View Full Version : Fuel Injection
Pages : 1 [2] 3 4 5 6 7
  1. Gen 7 troubles
  2. Fuel Rails??--Vortec 8.1
  3. just felt like showing....
  4. XFI dealers?
  5. pre sumped factory fuel cells
  6. DIS ignition
  7. 99 C5 fuel filter/regulator
  8. Pontiac EFI?
  9. Big Stuff 3 tuning ?
  10. Ram Jet fuel pump
  11. Fuel lines: Classic tube or Inline tube
  12. What's a neat way to run fuel lines down frame?
  13. stock hood
  14. Has BigStuff3 gone out of business?
  15. Ford cam positioning sensor
  16. OK, I finally decide on to go fuel injection...now which system?
  17. I found a Accel Gen 6 forsale ECu #74046.
  18. Fuel pressure regulator plumbing
  19. What is the best low budget EFI system?
  20. Adapting GM or Ford distributorless Ignitions to Mopar Engines
  21. EFI fuel line tubing
  22. TPI Rev issues/Limp Mode?
  23. Any edelbrock pro flo injection users?
  24. 73 Camaro, Efi, Fuel Tank Barry Grant King Sumo.
  25. 2 gen Camaro fuel tank....
  26. TPI injectors
  27. Speed Scene EFI Harness - Anyone use/comments?
  28. Edelbrock EFI hardware
  29. EFI throttle body ratings
  30. Which External Fuel Pump??
  31. OK guys I have a new FI setup in prototype,,
  32. Accel Gen VII?
  33. What do I need?
  34. EFI regulator plumbing
  35. 90 deg. AN flare to pipe installed - want facing opp. direction
  36. Crank Trigger for Pontiac 455
  37. ram jet
  38. Finding a seeping fuel leak
  39. BossEFI™ - The World's First Turnkey EFI System???
  40. LT-1 Retrofit Questions
  41. Fast Edist +ls1 coils
  42. FAST Questions
  43. Fuel pump speed controller
  44. Holley Commander 950 MPFI
  45. Accel Gen VII DFI
  46. couple efi questions
  47. AutoTap?
  48. Butler EFI for Pontiac...who has it?
  49. What HP can a 3/8" supply line feed without problem?
  50. Need help on EFI
  51. Fuel pump questions
  52. A1000 fuel pump question
  53. tbi or mpi????
  54. Aeroquip hose + Russell Fitting = problem?
  55. What Injectors to use?
  56. Accel Gen 7 firmware upgrade
  57. Fuel injection plumbing Suggestions
  58. Need help determining fuel filter fitting size.
  59. Suggestions for fuel filter
  60. Difference in LS1 vs LT1 style gas tank
  61. Intake Manifold Choice for EFI - Pontiac
  62. IAC options for a stealth ram
  63. Fuel pump for 600hp
  64. spacers and performance
  65. racepumps.com and EFI
  66. Engine mount question, Lt1 Engine in a 1969 camaro.
  67. Ram Jet crate engine diagnostic tools
  68. 502RJ Dips below Idle, Then Comes Back
  69. Accel GEN 7
  70. specs for every fuel injector (almost)
  71. EFI Recommendations - Blown Early Hemi
  72. 502 Ram Jet w/Holley Commander
  73. 305 tpi on 350 short block
  74. Custom plenum to sit on traditional manifold
  75. Fuel rail pressure dampner
  76. Fuel fittings for EFI
  77. 69`Camaro with 92`LT 1=> bad idle&throttle response
  78. Holley Commander 950
  79. BG Mighty Enduru, Regulator and Line Questions
  80. Fuel pump
  81. Fuel Pump question
  82. Delphi Electronics MEFI4 InGenius software
  83. whats the best EFI for a 406?
  84. Is this throttle body any good
  85. Ricks Stainless tank question
  86. LT1 Throttle Body water outlet
  87. Most reliable TBI-style injection system?
  88. What 502RJ TPS Adjustment specs?
  89. Bs3 ??
  90. running gauges in parallel with sensors
  91. Is the 502RJ MAP a 1 or 2 Bar?
  92. Injector interchangeablity
  93. MAF or Speed Density
  94. BBC Accel SuperRam
  95. stock tpi throttle bodies x4
  96. 96 LT1 with wire loom, where to now
  97. Throttle bodies with tranny kick downs
  98. Where to install fuel return fitting in tank
  99. Fuel tank venting
  100. saturated or peak and hold
  101. Megasquirt????????????
  102. 650 HP Injector size?
  103. Fuel pump size??
  104. TPI Vortec vs Regular
  105. Fast Fuel Injection-Timing HELP ?
  106. Wilson Manifolds V-Force efi
  107. TPI for fastburn heads?
  108. I want to drive my car! Who makes the cheapest pop on EFI system?
  109. Need fuel tank advice.
  110. O2 Sensor mounting
  111. NE1 near Indianapolis, IN that can tune an LT1?
  112. Need advice on aftermarket computer
  113. Mast M90 ECM
  114. Y block on fuel lines or not
  115. BigStuff3 and Weldon Fuel pump controller.
  116. Commander 950 idle issues
  117. Lt1 swap help
  118. Big Stuff 3 handle 4l80e
  119. Running Rich With Bigger Throttlebody?
  120. Fuel Pump size???
  121. XFI, fuel pump, fan connection
  122. Ricks fuel tank...
  123. Crank Trigger or Dual Sync Distributor?
  124. Another fuel system question
  125. Regulator vac/pressure port?
  126. Fuel tank construction
  127. xfi air temp sensor location
  128. Cleaning fuel injectors?
  129. dual plane mpfi?
  130. XFI, no crank signal, msd trigger
  131. need help!!
  132. XFI efi compatibility
  133. LS2 Fuel Line Help
  134. 3rd gen sending unit in a 2nd gen tank
  135. Positioning of intank pump
  136. Tpi 350 Motor Questions Fuel Lines
  137. TPI Injectors
  138. More LT-1 woes
  139. Fuel tank?
  140. Fuel Cell or stock tank for EFI? Pros? Cons?
  141. Suggestions for cam position sensor (SBC)
  142. what is the best way to tune a 502 ramjet?
  143. single wideband
  144. Cap for vortec distributor w/o terminals
  145. O2 sensors and leaded gas
  146. XFI guru's, help with idle
  147. Best fuel injection for EFI Rookie???
  148. Napa Syl-Glyde for Lube on Injector O-Rings?
  149. Modifying an Edelbrock Proflo EFI for sb427
  150. 96 Vortec conversion
  151. Walbro pumps
  152. IAT sensor location questions
  153. Fast xfi to Digital 6 hook up
  154. IAT/MAF between manifold & 4150 style TB
  155. Need suggestions for running LT1 ign wires.
  156. how much to pay for TPIS system?
  157. TPI Injectors
  158. Tell me where to go!
  159. Alcohol compatible Fuel Injectors for 350 TPI
  160. ????? for all
  161. Question about Accel GEN 7 and wiring an HEI/6AL box
  162. can someone help
  163. Rock Valley fuel tank/pump
  164. Fuel Safe cell pump mount.
  165. Fuel Injection Setup - Accel Superram unavailable
  166. Is this for real!!!
  167. LT1 Wiring.com
  168. Throttle cable bracket for Accel Pro-ram, etc style throttle body?
  169. Fuel Filters
  170. Accel DFI Tech Line
  171. AZ S&M MEFI4B & Software
  172. difference between these aeroquip fittings
  173. efi tank
  174. Regulator mounting
  175. Project problems
  176. Edelbrock 3551 and Win Proflo Software
  177. Fuel system question
  178. Flat line O2 sensors at idle ( eye burning rich )
  179. Can I get some help with this intermittant Holley problem please?
  180. Are there any computers that do way more than just run the motor?
  181. Fuel system for HSR and 950 in a 350
  182. DIS EFI 8.2L FORD Big Block
  183. Pfm
  184. Cutler EFI
  185. F.A.S.T. XFI setup: Timing/Spark issues on a gen1 427 sbc in a c3 vette
  186. FAST xfi tuning on a fresh startup 427 sbc
  187. software for 92' LT 1 ECM-programming
  188. EFI fuel line sizing/material question
  189. TPI vs TBI
  190. How to calculate flow rate with higher fuel pressure?
  191. Fuel tank questions
  192. F.A.S.T. XFI sequential and speed density mode problems
  193. Individual Cylinder Tuning
  194. AN-6 or AN-8 line for my fuel line?
  195. Fuel injection & vaccuum canisters?
  196. 80's era L98 tpi
  197. VEMS EFI System
  198. LT1 cam
  199. Fuel Cooler
  200. fuel pump help?!?!
  201. whos running procharger and A1000 pump
  202. Eliminator in 1st gen with LT1
  203. Ported LT1 heads VS LT4 heads
  204. Edelbrock LT1 intake?
  205. Custom Aluminum Fuel injection Gas Tank
  206. Acell DFI ignition set up help
  207. Injector flow rating chart?
  208. EFI Puzzler -- higher pressure, leaner burn
  209. LT1 intake swap
  210. GM SB2 heads & fuel injection, anyone running it?
  211. efi on vortec motor
  212. BDS EFI anyone?
  213. 2gen fuel tank
  214. What kind of Fuel cell are you using
  215. ever seen dribbling TBI injectors :
  216. Need fitting suggestions
  217. Does anyone make a direct injection kit for anything?
  218. OBD II Scan Tools
  219. MEFI4B Programing
  220. Did I Do This Right? Pics
  221. Fuel return line ideas for '67 camaro
  222. Russell Full Flow AN hose ends
  223. what line size????
  224. Butler Peformance FI for Pontiacs
  225. Sequential Vs. Batch - Idle Quality
  226. Tuning question egt temps?
  227. Non Oem Efi Questions
  228. efi for 502 67 chevelle ss stock hood
  229. Multi Point Tank Pickups - Walbro / Holley?
  230. Fuel system parts selection
  231. Is vss needed for obd1 l99/lt1
  232. LTI intake w/ Vortec heads
  233. Aftermarket throttle bodies
  234. EFI fuel line question. What did you use?
  235. Fuel sump issue
  236. edelbrock proflo twin turbo?
  237. Why does this oxygen sensor cost so much?
  238. leaded racing fuel and O2 sensors.
  239. If you have a commander 950 how happy are you with it?
  240. Low budget FI
  241. Had a fuel pump problem yesterday.....
  242. Gas Mileage
  243. Regulator before or after fuel injection unit
  244. Wide band 5 wire O2's the same?
  245. Is this a prank?
  246. Efi Help ! ! !
  247. Fuel injection use on a 2-stroke???
  248. q for you efi guys - fuel pressure spikes at idle
  249. Question for anyone who has ever had Holley Projection 2D or 4D
  250. injection advise
