- Injector O-rings (1 replies)
- poly gas tank in a 1st gen? (2 replies)
- G-Force Cuda (0 replies)
- Fuel tank 78 T/A + LS1 (2 replies)
- EFI throttle body size questions (17 replies)
- LS1 or Aftermarket (4 replies)
- 4" aluminum tubing & bends (6 replies)
- Need help with TPS wiring diagram (2 replies)
- Fuel injector size ? (6 replies)
- Where to buy (4 replies)
- '99 Vortec truck w/454, but want a 502: Need help... (12 replies)
- C950 vs FAST (2 replies)
- In-line pump in the tank? (2 replies)
- ZZ383 Fuel Injection Install Question** New Product** (5 replies)
- modify LT-1 intake for sync distributor (2 replies)
- Commander 950 in Chevelle (1 replies)
- Fuel cell venting and fumes? (15 replies)
- LT1 to Cowl hood cold air intake system? (6 replies)
- 4cyl + FAST efi + boost = 8 injectors? (got questions) (13 replies)
- 2nd Gen. Fuel Tank Help (0 replies)
- Accel DFI Tuning Question, hard to start (2 replies)
- gen7 question (6 replies)
- MOMAR Injection (0 replies)
- Is the market saturated? (13 replies)
- Rick's Tanks, any problems? (3 replies)
- High horsepower EFI fuel system Inquiry (18 replies)
- FAST or Stock LS2 computer.. what should I use? (4 replies)
- Injector Information Needed (4 replies)
- fuel pump choice? (9 replies)
- Ricks tanks (5 replies)
- What EFI systems are you guys running?? (20 replies)
- FAST xfi power adder wiring question (2 replies)
- Fuel Injector Question (9 replies)
- Good book to learn about EFI - Recommendations (10 replies)
- TPI fuel pump quesiton. (4 replies)
- BigStuff3 operating system.... (8 replies)
- custom intake plenum (8 replies)
- EFI School (0 replies)
- EFI Pontiac Help (7 replies)
- throttle body adapter (5 replies)
- Gm 572 Fueilie??? (3 replies)
- lt1 fuel return line question (6 replies)
- Force EFI????? (25 replies)
- what's going on (10 replies)
- which system for 1st timer? (4 replies)
- Fresh engine and Fuel Injection (5 replies)
- FJO wide band with comander 950 (1 replies)
- Hard AL fuel line? (8 replies)
- Running Fuel Lines (2 replies)
- Fuel Tank Baffles (2 replies)
- EFI Tuner in Ontario Canada (or nearby) (0 replies)
- Old style iron + aftermarket EFI or LSx (9 replies)
- Fuel Injection on a ZZ4 (4 replies)
- MEFI IV Worth it? (10 replies)
- Electromotive question (2 replies)
- LS1 fuel filter regulator (3 replies)
- AN -6 to -5 reducer (2 replies)
- MEFI IV.......Where? (15 replies)
- Trustworthy LSx Tuner in AZ?? (4 replies)
- Advanced Induction Tech?? Good/bad? lt1 (2 replies)
- tpi question (4 replies)
- LS1 throttle cable w/stock linkage? (3 replies)
- Mass Flow EFI (18 replies)
- ?'s about modifying factory GM TBI (2 replies)
- Which LT1 throttle body? (10 replies)
- Fast Ecu (map / Tps) (6 replies)
- "Ram Jet" injection to 383 & Fast Burn heads (7 replies)
- Accel Gen 7 issues (7 replies)
- Help! I can't breath(er) (15 replies)
- ECM Programming (3 replies)
- Purchase tank now or after paint? (1 replies)
- Mounting Air Temp Sender (ATS) (6 replies)
- Elevtromotive Direct Ignition (2 replies)
- Accell 77143 or 77144 (5 replies)
- Big Block Fuel Inj. (2 replies)
- LT1 fuel line weld on AN fitting (19 replies)
- Good chip reprogram (7 replies)
- commander 950 upgrade to wideband o2 (3 replies)
- LT1/4 Lokar throttle Cable fit (5 replies)
- TPI for LT1 intake swap??> (1 replies)
- Fuel injection cleaners? (8 replies)
- Big Stuff 3 Questions (12 replies)
- EFI FAQ (9 replies)
- Which EFI system. TB , TPI . S ram, St ram (11 replies)
- fuel rail (1 replies)
- CLT sensor, which application can I find this on? (1 replies)
- Harrop Hurricane LS1 8TB Inlet Manifold (8 replies)
- Another Fuel Question... Will my tank work with my setup... (7 replies)
- Planning ahead for FI (8 replies)
- Accel DFI versus Holley FI Units (7 replies)
- 383 + D-1SC = which Commander 950 kit? (4 replies)
- LT1-LT4 heads,cam,intake (14 replies)
- Hilborn-Carabine fuel inj (6 replies)
- MAF EFI Conversion From Quality Roadsters (1 replies)
- LS1 carb intake swap????? (24 replies)
- sbc to lt1 conversion? (3 replies)
- ECU Harness Routing (3 replies)
- The mules intake (12 replies)
- Anyone use TunerPro for hacking GM ECM code? (13 replies)
- A little advise??? (1 replies)
- Intresting way to route a return line (4 replies)
- Which way should I go (4 replies)
- Lt1 Help Needed (1 replies)
- LS1 in 1st Gen questions... (22 replies)
- help converting to fuel inj. (10 replies)
- EFI wanted-convert SBC, LS1 or 502BB? (2 replies)
- EFI for my 327 (0 replies)
- V6 options? (2 replies)
- EFI conversion recommendations (2 replies)
- Edelbrock EFI on a ZZ502?? (0 replies)
- Stupid f'ing vent tube.. help.. (21 replies)
- FAST vs Commander 950 (1 replies)
- Fuel injected olds 350 (1 replies)
- Fast Xfi? (2 replies)
- high/low impedence injectors (7 replies)
- Fuel Injection Conversion (14 replies)
- EFI Plumbing Questions (1 replies)
- Good EFI system for a Pontiac 455? (8 replies)
- Electromotive TEC3 MPI Info (5 replies)
- Custom tank baffle questions (11 replies)
- Rock Valley gas tank (12 replies)
- Which gas tank was it that swaps into a Chevelle? (2 replies)
- LT1 injection identification (1 replies)
- ram jet 350 upgrades (14 replies)
- Charcoal canister? (9 replies)
- bank to bank or SFI (6 replies)
- Need opinions.. BG King Sumo Fuel Pump (0 replies)
- Angle of the Dangle - Injector Aiming (13 replies)
- for sale Firehawk t-ram intake by slp (1 replies)
- Outtakes from product development (0 replies)
- Commander 950 questions (4 replies)
- Injector Bungs??? (1 replies)
- commander 950 software & wide band O2 (1 replies)
- ls1 throttle body (3 replies)
- Anyone have experience with Edelbrock's EFI (5 replies)
- Carbon Fiber Airbox Question (2 replies)
- Commander 950 (2 replies)
- Best Deals on (3 replies)
- SLP T-ram Fuel injection Firehawk (6 replies)
- Larry C....Looking at Tony's book &..... (3 replies)
- Need good website for APEX fuel controller! (0 replies)
- LS1 fuel system questions (3 replies)
- Best regulator/filter setup for LS1 instal (4 replies)
- cheap fuel injection-non pt car (3 replies)
- External sump to solve starving problems (10 replies)
- Clean injectors.. Ultrasonic cleaner? (1 replies)
- LT-1 no idle (0 replies)
- ram jet help (1 replies)
- EFI Cam/Manifold matching question (4 replies)
- Bigstuff3 injection??? (21 replies)
- Dual Sync Distributors (1 replies)
- IAT Sensor Placement (1 replies)
- 1968 Camaro with LS1...Fuel Cell or No Fuel Cell... (8 replies)
- Individual runner intake ECUs (10 replies)
- Holley Stealth Ram Fuel Injection With Commander 950 (21 replies)
- Inexpensive throttle body (11 replies)
- ramjet 350 fs (5 replies)
- Installing wiring harness on RamJet 502 (2 replies)
- Supervictor to FI (3 replies)
- ramjet 350 thinking about going to carb (8 replies)
- help me please engine problems (2 replies)
- Smallest Inj (13 replies)
- LS1-T56 swap into 1st gen? (13 replies)
- Calling CAMCO/Jody! (5 replies)
- Custom Gas Tank (7 replies)
- Fuel pump locations (4 replies)
- New markets (29 replies)
- LT1 Information (6 replies)
- LT1 PCM Programming with Tunercat (3 replies)
- Kinsler type fuel injection? (28 replies)
- i want to learn about fuel injection (6 replies)
- Legris Connectors (3 replies)
- It can be done.....late model fuel tank swap (9 replies)
- Sbf Dpfi?????? (1 replies)
- Need some help with what kind of fuel inj. (6 replies)
- edelbrock EFI (14 replies)
- LT1 injector connector height? (5 replies)
- Who can do LS1 harness/pcm mods? (22 replies)
- Holley Projection 4Di (3 replies)
- Million dollar question: What Fuel Injection? (5 replies)
- Caprice to 1st gen fuel tank swap for EFI (1 replies)
- LT1 accessory brackets (19 replies)
- My New "victor jr" E.F.I Intake! (11 replies)
- Fuel System?? (7 replies)
- 2x4 intake (16 replies)
- LT1 TPI on a 5.7L caddi block? (2 replies)
- Fuel cell in 69 Firebird/LS1? (3 replies)
- TPI Combo (1 replies)
- Electro Motive (14 replies)
- Megasquirt (2 replies)
- Caprice/Impala gas tank in 1st gen Camaro? (17 replies)
- Ebay Accel big block fuel injection (4 replies)
- How hard is it to fab your own FI manifold? (23 replies)
