View Full Version : Fuel Injection
Pages : 1 2 [3] 4 5 6 7
  1. Anybody use this tank?
  2. injector brand
  3. ls1 or big block aftermarket fuel injection?
  4. Could someone explain returnless systems?
  5. lt1 question
  6. Injector interchangeablitity
  7. ECM prom identification
  8. lt1 guy's
  9. LQ4 carb going to EFI and have some questions.
  10. Low Z VS High Z injectors?
  11. fuel return into the bottom of tank??
  12. Newbie to FI - Fast XFI or Something Else....
  13. laguna4efi Help please with XFI can link
  14. Painless setup for trans and tpi
  15. Anyone using the Tanks Inc. sump with in tank fuel pump?
  16. Rick's Fuel Tank Fitment Question
  17. what aluminum to use for intake plenum
  18. TBI sizing w/ single turbo
  19. What return style Fuel Pressure Regulator for Carb with EFI In-Tank Pump?
  20. "How I Fuel Injected My Pontiac 400"
  21. Edelbrock pro flo upgrades
  22. Tube AN Nuts
  23. Fast-MSD?
  24. Norris Motorsports Is Now A PT Sponsor
  25. keeping fuel tank vent: pros/cons?
  26. what hi pressure fuel line do you use?
  27. camaro keeps dying
  28. Anyone paint or shrink wrap their fuel injectors to a different color???
  29. Is it worth it?
  30. What type of FI system to use?
  31. Intake manifold options for a big inch small block Chevy
  32. Where to find a good selection of 4" intake pieces?
  33. BS3 and a sbf
  34. MAP sensor location
  35. in tank efi pump conversion kit
  36. Russell braided SS fuel line failure
  37. Professional Products FI
  38. What regulator and filter with ricks tank ?
  39. AF ration vs. HEGO voltage
  40. OEM prefilter Walbro pump...do i need another filter
  41. Help with Holley Stealth Ram and intake filter
  42. Fuel tank venting
  43. Another fuel tank vent question
  44. Aftermarket ECM
  45. lt1 engine problems!
  46. What kind of fuel pressure regulator?
  47. II Much cold start: an update
  48. Efi 540
  49. TPI question
  50. Accel DFI Error when connecting to ECM
  51. turbo and TBI fuel system
  52. BigStuff3 Crank Reference angle problem
  53. Lean tip-in bog with Accel DFI
  54. what went wrong?
  55. 86 305 tpi
  56. EFI hose information
  57. can't get TPI engine fired
  58. CAI for my driver
  59. Fuel Injector Question
  60. StealthRam Injector Replacements
  61. Holley Commander 950
  62. Newb EFI?
  63. whats going on here... EFI with return line
  64. Holley Pro-Jection MPI
  65. Is it typical for fuel pumps to whine when they suck in a little air?
  66. LS1 in 68 Camaro have fuel pump question
  67. Thoughts on my Fuel Re Plumb
  68. Fuel pump PSI
  69. Dumb question - AN to tube adapter fittings
  70. F.A.S.T. system w/erratic idle-wtf?
  71. A1000, stock fuel tank w/ baffling okay?
  72. RamJet 502... stumbling
  73. Ls1 Tank for 1st gen question
  74. Map sensors. Does the connector change depending on the BAR?
  75. walbro fuel pump source
  76. how to get wiring into fuel tank?
  77. Fuel Line
  78. what sender and float should I use?
  79. Fuel System: New to AN. (Help!)
  80. Pre pump surge tank
  81. LT1 Idle problem solved....
  82. electromotive tec3
  83. New Steel Tank (Pics), Should I coat or paint it?
  84. 502 RamJet issues. Please help!!!
  85. Edelbrock mpfi
  86. Routing LT1 coolant/steam lines from back of heads?
  87. Trying to use a factory sender in a modified stock tank...will it work. Pics
  88. EFI questions need advice
  89. Edelbrock 1st Gen Pro-Flow & LC-1 Wideband Integration
  90. AN fittings for walbro external fuel pump
  91. HELP! Racepak (IQ3) to MEFI 4B Interface
  92. Help with FAST XFI Startup
  93. Ramjet frustration
  94. Belt Driven Fuel Pump
  95. Fuel injected 572 problems
  96. Parallel vs. dead head
  97. Edelbrock Pro-flo 2 for b.b.c.
  98. TPS Eratic
  99. Fuel Lines - 900 HP - What to use from tank?
  100. Accel DFI wiring - will not start
  101. Diy Cold Air Intake?
  102. CFI to single TBI
  103. Pics & Video of my problems with Edelbrock Closed Loop Function
  104. Accel DFI tuner in PA/NJ
  105. manifold question?
  106. OBDII port and tuning cable information needed
  107. Which is cheaper?
  108. Accel DFI 6.0 Sequential
  109. carbon fiber cold air intake
  110. Which throttle body to use?
  111. Priming EFI Pump before first start - no pressure
  112. blowing boost through a 4500 tb
  113. How should I feed my Lq9?
  114. Fuel pump ratings
  115. what throttle bodies for twin set up???
  116. Ford Mustang TB on TPI/ LT1
  117. Modified Lt1 intake?
  118. Spectra Fuel Tanks....
  119. any body ever heard of or used this system?
  120. has anyone gotten into bins and chip burning?
  121. can i use a stock tpi chip?
  122. Need FI advice - ZZ502
  123. Which DFI to use?
  124. Changing injectors
  125. Pontiac 455 EFI inatake manifolds
  126. Mega Squirt fuel injection who runs it and how do you like it?
  127. Setting Fuel Pressure
  128. Thoughts on Holley ProJection system?
  129. What to do with leftover ports on the gas tank???
  130. fuel pressure problem
  131. ACCELL GEN 8 vs BS3
  132. Where can I find a set of 8 Noid lights?
  133. Bung placement for FI Regulator return line on stainless tank.
  134. wiring the 4DI blues
  135. Pressure Fluctuations
  136. TPI Runner Dents
  137. Fuel delivery questions...
  138. Pro Flo and Data Acquisition
  139. Whats a good price for an ACCEL Gen Vii (77022) DFI system?
  140. Aeromotive fuel filters: how to tell them apart?
  141. Accel Thruster DFI - Narrow vs Wide O2
  142. EFi Fuel pump, in-tank or external?
  143. F -body EFI tanks with sump!
  144. 600HP with a TPI 383?
  145. Which efi system for small block chevy?
  146. FAST XFI discovery
  147. 68 Camaro Fuel Line Suggestions
  148. Another fuel line question
  149. IAC Solenoid
  150. Ricks SS tank prices
  151. LS1 fuel regulator & Projection ?
  152. MAF Sensor and cold air intake
  153. PRO-FLO Shutter Wheel
  154. What fuel pressure regulator do you like?
  155. Fuel Pump Locking Ring???
  156. zz4 fast efi tune needed
  157. summit 42lb injectors vs Ford 42lb injectors
  158. LS1 fuel line & pump expeirences / ?'s
  159. Fast ez-efi
  160. Complete Budget Friendly EFI - Thoughts?
  161. Tuning trouble with a BS3... ideas?
  162. rear return system questions
  163. Remote IAC motor
  164. Quick FPR Question
  165. What fuel system to use with a 540 blower motor?
  166. DSE narrowed tank with LS fuel pump installed, question?
  167. EFI Throttle Body Spacer Size
  168. The "amcmike" Retrotek Powerjection III thread
  169. stainless fuel line and beeding
  170. Rick's tanks at the track
  171. efi for a 500 -650 hp bbc whats out there
  172. ? About Fuel Injector Sizing
  173. BBC Oval Port EFI Conversion, Good Start??
  174. lt1/t56 swap in an 81 malibu??
  175. 625HP Big Block - EFI Recommendation?
  176. F.I. Opinon
  177. ? About aluminum tubing and FI pressure
  178. fuel injection tank
  179. Fuel Injected vs. Carburetor?
  180. What to use for fuel line
  181. Electric pumps and fuel tanks for camaro's
  182. what fuel pump will be sufficient?
  183. 502 Ram Jet FI
  184. sheet metal intakes and ITB's for SBC?
  185. EFI Six-Pack - F&B ?
  186. Fuel Tank Advice..Stock tank with EFI setup?
  187. external anti-surge tank with A1000
  188. Rock Valley tanks at the track
  189. MAF on turbocharged engine
  190. O2 sensor placement for Gen 7 DFI
  191. FAST XFI and Dual Sync, Frank S are you around?
  192. Need to find Edelbrock part or replacement.
  193. Fuel Line Mounting Brackets?!?!?!
  194. How to choose fuel rails?
  195. Would this work for in tank EFI pump
  196. Accel dual sync distributor installation ,HELP
  197. Rock Valley and DSE Gas tanks
  198. What throttle assy. for 68 w/Commander 950
  199. Fast EZ EFI
  200. charcoal canister?
  201. 92 Corvette fueling problem
  202. Cts v6/man 5 spd conversion
  203. Recommendations for LT1 PCM custom programming
  204. efi tanks
  205. quick connect fitting on both ends?
  206. Throttle body adapters from 4500 to 4150 style are they any good ?
  207. Fuel regulator opinions
  208. Vortec distributor cap
  209. Making EFI harness. Any hints?
  210. Roadrunner Emulator
  211. Need electrical help with new RetroTek EFI
  212. Efi 409
  213. Cold Air Intake-need input
  214. late model engine hand held programmer
  215. How to choose a MAP sensor?
  216. tbi questions
  217. MSD box or not with Fast XFI
  218. Best Fuel Tank low budget
  219. Should I go narrow or wide band?
  220. FAST Dual Sync Dist, **BEWARE**
  221. nawowed gas tank
  222. Fuel tank for EFI 70 Mustang
  223. 6.3 hemi tuning help
  224. Anyone know what the cost to check Fast classic ECU
  225. Worm clamps for FI lines - what are the facts?
  226. MAP sensor vacuum question
  227. AFR vs Fuel mileage. What have you seen?
  228. Deceleration Fuel Cut-Off option. Use it or not?
  229. What's a aMEFI-4 controller worth?
  230. Injector Cleaning Questions
  231. B-Body Tank Swap
  232. Fuel line routing at fuel rails
  233. Pics of Holley Stealth Ram?
  234. Does Earl's pro lite 350 give off fumes?
  235. How big of a line for 600 HP with an in-tank pump?
  236. what are you FI guys doing fuel system wise in your cars?
  237. Race style custom stainless fuel tank
  238. Used A1000 fuel pumps
  239. Opinion on port injected rail feed / return design
  240. RetroTek EFI - electronic fuel pump problem
  241. edelbrock injection
  242. Intake temp sensor (Air charge temp sensor) location
  243. Accel fuel rail regulator.......
  244. Fuel line help needed
  245. Building my own system ?'s
  246. Fuel Hose
  247. Dual cold air intake
  248. intermediate crank signal
  249. Couple of Ford EEC-IV questions
  250. Fuel Tanks?
