View Full Version : Fuel Injection
Pages : [1] 2 3 4 5 6 7
  1. How hard is it to fab your own FI manifold?
  2. Ebay Accel big block fuel injection
  3. Caprice/Impala gas tank in 1st gen Camaro?
  4. Megasquirt
  5. Electro Motive
  6. TPI Combo
  7. Fuel cell in 69 Firebird/LS1?
  8. LT1 TPI on a 5.7L caddi block?
  9. 2x4 intake
  10. Fuel System??
  11. My New "victor jr" E.F.I Intake!
  12. LT1 accessory brackets
  13. Caprice to 1st gen fuel tank swap for EFI
  14. Million dollar question: What Fuel Injection?
  15. Holley Projection 4Di
  16. Who can do LS1 harness/pcm mods?
  17. LT1 injector connector height?
  18. edelbrock EFI
  19. Need some help with what kind of fuel inj.
  20. Sbf Dpfi??????
  21. It can be done.....late model fuel tank swap
  22. Legris Connectors
  23. i want to learn about fuel injection
  24. Kinsler type fuel injection?
  25. LT1 PCM Programming with Tunercat
  26. LT1 Information
  27. New markets
  28. Fuel pump locations
  29. Custom Gas Tank
  30. Calling CAMCO/Jody!
  31. LS1-T56 swap into 1st gen?
  32. Smallest Inj
  33. help me please engine problems
  34. ramjet 350 thinking about going to carb
  35. Supervictor to FI
  36. Installing wiring harness on RamJet 502
  37. ramjet 350 fs
  38. Inexpensive throttle body
  39. Holley Stealth Ram Fuel Injection With Commander 950
  40. Individual runner intake ECUs
  41. 1968 Camaro with LS1...Fuel Cell or No Fuel Cell...
  42. IAT Sensor Placement
  43. Dual Sync Distributors
  44. Bigstuff3 injection???
  45. EFI Cam/Manifold matching question
  46. ram jet help
  47. LT-1 no idle
  48. Clean injectors.. Ultrasonic cleaner?
  49. External sump to solve starving problems
  50. cheap fuel injection-non pt car
  51. Best regulator/filter setup for LS1 instal
  52. LS1 fuel system questions
  53. Need good website for APEX fuel controller!
  54. Larry C....Looking at Tony's book &.....
  55. SLP T-ram Fuel injection Firehawk
  56. Best Deals on
  57. Commander 950
  58. Carbon Fiber Airbox Question
  59. Anyone have experience with Edelbrock's EFI
  60. ls1 throttle body
  61. commander 950 software & wide band O2
  62. Injector Bungs???
  63. Commander 950 questions
  64. Outtakes from product development
  65. for sale Firehawk t-ram intake by slp
  66. Angle of the Dangle - Injector Aiming
  67. Need opinions.. BG King Sumo Fuel Pump
  68. bank to bank or SFI
  69. Charcoal canister?
  70. ram jet 350 upgrades
  71. LT1 injection identification
  72. Which gas tank was it that swaps into a Chevelle?
  73. Rock Valley gas tank
  74. Custom tank baffle questions
  75. Electromotive TEC3 MPI Info
  76. Good EFI system for a Pontiac 455?
  77. EFI Plumbing Questions
  78. Fuel Injection Conversion
  79. high/low impedence injectors
  80. Fast Xfi?
  81. Fuel injected olds 350
  82. FAST vs Commander 950
  83. Stupid f'ing vent tube.. help..
  84. Edelbrock EFI on a ZZ502??
  85. EFI conversion recommendations
  86. V6 options?
  87. EFI for my 327
  88. EFI wanted-convert SBC, LS1 or 502BB?
  89. help converting to fuel inj.
  90. LS1 in 1st Gen questions...
  91. Lt1 Help Needed
  92. Which way should I go
  93. Intresting way to route a return line
  94. A little advise???
  95. Anyone use TunerPro for hacking GM ECM code?
  96. The mules intake
  97. ECU Harness Routing
  98. sbc to lt1 conversion?
  99. LS1 carb intake swap?????
  100. MAF EFI Conversion From Quality Roadsters
  101. Hilborn-Carabine fuel inj
  102. LT1-LT4 heads,cam,intake
  103. 383 + D-1SC = which Commander 950 kit?
  104. Accel DFI versus Holley FI Units
  105. Planning ahead for FI
  106. Another Fuel Question... Will my tank work with my setup...
  107. Harrop Hurricane LS1 8TB Inlet Manifold
  108. CLT sensor, which application can I find this on?
  109. fuel rail
  110. Which EFI system. TB , TPI . S ram, St ram
  111. EFI FAQ
  112. Big Stuff 3 Questions
  113. Fuel injection cleaners?
  114. TPI for LT1 intake swap??>
  115. LT1/4 Lokar throttle Cable fit
  116. commander 950 upgrade to wideband o2
  117. Good chip reprogram
  118. LT1 fuel line weld on AN fitting
  119. Big Block Fuel Inj.
  120. Accell 77143 or 77144
  121. Elevtromotive Direct Ignition
  122. Mounting Air Temp Sender (ATS)
  123. Purchase tank now or after paint?
  124. ECM Programming
  125. Help! I can't breath(er)
  126. Accel Gen 7 issues
  127. "Ram Jet" injection to 383 & Fast Burn heads
  128. Fast Ecu (map / Tps)
  129. Which LT1 throttle body?
  130. ?'s about modifying factory GM TBI
  131. Mass Flow EFI
  132. LS1 throttle cable w/stock linkage?
  133. tpi question
  134. Advanced Induction Tech?? Good/bad? lt1
  135. Trustworthy LSx Tuner in AZ??
  136. MEFI IV.......Where?
  137. AN -6 to -5 reducer
  138. LS1 fuel filter regulator
  139. Electromotive question
  140. MEFI IV Worth it?
  141. Fuel Injection on a ZZ4
  142. Old style iron + aftermarket EFI or LSx
  143. EFI Tuner in Ontario Canada (or nearby)
  144. Fuel Tank Baffles
  145. Running Fuel Lines
  146. Hard AL fuel line?
  147. FJO wide band with comander 950
  148. Fresh engine and Fuel Injection
  149. which system for 1st timer?
  150. what's going on
  151. Force EFI?????
  152. lt1 fuel return line question
  153. Gm 572 Fueilie???
  154. throttle body adapter
  155. EFI Pontiac Help
  156. EFI School
  157. custom intake plenum
  158. BigStuff3 operating system....
  159. TPI fuel pump quesiton.
  160. Good book to learn about EFI - Recommendations
  161. Fuel Injector Question
  162. FAST xfi power adder wiring question
  163. What EFI systems are you guys running??
  164. Ricks tanks
  165. fuel pump choice?
  166. Injector Information Needed
  167. FAST or Stock LS2 computer.. what should I use?
  168. High horsepower EFI fuel system Inquiry
  169. Rick's Tanks, any problems?
  170. Is the market saturated?
  171. MOMAR Injection
  172. gen7 question
  173. Accel DFI Tuning Question, hard to start
  174. 2nd Gen. Fuel Tank Help
  175. 4cyl + FAST efi + boost = 8 injectors? (got questions)
  176. LT1 to Cowl hood cold air intake system?
  177. Fuel cell venting and fumes?
  178. Commander 950 in Chevelle
  179. modify LT-1 intake for sync distributor
  180. ZZ383 Fuel Injection Install Question** New Product**
  181. In-line pump in the tank?
  182. C950 vs FAST
  183. '99 Vortec truck w/454, but want a 502: Need help...
  184. Where to buy
  185. Fuel injector size ?
  186. Need help with TPS wiring diagram
  187. 4" aluminum tubing & bends
  188. LS1 or Aftermarket
  189. EFI throttle body size questions
  190. Fuel tank 78 T/A + LS1
  191. G-Force Cuda
  192. poly gas tank in a 1st gen?
  193. Injector O-rings
  194. Planning Fuel System
  195. Anyone running a MegaSquirt ?
  196. Fuel Line
  197. Question on return line size......
  198. LS1 / LS2 crank position sensor wiring
  199. External Fuel pump for a vortec 5.3
  200. HSR Distributor
  201. Oxygen Sensor Woes
  202. Adding a return line for my 69 Camaro
  203. EFI, Crower intake, idle problem
  204. AN fuel lines to metric sender
  205. Rick's tank or DSE tank or ?
  206. Fuel Injection for 489ci BBC
  207. Tank install
  208. What size fuel line for 502 RamJet
  209. Laptop software for commander 950?
  210. Looking to get injected! Which system to buy?
  211. Anyone have an LT1 wiring diagram?
  212. Does anyone make a FI set up for Olds big blocks?
  213. Holley EFI fuel pump cycles.
  214. What wall thickness for cold air intake?
  215. Ferrari Fuel Injection
  216. Big Stuff 3 fuel inection
  217. Setting-up Distributor for Big Stuff 3
  218. LT1 ECM with crank trigger on earlier motor?
  219. big stuff 3
  220. LT1 Fuel Pressure Issues - Please help!
  221. Which System for budget
  222. Question on Hard lines and AN Fittings
  223. Fuel Line Strain Relief?
  224. Mega Squirt Controllers
  225. Mustang Tuners for 92 5.0 in Cali
  226. Crossfire Injection
  227. TBI fuel pump
  228. Massflowefi
  229. EFI University...anyone ever been?
  230. World 427 aluminum block/heads
  231. "QUIET" fuel pump
  232. Thinking of dumping my Comander 950 Pro wideband but for what?
  233. Looking For Qualified Dyno Shop for DFI Set-Up
  234. TBI Speed Sensor
  235. Hilborn Fuel Injection Tech info. It works!!
  236. Are there any Ram Jet fuel injection people...
  237. 502 RJ Injector Plugs PITA!
  238. charger running rich
  239. Obd1 Tuning
  240. how to switch to big stuff 3......
  241. Question on knock sensor placement...502RJ
  242. EFI bits....
  243. External fuel pump for EFI conversion
  244. which efi for my setup???
  245. Help phasing rotor with BS3 and MSD-2345
  246. Any opinions on the Arizona Speed & Marine "ram intake"?
  247. Anyone running a BigStuff3 on a 427/454/502
  248. Which EFI controller to use?
  249. e85/alcohol friendly fuel system
  250. Very poor idle quality, can't tune out the surge. Suggestions?
