Tuning For Elevation
- Demon 750 issue
- spectre or k&n
- Cfm?
- throttle cable mounting
- Carter AVS
- 1969 quadrajet vacume advance hook up?
- I got it running and driving... tuned??? Well lets say it's rough.
- Carb and linkage for 300hp GMPP, 700R4 autocross '68 Camaro?
- mechanical fuel pump test
- mini tubbed f-body .....what fuel tank
- Idle feed restrictors VS Air Bleeds
- Carb for 383 stroker
- anyone make a lid similar to this
- trying to decide on which brand carb
- Help setting up a carbed car to drift
- Spectre Air Intake Kit
- Pro-Systems SV1 - any experience, comments, good/bad?
- Barry Grant back in buisness
- A/F Ratio tuning questions.....
- How much do PTFE fuel lines cost, any brand recommendations
- Custom Shaker Air Cleaner
- sea foam with carb
- Barry Grant badman, can't find one (ford)
- Any experiences with smaller return fuel line? Pump selection?
- Need help with Mighty Demon 650
- 4150 Lacks Throttle Response When Hot, Help Please
- Aluminum hard line
- Oil leak from mechanical holley fuel pump
- starting problems
- Steel fuel lines, what fittings to use?
- Fuel Volume Problem
- stop the gas from leaking from the fill tube
- What size jets for my 625 Demon?
- Fuel return line for a carb? ie Carb to tank?
- Engine Bogs/Discharge Nozzles/ Manual Camaro
- demon carbs, are they back?
- Help Me Build a Fuel System
- Stock 69 Camaro has 2 lines going from the tank to the fuel pump. Why?
- Wall thinkness for SS 1/2 fuel lines....
- Tuning 600cfm holley for 305 engine input needed.
- 950HP idles to fast
- how close can a carbs come to fuel injection
- Fuel Pump Suggestions..
- Air Bleeds on SD Concept Engineering Prepped Carb for Blow Through, Are these Right??
- Very Rich ... Blow Through Setup ... Ideas
- Carb Guru's, I need some help.
- Demon Carbs
- Fuel Pressure Regulator Setup..
- Breaking up in third gear
