View Full Version : Power Adders
Pages : 1 [2] 3 4
  1. Dyno today!
  2. wideband A/F, which one?
  3. Best WG location
  4. Smoking!!!!
  5. Can nitrous be detected?
  6. Fancy new wastegates! ! !
  7. T/T 350 Fuel Injector Sizing
  8. New Kenne Bell Guy-Need Help
  9. E85 with a procharger???
  10. Nova intercooler?
  11. twin turbo sizing for SBC 350
  12. turbo with blow through carb
  13. blow through carb???
  14. 69' Camaro twin turbo, turbo locations?
  15. What Heads to Use on a T/T 350???
  16. Does anyone have a contact at Banks?
  17. Alcohol injections placement?
  18. Anyone using Extreme velocity carb hat?
  19. Has anyone used these turbo manifolds?
  20. Possible to turbo my big block camaro???
  21. twin turbo camaro run-in
  22. Looking for pics of front mount intercooler on 3rd gen camaro!
  23. pre '86 305 TPI super charger?
  24. Need intercooler sizing help.
  25. Procharger problems or not?
  26. What are the best blow thru carbs?
  27. 383 procharger
  28. BBC heads and 6-71 blowers
  29. lock out distributor on a Procharged car?
  30. F1 Procharger Head Unit Price?
  31. Who sells the cheapest aluminum tubing bends?
  32. Someone give me a quick lesson on boost & pressure connections ... See inside ...
  33. Found This On Ebay
  34. Fuel pump ques.
  35. Whipple, twin screw, magna charger for Big Block Chevy's?
  36. turbo kit?
  37. When do you need a BOV???
  38. Intake tubing sizing
  39. Helpful Spreadsheet with compressor maps
  40. nitrous (not noss!) with hyperujunktics
  41. Enough venting for intercooler?
  42. Dual intercoolers vs. single
  43. Can this combo take boost
  44. Questions about ProCharger P1SC....(many)
  45. Procharger Polish
  46. Clocking blower side of a procharger
  47. Building a small block for my camaro...need input
  48. twin turbo camaro run-in ---update---
  49. NOS fuel solenoid for purge?
  50. best flowing air filter?
  51. Nitrous fuel line routing
  52. What fuel pump with 1200 hp and an F2 blower?
  53. 1971 Chevelle twin turbo (pics)
  54. turbo on a carb'ed v8
  55. Where to get a Bypass valve besides procharger??
  56. Just ordered an F2-R
  57. GMPP 350ci 250hp crate engine for turbo application?
  58. Stainless Exhaust Bends - Suppliers? - Welding Tips?
  59. turbo header madterial?
  60. Finally coming together-sorta
  61. Got The Intercooler and Bypass valve installed.. PICS!!
  62. 351 c twin turbo
  63. turbo small block help
  64. a supercharger
  65. Any turbo Basics?
  66. Need turbo big block help please.
  67. Anyone wanna help me try and build an engine?
  68. Blow through problems
  69. does this sound right (turbo sizing)
  70. Decided To Add Turbo's
  71. No intercooler, just meth injection
  72. Fuel system questions
  73. Ignition setup - Digital-7 part #7535
  74. twin turbo big block mopar.
  75. Procharged ZZ383?
  76. V8 project...
  77. Smaller pulley but no more boost?????
  78. Should I cnc port my intake
  79. Where did you install your Water Injection Kit?
  80. Which Carb Vacuum port to Blower Accessories (Vacuum Log) ... Pic inside ...
  81. See any problems with Nozzles for Water Injection Here? Pics Inside ...
  82. supercharger questions??
  83. I'm so stupid!
  84. Procharger quality issues?
  85. FAST dual A/F mounting options
  86. Vortec 8.1 (496 bored .030 over)....turbo'd?
  87. Roots style vs centrifugal
  88. 17.8-18.9 AFR @ idle, thoughts?
  89. Belt slip on Magnacharged LS1?
  90. Which type of TB is most streetable?
  91. ATI clutch drive
  92. Nelson Racings new LSX twin turbo headers
  93. Weiand 142 and 68 Camaro
  94. Procharger-Power Steering- Small Block Chevy
  95. Ideas on how to change current 950 Wideband tune when adding Alky?
  96. Twin Turbo BBC
  97. Prologger wide band system. Opinions please.
  98. Supercharger Help!!!
  99. Procharger prices?
  100. air fuel blues!
  101. Where to buy: Aluminum tubing and silicon hose
  102. need some help here !
  103. Which power adder for this SBC Engine?
  104. Serp Pulley setup for Procharger Motor
  105. Single turbo?
  106. Intercooler prices
  107. Procharger 8 rib drive belts
  108. Intercoolers-does size matter?
  109. 5.0 GT Vortec issue
  110. Corvair twin Turbo
  111. Procharger needs idler pulley
  112. Looking for info on a car...
  113. Which Procharger Pulley is this?
  114. Need thoughts on new dizzy, vacuum advance or not?
  115. This might damage my reputation for asking but are these any good?
  116. electric supercharger for $67 ???
  117. BBC Turbo placement...
  118. By Pass Valve Vent or into the intake
  119. cast iron heads for intercooled twin turbo setup
  120. f1r charger intercooler on 69 maro
  121. Procharger Fuel Pump
  122. What You Need for A Turbo Setup
  123. Procharger and Power Brakes
  124. Nitrous questions
  125. Turbo on 93 Corvette LT1 Block
  126. Alcohol Injection
  127. Any Procharger experts out there??
  128. BBC Turbo Kits
  129. Blow Off question?
  130. Twin turbo headers....where to buy some
  131. Need help deciding on what size turbos to get.
  132. fuel pump block off plate drain.
  133. custom intercoolers?
  134. good high reving race engine? *nitrous injected*
  135. Intercooler tubing clamps. Help me locate.
  136. Anyone a Turbonetics dealer?
  137. good start for a twin turbo set up?
  138. Turboing a BBC
  139. who makes the smallest supercharger?
  140. help with twin turbo timing.
  141. D1sc Accessory Drive Question
  142. Turbo size question.
  143. Would this work??
  144. Paxton SN93 F-body
  145. anyone heard anything about the aluminator?
  146. Comments / advice request
  147. Will 4 inch tubing improve F1C efficiency?
  148. Procharger Giving Me FITS!
  149. new guy
  150. nitrous for LT1???
  151. Ring End Gap On Small Bock Chevy With Procharger
  152. SC LS1 first gen???
  153. Blower cam??
  154. sufficient bottom end for procharger?
  155. LS2 1st Gen F body FI kit
  156. Who makes the best Desktop Dyno for turbo motors?
  157. Is 9.0:1 compression ratio too high for 10lbs of boost?
  158. Where's your Eliminator/A1000?
  159. Intercoolers
  160. supercharging a VUE
  161. PCV on a boosted engine???
  162. Heat wrap turbo?
  163. Martin Turbo setup...
  164. Best methanol injection out there??
  165. BDS blower for LSX
  166. What's the best way to upgrade my 350
  167. Turbo size help
  168. Inline 6 with turbo
  169. Supercharger in 66 El Camino
  170. Blower for 351?
  171. E85 + Boost + "High" Compression?
  172. Turbo oil source. Where to find on SBC?
  173. X hat or super vic
  174. Procharger Alternator mounting on BBC
  175. OK trying to get better idea of possibilities,,,,
  176. To boost, or not to boost?
  177. Twin GT-K1000 project
  178. FAST A/F meter mountung
  179. what the shaft
  180. cannot make over 10 psi of boost
  181. 351 cleveland mini roots blower?
  182. Twin Turbo Olds
  183. pro charger
  184. What's everyone think of this Supercharger?
  185. 351c Centrifugal blower ?
  186. Blown issues!!!!
  187. Procharger Bypass/Surge Valve with Intercooler
  188. Procharger (and others) Videos on You Tube
  189. best forced induction for LT1?
  190. 455 Buick Twin Turbo upgrade kit
  191. Found a Twin Turbo Buick 455 Kit advice needed
  192. Magnacharged Gen III with Front Runner?
  193. Blow through carb and hat sealing
  194. Al. or mild stl. charge tubing?
  195. Pan evac for boosted motor
  196. Evap pump for MotiV8r
  197. From Roots To Procharger?
  198. Probably a dumb question, but...
  199. Too Much!!!!!!!!!!!!!!
  200. MAP / Fuel Reg / By-Pass Valve (Line)
  201. D1SC/355 combo
  202. Turbo LT1
  203. Mock up of the D1SC on my 408 sbc
  204. Vortech S1 trim or B&M 143 roots?
  205. What is the world record? 8-71
  206. Horsepower per pound of boost?
  207. How to change teflon strip in blower?
  208. Any info-how to change teflon strips
  209. Cogged crank pulley
  210. Twin Turbo in a 68 camaro
  211. to cog or not to cog
  212. G body Turbo
  213. Opinions on Banks Twin turbo set-ups...
  214. Procharged Chevy 350
  215. Exhaust Cutout illegal? - San Diego, CA
  216. Intake Charge Temperature
  217. vac lines?
  218. Turbo...Up front or in the back?
  219. Hats
  220. Blown head gasket!!!!!!
  221. B&M 144 blower and power question
  222. How would you build my LT1?
  223. Ignition timing for Supercharged 408
  224. Can I use the EGR port for my brake booster?
  225. Vortech V2 S-Trim on SBC.. need help!
  226. Limiting high rpm boost
  227. Throttle pedal issues...
  228. Twin turbo math question
  229. cam selection for Procharged 350
  230. Running a centrifugal supercharger backwards
  231. super charged ranks
  232. Supercharged s10??
  233. dyno day
  234. Got a free 6-71 Dyer. Need info to put on my 454
  235. Boost reference.
  236. 94mm Turbo Setup Pics
  237. Supercharger
  238. question on inlet pipe diameter - f1 procharger
  239. the juice
  240. Turbo, synthetic or mineral oil?
  241. Surge valve
  242. my new blower setup - procharger F1-R on FE 427
  243. turbo/engine Q
  244. Kenne bell owners
  245. Carbd Procharger Part throttle lean problems
  246. theoretical: what's a blower got that high compression ain't got?
  247. Nitrous question
  248. supercharger
  249. AEM Water/Methanol injection kit
  250. dont know if this is the right section but, lets see hidden nitrous setups!
