View Full Version : Engine Miscellaneous
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14
  1. Sending Unit Has Two Lines?
  2. LS6 454 teardown - need help identifying cam
  3. Harmonic balancer runout - what's acceptable?
  4. Lifters off-center of cam lobe - normal?
  5. Horsepower to Weight Ratios
  6. BBC, Edel-RPM Intake, Cowl Hood, What Air Cleaner?
  7. dyno numbers, help explain
  8. Any Engine Builders?
  9. rear seal options
  10. Who makes this Air Cleaner?
  11. Desktop Dyno Request
  12. Main bearings - Please take a look
  13. Any ideas on cheap thermo barriers for intake bottoms?
  14. Holley carb adj. question
  15. need to find headers.. and does this sound like 500hp?
  16. Main girdle Question. Ford Guys can help too.
  17. Eagle crank need balancing?
  18. What is what I have worth?
  19. Have been debating building a 383 LT1, what crank?
  20. GMPP 18° heads
  21. Lift exceeding flow. please advise
  22. Classic Chambered exhaust?
  23. LT1 Engine
  24. 502 bare blocks
  25. Energy Suspension poly motor mount torque specs
  26. Engine advise.. and contest of sorts
  27. Anyone...300z help needed
  28. engine quest heads
  29. Motown / Bill Mitchell 427 SBC
  30. You usin' a Melling oil pump? Better read this!!!
  31. dse pulley ?
  32. 500 Caddy questions
  33. 502 hood clearance???
  34. 396 Question ?
  35. 355 with bowtie heads??? not enough power!
  36. Olds' mill
  37. cant set installed height
  38. Need help finding correct throttle cab. bracket!!
  39. 632 BBC in 68 Camaro
  40. Belt drive worth it for solid roller SBF?
  41. 454 ideas?
  42. crate motor, crank turning
  43. compression guess??
  44. timing or fuel?
  45. Ford 4.6L vs. 5.0L Modular Engine
  46. Do these timing #s look scorrect?
  47. Desktop dyno this 400 Sbc?
  48. Mini Starter
  49. Went dead?
  50. 400 Balance Plate/offset
  51. Weird starter issue
  52. Ford engine weights
  53. hyd. roller cam rpm's
  54. Canton Pan
  55. oil press. holes in block?
  56. porting & polishing Alum heads
  57. one piece and two piece blocks??
  58. Looking for help on my mopar !?!?!
  59. Why did they do this????
  60. 400 long block motor?.. or 350?
  61. BBC hydraulic roller and beehive springs
  62. 01 durango p0700 code!!
  63. Can Someone DD my motor?
  64. Dynometer in Long Island, NY
  65. Ford Pulleys
  66. Block Fill
  67. fuel fittings AN NPT and ?
  68. How to get 650 horse from my 396?
  69. Noisy Valvetrain
  70. Cam lifters / Assembly lube / storage
  71. Road race pan baffling
  72. gm's serp kit?
  73. Port Matching Vortecs??
  74. 550-600 hp sbc
  75. Sanity Check--Solid Motor Mounts?
  76. Afr 210 Heads
  77. FORD 390 info ?
  78. Backing off valves w/shaft rockers
  79. Piston -> Valve clearance checking
  80. Hiding and Tucking wires?
  81. Difference between Pontiac 350 and Chey 350?
  82. lowering compression
  83. What CR for a 1000hp BBC with Pro charger
  84. Filtermag
  85. Chevy BB 302???
  86. 350 w/bigger crank?
  87. D/D Help.
  88. What is the longest stroke that will fit a stock BBC block?
  89. Crappy day at the dyno
  90. Cleveland-pick-a-part
  91. Firing order!
  92. Cam size and maintinance
  93. How does this cam wear look?
  94. Pontiac engine code help needed.........
  95. Timing Set Questions
  96. Dyno results in
  97. Difference between Merlin III and big M big blocks.
  98. Brodix -2's enough for a 572ci BBC?
  99. Noise - Hydraulic vs Mechanical Roller
  100. sbc 400 ??? @ DCR & CR
  101. Problems with 69 camaro motor
  102. sbc issues??
  103. Oil leak + backfire through carb
  104. Big Inch Small Blocks...
  105. New BBC for the chevelle what to do?
  106. Head specifications 3927185 1970
  107. Pro Comp aluminum BBC heads any good?
  108. Piston wall scoured--am I screwed?
  109. BBC--Piston wall scoured--am I screwed?
  110. engine forums??
  111. New BBC Crate Motor w/o clutch Pivot location
  112. sportmans ll heads????
  113. How much $ for a 396?
  114. Teflon lined braided hose - Anyone use this?
  115. lt1 brackets and assocc.
  116. My engine situation (BBC)
  117. sbc 420 combo
  118. Best electric water pump for a Big block Chevy.
  119. What does it take to build a BBC 496?
  120. dart heads
  121. LT1 valves
  122. early sign of detonation
  123. octane argument
  124. tall bbc valve covers
  125. 96 LT1 engine code VO808YSU
  126. sbc oil pressure drop ?
  127. 180° crank for Pontiac engines?
  128. Any try these on stainless tubing ??
  129. Intake Tightening Sequence
  130. engine internal color
  131. SBC pro's or afficionadoes...need a price check.
  132. carburated lt1
  133. quickchange carburetor
  134. Autozone Big Block?
  135. SBC Steel Crank Identification
  136. 1000hp 351 winsor?
  137. Cold solid lifter lash
  138. 3" Flowmaster Exhaust
  139. engine casting #'s
  140. Need engine starter help ASAP
  141. Help! Boiling Fuel
  142. Low Compression Smog Big Block Turbo Question
  143. Victor Jr water passages.....plug or connect
  144. My Camaro eats Distributors?
  145. Engine Oil Leaking from Breather?
  146. Valve Covers: 400 Pontiac
  147. What water neck to use?
  148. For the people who dont take the Pontiac catch up race serious!
  149. engine troubles!
  150. 2001 Chevy Camaro Trouble
  151. 300 Ford six info needed.
  152. Heim joints for alt adjuster
  153. PCV valve needed?
  154. Whats a good road race motor?
  155. ?s about building an LT1 383
  156. Is a 300hp 20mpg Gen-I sbc possible?
  157. Are MTI 2E ls6 head better than Patroit lsg cnc heads?
  158. LSX carbon v/covers
  159. Cast iron vs. cast steel crank
  160. Tall valve covers in my 67
  161. Cam bearing oil hole location.
  162. Vortecs and Beehive springs
  163. 327 engine upgrades
  164. Help me pick a mini starter
  165. Aftermarket block or used?
  166. turbo v8 or lt1
  167. BBC, getting the good and bad ports close?
  168. Sta-bil?
  169. Problems with my new engine, need direction please..
  170. Destroked high-revver... ?
  171. For resale 2 bolt or 4 bolt?
  172. ZZ4 Spark Plugs
  173. Noise at low RPM, goes away at off-idle
  174. Afr 210 Heads
  175. Dramatic drop in Oil pressure, help!!!!
  176. Well got a heck of a deal on a different engine,,
  177. Hey SB Chevy guys
  178. budget "F-Bomb" engine
  179. looking for an engine
  180. HELP cant keep car running after changing gas tank/fuel sender
  181. Need help
  182. How to tell if your motor turns over.
  183. American Muscle Car Engine tests
  184. How to tell if a 1970 Chevy is numbers matching?
  185. Where to mount fuel regulator.
  186. Does anyone have a Nelson TT set-up...
  187. LT4 hot cam valve springs
  188. Hydraulic roller lifter help
  189. 400 SBC + 400 turbo trans a good combination??
  190. firebird 400 swap
  191. Engine Help
  192. LT1, LT4, Forgotten???
  193. 1.84 valves in a 350
  194. 572 intake height?
  195. Cc305 7 305-8
  196. World 540 cam
  197. Engine Install Question
  198. Chevy 2 piece valve covers ..anyone???
  199. 396 Crank Question
  200. Valve cover bolt not starting
  201. Shredded the distributor gear
  202. Belt noise
  203. solid roller lifters, horizontal or vertical lifter bars?
  204. Roller rockers?
  205. closed or open chamber heads
  206. Confused about engine balancing...
  207. Vented gas cap
  208. 427 clutch pivot ball
  209. Carbon fiber valve covers finally arrived today...
  210. SBC Locking Oil Dipstick, anyone know?
  211. -Throttle by Wire-
  212. Help, Help
  213. Which intake?
  214. 5.3 L vortec motors
  215. 385 FB steaming oil?
  216. How much power are we talking about here?
  217. GM Crate motor cam selection
  218. Ford engine decision.........large or small?
  219. Need Answers Fast!
  220. Fuel system returns
  221. hehe super micro size SBC
  222. Which Lokar thr. cable for .71 Camaro??
  223. What are these holes?
  224. Engine hoist lift plate?? concern
  225. Morse to pinch clip throttle cable swap?
  226. Oil pan for peace of mind - 68 Firebird
  227. Dyno question
  228. Is my engine internally or externally balanced?
  229. Engine Stand
  230. Stroker Question, 383 or 408?
  231. Solid Roller
  232. throttle body spacer (what does it do)
  233. 1.5 or 1.6 roller rockers for my set up???
  234. Who makes GM Pistons
  235. older bbc to efi conversion
  236. Oil cooling.
  237. Is a 235 cc head too big for a small block 434?
  238. PCV valve ideas??
  239. new top end!!!
  240. 350 Crate Motor Teardown?
  241. 32 valve bolt on SBC head
  242. cc vs comp???
  243. Schubeck Racing Roller X Lifters
  244. head stud torque specs and spark plugs???
  245. Engine Testing
  246. Big Block To Small Block Frame And Motor Mounts?
  247. ID'ing Old Hemi Numbers
  248. lt1 motors in chevelle/camaros
  249. 5.7 hemi swap 1966 coronet
  250. Roush engine questions...
