View Full Version : Fuel Injection
- Help with fuel return for injection?
- Spectra Fuel Tank pump we a bad fuel pump
- Fuel pressure problems
- BS3 Tuning
- EFI and Rhoads lifters ?
- EFI DIY Serge Tank Idea?
- Let's get all this surge tank stuff straightened out.
- Looking for a good DFI tuner in the DFW area.
- Anyone running a Megasquirt controller?
- Carb to EFI conversion
- Fuel pump controler with XFI or not.
- Rear mounted return system
- Fuel Line Sizing
- need help for my fuel system for my blown LSX
- What size injectors should I use?
- Another surge tank plumbing question.
- walbro vs stock vs racetek
- EFI Tuner in Sacramento norcal area?
- EFI Tank Options for 2nd Gen (74-77)
- making a disc from Accel DFI....
- Holley's new EFI SEMA/PRI Brochure
- Saturday EFI install 355 69 Camaro
- efi fuel system for a 67 Camaro
- rotor phasing
- braided fuel lines took a crap
- Reprogramming LT1 ECU
- SOS LT1 help
- Throttle body mm = CFM
- A1000 mounting pics needed
- LT1 going lean
- problems with 02 sensors (keep having to replace them )
- odd TBI problem
- Anybody swap a direct injected engine in anything?
- Regulator location
- EFI conversion, need some direction...
- Holley TBI on a Pontiac motor
- EFI Mopar project
- Running very rich
- Accel Thruster single TB - set for 4 injectors?
- injector boss
- lsx fuel system
- LS1 throttle body silicone coulper
- fuel pump
- Mike Norris Motorsports EFI Tuning In Your Area
- factory lsx fuel pumps
- In-tank pump
- Returnless fuel system
- FAST EZefi question
- Whistles under light throttle
- efi vac adv
- Owners of Rick's Tank?
- Hardline Question
- Cormaro ignition works but no injector fuel ?
- Aeromotive 13109 Regulator
- Chevelle EFI install...
- Who's Using Tanks Inc PA-4
- Accel DFI gen 7 tuning....
- Is this a reasonable starting point for ignition timing?
- Ful Line Routing, Which Side?
- Opinions on Powerjection III from Professional Products
- TPI tips?
- list of individual throttle bodie companys
- Stumbling after Walbro in-tank pump install
- typhoon
- Stack injection
- GM TBI conversion on small block mopar
- EFI pump - Regulate to carb pressures?
- In-tank corrugated pressure hoses.
- Stock tank dimension needed.
- Whos running megasquirt?
- TBI on a 400+hp 406 sbc?
- Fuel hose that will stand up to todays fuel.
- stock fuel tank --> fuel cell?
- Electric Fuel pump mounting 67 GTO
- EFI cams. What are you using for brands and specs?
- FAST XFI help... stopped running.
- Spectra Fuel pump
- LT1 injectors - SVO, LS1 upgrade? Help, car is apart!
- Accel DFI - Dual Synch Distributor Failure
- Holleys new EFI
- 3.4 camaro SFI fuel line question
- what FI for my engine?
- FAST™ XFI™ Fuel Injection Training Course Open For Enrollment
- 489 FE EFI runs!
- Fuel pressure regulator location?
- Tank options for 67 efi camaro
- need help planning a fuel system
- Noisy fuel pump
- Where to buy fuel pump and hoses?
- Holley avenger efi 550-811
- Why Does My Fuel Presure Drop
- Do I need to be concerned about electrolysis in my FI plumbing
- power loss while turning
- V12 FI system
- OK my magazine is missing on swapping an LT1 intake,
- Aeromotive 1000 EFI fuel pump
- Code 66 Accel DFI shutting off ?
- Hard line flaring 5/8?
- ECU battery?
- Accel DFI code 66 ignition output driver over current
- Fuel Accumulator......
- camshaft position sensor wiring
- accel dfi problem
- Fuel system for a LS7 in 67 Camaro
- Clean a tank after grinding on it?
- Road Runner is now fuel injected
- Fuel Tank Differences
- Small Parts for building a fuel tank?
- Inside an Impala fuel tank
- Need help with send and pump wire on EFI tank
- Fuel Pump sizing for 700HP
- Target injector timing,rev limit settings. What's yours at?
- efi on a soild lifter chevy?
- Accel Gen7 tuning issues
- Fuel coming out vent
- distributorless ignition
- 3.4 swap using 7727 ecm wiring questions
- Cleaning fuel injectors?
- Fuel tank fabrication advices
- Fuel lines along the transmission tunnel
- 3'' aluminum tubing
- Fuel Line Fitting Assembly Lube, Hardware Store Equivalant?
- best buy on Accel gen 7?
- What gear should i be tuning in?
- Fuel Reservoir How To
- All this talk about fuel reserviors...
- Pieceing together FAST & GM OBDI fuel injection
- Inline tube fuel lines are they any good?
- Not so EZ-EFI Question
- EFI Manifold conversion
- fuel pressure question
- pro-flo problems
- Fuel leak
- Help from efi experts please....
- ls2 wire harness
- In tank fuel pump - which one?
- Mass Flo EFI.....good alternative?
- Air Cleaner challenge
- is this kit worth it? e-brock pro-flo
- Accel sensors MST, ESC
- Accel 7 tuning
- huge idle/dying issue
- Edelbrock/Carter AFB into throttle body?
- electric wires in gas tank?
- looking at different idea's for LSX intakes.
- 100 miles on Sunday with the Massflo 489 cid FE!
- Injection cleaner
- Ez-efi
- Hi guys
- EFI Brainstorming
- what tank do you guys suggest???
- Fuel Injection And a Formula Hood
- EZ EFI, Holley Avenger, OR Quick Fuel Carb - Advice?
- Looking for a fuel shutoff valve?
- FAST Expert Needed - Dist Issues
- 70 Chevelle Fuel Injection setup..help needed
- Barcode on LS fuel rail???
- Fuel line question
- Is buying tuning software and learning to tune yourself insane?
- Looking at EFI
- best Route for sumping stock tank
- Rock Valley or Rick's Tanks
- Who has a Glenns Performance gas tank?
- Looking for Accel DFI / Thruster cal
- EFI help
- modify your own tank?
- Making my own Injection
- Problem with Idle and restart
- Notching RV Fuel Tank
- idle fluctuation and engine dying
- plumbing the fuel system
- Anyone else gone with TBI?
- How did you plumb your fuel injection
- Spectra FI Gas Tank fuel gauge help 6.0 Swap Fuel injection
- Fuel pump sending assembly for spectra tank GM32AFI
- Anyone use tube tech efi lines?
- What is the concensus for regulator placement?
- Edelbock Pro-Flo XT BBC rectangle port intake + 102mm TB?
- C5 fuel tanks into 1st gen
- Chevelle in-tank pump
- Low fuel pressure Rick's tank
- 1974 nova narrowing stock tank
- Jeg's AN Push-Loc fittings?
- Kinsler BBC crossram?
- fuel pump losing prime/corvette style filter
- setting cold idle on PowerJection 1 system
- EFI tuning, Need some help.
- Ricks Fuel Tank Question
- PTFE/Teflon Fuel Hose
- Projection III
- Can you run a TBW throttle body on a Holley Stealth Ram intake?
- Anyone running an AEM controller
- holly dominator efi
- Intank fuel pump into a non EFI fuel tank
- Real low spark advance on start up
- Anyone use the Megasquirt 3 boards with a healthy higher rpm combo?
- EFI intake options for vortec heads
- EFI 58x and 24x Relutor crank sensor for Early SBC
- MAT sensor location
- What Fuel Filter to Install?
- Fast crank trigger 301180
- Still running really cold
- Help with Pictures on Your Fuel Line Routing at the Motor
- Hardline vs. Teflon Braided
- Throttle bodies with TH 350, 200R stud placement
- Fuel Regulator & Filter selection for LS
- GM LS Computer Running Older Engine...Possible?
- EZ EFI idle drops significantly when in gear...
- Aftermarket EFI + catalytic converters + CA legal
- Aluminum Intake runner - gauge size?
- any one running spectra gm32 tank in 1st gen camaro
- Use older FAST system or get the newer XFI?
- Fuel rail options for Fast Manifold
- What is this fitting?
- Aftermarket EFI with OBD2?
- '63 Vette Fuel Injection
- Which fuel tank should use?
- any 1st gen camaro's running sumped tank external fuel pumps with ls swap
- Anybody familiar with BigStuff 3
- Anybody Good with holley Pro-Jection systems?
- Anybody using new Spectra GM32BFI tank with internal baffles and sump?
- How to make a sumped tank?
- Teflon hose and fittings
- Fuel overheating
- 68 camaro LT1 to Rick's tank fuel line length???
- Ez-efi or xfi ????
- Help! Which EFI system is best for an 8-71 Blown SBC 406 CI?
- EZ EFI fuel system plumbing (mopar content, but any help is appreciated)
- Any sponsers a dealer for Nick Williams?
- Kicked out of the Garage!! EZ EFI fuel line odors.
- Fuel Pumps and pluming help needed.
- Help me verify FAST Fuel Rail pt#
- Spectre tank pump rating
- Help me make a shopping list!! (injectors, pump)
- 95 LT1 running rich
- homemade fuel injection system what will I need?
- redline weber efi
- Throttle body size advice
- Help me find fuel lines
- 70 Chevelle LS6 - Should I put an EFI?
- 2010 camaro pump and Ricks Tanks
- Carb to EFI - Need help..
- Fast EFI question
- Need some help figuring out where to start troubleshooting the wife's 01 Tahoe
- Russel Fuel rail adapters for LT1 to AN-6?
- injector size
- vapor lock heat problems
- EZ EFI Problems: someone has to be able to help.....
- Ez efi
- touring 70 monte, convert to FI
