View Full Version : Power Adders
Pages : 1 2 [3] 4
  1. Question for the Turbo Guys...
  2. FINALLY got my car put together and running & now to button it all down ... questions
  3. magnussen supercharger
  4. Supercharger
  5. twin turbo
  6. Boost Timing Master and Vac Advance?
  7. I have obstacles in my way when trying to use my timing light ... questions ...
  8. zz385 350 forged crank fb heads h cam
  9. 5.3 with a turbo in a 85 monte???
  10. Intercool vs Methyl injection
  11. 20 year old Turbo
  12. SBC Turbo Cast Manifolds!
  13. is my motor sufficeint for a supercharger?
  14. LT1 in 2nd gen camaro ... will procharger fit?
  15. 69 gto
  16. AFR 235 for the street!
  17. Eldorado supercharger ?
  18. who knows of a master power dealer?
  19. I might have to take my engine to a Pro.
  20. Quick Procharger Race Bypass Valve Question ...
  21. Single turbo SBC
  22. The motor is alive!
  23. w/g & bov question
  24. RSX Piston Meltdown
  25. Holy Huge Supercharger The New Procharger F4
  26. Twin Turbo SB Mopar
  27. Procharger question?
  28. Vacuum operated exhaust cutout?
  29. weiand 144
  30. KB Twin Screw
  31. Intercooler for 1st gen Camaro
  32. D1SC Bracket that holds cover on blower
  33. procharger C3 corvette (good news)
  34. 7.2:1 comp ratio, just how much BOOST? Pontiac 400...
  35. Procharger with power steering issues - help!
  36. Custom Water/Methanol Injection System
  37. rear mount turbo
  38. HELP with intercooler 1st gen camaro
  39. L92 Turbo or Supercharger?
  40. Please help me Identify my Banks Turbo
  41. Anyone Know About COMP TURBO'S?
  42. Stock 350 block w/ twin turbos?
  43. LS turbo setup in 1st gen f-body, anyone?
  44. twin turbos with or withour intercooler
  45. Procharger on LS engine kit?
  46. is it safe to run nitrous with a dual plane intake
  47. Nelson supercharger
  48. 5.0 KB twin screw
  49. Big block Mopar with engine plate
  50. Programmable 6al2
  51. Tuning on twin turbos
  52. I'm going Twin Procharged
  53. Pictures of my water injection in manifold
  54. bbc 454 upgrades
  55. Juice on a zz430
  56. External wastegate vs. Internal
  57. delete
  58. What Kind of system would you Suggest
  59. Mod motors
  60. oil feed line for a 5.3 turbo
  61. rear gear recommendations
  62. Fuel Tank for Twin turbo
  63. 421ci SBC High Boost/E85/Blower/N2O Project
  64. turbo seized?
  65. too much oil?
  66. Turbo vacuum
  67. procharger ?
  68. Twin turbo engine upgrades?
  69. Dyno day
  70. Edelbrock E- Force Super Charger Install On 2010 Camaro
  71. Sbc with procharger. Which r4 compressor to buy?
  72. Question about my GT35R
  73. Variable Geometry Turbo's
  74. Fuel pressure for blown sbc?
  75. 30 Degree Temp Gain
  76. 4000hp BBC comming soon.......?
  77. Wideband o2
  78. turbo oil return pump
  79. Question about turbo cam
  80. boosting at altitude
  81. Support turbos or not? Pic's Opinions,,,
  82. turbo question
  83. What plugs?? Vortech blown 338SBC with AFR heads
  84. Twin Turbo Ls3
  85. Guess what the wife is getting for christmas?
  86. Help With Initial Setup
  87. procharger with accessories
  88. 2.8 KB supercharger
  89. powdercoating a s/c housing
  90. Forced Induction 101?
  91. magnacharger or harrop
  92. Nitrous, which kits and how much to run?
  93. twin screw snout ext removal anyone suggest proper tool?
  94. Twin turbo V8 systems, can you beat on them???
  95. Looking for some help/info
  96. Fuel for twin turbos
  97. Intercooler flow?
  98. Engine vacuum. How much vacuum does your engine pull rolling down the freeway?
  99. "No buck" turbo UPDATE
  100. exhaust velocity question for turbo guys....
  101. nitrous newbie questions.
  102. symmetrical turbocharger aesthetics
  103. best technique & materials to use for a custom S/C mount?
  104. I want more! Procharge?
  105. Fuel Set up for Blow thru
  106. bought a blower motor... does the blower require oil?
  107. Carb hat
  108. Everything you need to twin turbo a ls3 in a 69 camaro
  109. ls truck manifold 67 camaro twin turbo build
  110. LSx Compression with Boost?
  111. can a rotomaster turbo turbine housing be switched with another make?
  112. vortech v-3 si-trim
  113. Turbo oil drain size?
  114. Who to talk to about blow through carbs
  115. Cant find a crank pulley to get my Vortech V-1 to work with my LS1 swap.. Help!!
  116. No replacement for displacement - really???
  117. Installing intercooler needs pics
  118. SUpercharger Help!!!!
  119. LS7 based lower intake for Kenne Bell 3.6LC
  120. D1 procharger oil feed
  121. corvette accessories and procharger setup in a 1st gen camaro????
  122. Looking for an accessory set up for my KB
  123. procharger wanted
  124. Nitrous tune on dyno or street???
  125. Carbureted Remote mount turbo?
  126. Procharger tubing
  127. Decision on which motor
  128. setting a carbed engine up for a turbo
  129. Blow thru Carb
  130. Procharger Bracket Identification
  131. Help me piece together a very budget single turbo kit for 68 camaro with LT1 please.
  132. Installed Piston Oil Squirters in the new 421" SBC
  133. intercooler ???
  134. Intercooler: horizontal or vertical core
  135. Video of my run on Nitrous at the track.. 68 Camaro
  136. STS Turbo System
  137. Procharger for a carbed bb chevy
  138. Anyone Have Magnuson Issues?
  139. intercooler pipe
  140. NEED HELP!!! Procharger Not making enough boost
  141. custom turbo intakes
  142. BDS 6-71 blower questions....help?
  143. nitrous plumbing questions
  144. ABody Folks with ProCharger LSX Transplant kit - PS fit?
  145. Turbos for idiots?
  146. BOV which do you use
  147. Turbo PCV/evac setup
  148. Twin Procharged Camaro testing......!
  149. Help! I have a Problem with KB set up!
  150. Help Identifying this Duel inlet Turbocharger?
  151. Woul like to buy a magnacharger
  152. Ls6 which blower?magnacharger tvs2300,whipple or kenne bell???
  153. forced induction suggestion and values
  154. Blower EFI inpu
  155. How much Nitrous can I run????
  156. B&M 420 Mega Blower???
  157. Blown 502 with TCI Super Street Fighter 700r4. Fuel mileage????
  158. TVS 1900 / LS3 makes NO POWER!!
  159. Compression confusion
  160. New to Supercharges, have SN2000 & have some questions
  161. D-1SC Procharger installed on a 1968 El Camino
  162. E85 Timing for Procharged 383
  163. 1st gen - ls - TwinTurbo - w/AC
  164. OK turbo guys, how does 2 of these figure out going on my 302sbc as twins,
  165. Here are some good reads for people looking into turbos, got some good calculators to
  166. LSA supercharger on 6.0 Iron block
  167. LF 30 degree coupler, 3.5"
  168. WOW, kind of make you sorry you ever looked at turbos or superchargers huh?
  169. there comes a time in every mans life when faced with this question......
  170. Value of a "turnkey engine supply" or "mast motorsports" engine?
  171. WTB supercharger procharger
  172. Vortech 28 - On 565 CID
  173. 416 with maggy
  174. Cubes or Boost
  175. Vortech ysi 900hp, really
  176. Kenne Bell TS9001 SC Dimensions
  177. turbo 6.0 exhaust tone
  178. I need an intercooler.
  179. Gears for turbo street car
  180. Very Rich ... Blow Through Setup ... Ideas
  181. Best Power Adder for Track/Autocross
  182. Cog belt help
  183. Oil catch setup on Whipple charged BBC
  184. Single turbo ls series header question
  185. H2 magnacharger on my 67 camaro LS1 has anyone done this?
  186. Engine cover ideas?. LS3 w MAGNACHARGER.
  187. Deeds Performance twin turbo Headers
  188. Vortech supercharger on 2012 mustang gt
  189. Turbo Headers Are Available For Pontiacs, o-port and d-port, F & A body
  190. Boosting a SBC for towing
  191. My 67 RS twin turbo lsx e85 build!
  192. Whipple 3300 on BBC
  193. Large Turbo for upper rpm ponies, Nitrous to fight low rpm lag?
  194. Twin turbo on a 327 Engine... help needed
  195. Turbo + Carb questions
  196. How to connect vacuum lines?
  197. Procharger i-1, "Programmable Ratio Supercharger"
  198. nitrous on a big block
  199. Help!! turbo selection
  200. Spark plug gap on turbo motor?
  201. Kenne bell supercharger for 6.1 hemi any ideas???
  202. Procharger plus nitrous
  203. Vortech Centrifugal Supercharger on mild 350?
  204. Stock intake with boost?
  205. Heat exchanger 69 camaro
  206. this guy is nuts! nitro injection
  207. 1967 camaro 427 twin turbo project
  208. Nitrous and Timing.... Whats the purpose???
  209. Best Dyno Shops in Ca. for blow through setups
  210. Mobil 1 Oil question for turbo engines
  211. Turbo Engine I got.
  212. Turbo Pcv ?? Mike norris setup on turbo application??
  213. Looking for a Magnacharger for LS1
  214. C&R Heat Exchanger for '69 Camaro
  215. Oil Backing Out of Dipstick Tube ...
  216. LSx Superchargers! Help
  217. blew my turbo looking for new one and advice.. what works & who to stay away from
  218. turbo away!
  219. Found the limit on my 5.3 the hard way.
  220. converting carbed LQ to procharger efi
  221. Supercharged BBC.. too much crankcase pressure
  222. Intercooler For Second Gen Camaro?
  223. Can I turn the outlet side of my Paxton??
  224. Supercharger
  225. Best Hood for a 1st Gen camaro with a Procharger BBC setup
  226. Looking for more power out of Chevy 350 SBC
  227. twin trubo ls7 headers
  228. Looking for Twin turbo tech and advice, Mopar build
  229. 69 firebird single turbo
  230. turbo
  231. 403 Turbo suggestions?
  232. BBC blower on SBC
  233. 63 Studebaker lark Twin Turbocharger
  234. More power and more WOW for a ZZ430
  235. Hey guys, need some help with a turbo plenum chamber please
  236. 350 ramjet. which style nitrous kit. 100-125 shot
  237. mufflers for twin turbo
  238. edelbrock eforce
  239. 67 Camaro, LS1 with Procharger D1SC using Procharger swap kit
  240. Happy Dyno Day for my TVS 2300 combo!
  241. odd ? can you have too much port volume and head flow with an S/C
  242. Efi kit plus turbo
  243. SBC to Blown BBC
  244. does turbo tubing need to be rolled at the ends?
  245. thoughts on 8.1l 76mm turbo
  246. Banks twin turbocharger system
  247. Best way to supercharge a 355 LT1 engine
  248. ProCharger pipe fabrication and valve installation
  249. C&R heat exchanger for LSA motor in a 1969 Camaro
  250. Best Octane Boost
