View Full Version : Engine Miscellaneous
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]
  1. Which camshaft to a 350 with 461 heads
  2. Are these 461 or 461x heads?
  3. possible intake sucking oil?
  4. Mock up / replica / foam engine for Ford 5.0L Coyote?
  5. Need some tuning help, '94 Astro with an LT1
  6. Decided to fix my 327, but wich cam for it?
  7. So been working on a rod/piston combo for my 3800 Buick engine,,,,
  8. Cross ram injection for LS engines.
  9. First time engine start, run and vibration.
  10. Crane Anti pump lifters or Comp high energy?
  11. Old School Ford 5.0 EFI
  12. Camshaft problems.. 327chevy
  13. Getting the fuel from the inside to the outside of the frame rail
  14. Accusump custom cut-on switch
  15. Show me your Accusump installation!
  16. LS Chevrolet Script Billet Valve Covers
  17. Gen VI 454 stock piston weight
  18. Help with engine decipher.... please
  19. Cleaning Oxidation off a Aluminum Block
  20. short block pontiac
  21. Power Steering Pulley Installer
  22. Billet Specialties Tru-Trac Installation SBC
  23. LS Valve Cover Adapter
  24. Don Hardy Race Engine LS 427 with Billet Specialties Tru Trac Serpentine System
  25. LS Engine learning curve is steep!
  26. litre's gallons per hour
  27. -12 tube oil breather
  28. Chevrolet engine question..
  29. 2017 Gen V LT1 with 8sp harness and fuel questions
  30. Poly Loc Fail - Schumacher
  31. 428/455 into a 69 bird
  32. air cleaner for 68 camaro cowl hood
  33. Can I match a Pontiac 455 with a Chevy BW Super T10 four speed
  34. Video Billet Specialties LS Tru Trac Installation
  35. Custom OTR
  36. throwing oil out oil pan
  37. Radical SR8 casting flaw oil leak
  38. Engine Vacuum
  39. Engine combination, help needed
  40. Ground clearance to oil pan and bellhousing- Third Gen Nova
  41. Pinto -- Move engine back or front wheels forward
  42. Aerospace Vacuum Pump with Alternator, Power Steering Pump and Electric Water Pump
  43. Powdery white crust on Aluminum block
  44. GM Type II Pump Whine - Any Magic Remedies?
  45. aluminum head screw up drilling broken stud
  46. Moroso oil pan bolt issue?
  47. Amsoil oil is right for me
  48. will this cause my fuel pump to die an early death
  49. Help me pick a Autocross cam for my LS1/t56 70 Camaro build please
  50. Giant LS3 Intake manifold Dyno shoot out
  51. Light 327 11-1 Forged Pistons?
  52. Accusump one way valve question
  53. AEM Dry Air Filters versus others ?
  54. SBC/Brownfield heads, Why intake valves .100 longer than exhaust?
  55. Turnkey engines
  56. Mopar Experts: Opinions Needed On Engine/Trans Choice
  57. Pontiac 1973 Trans Am HP to the wheels on dyno to compare to improved 455 rebuild
  58. New 5.7 Hemi swap into a 70 challenger help wanted...
  59. Can lifters go bad? Need advice
  60. coyote swap 1969 mustang
  61. When to put synthetic oil in a fresh engine (???)
  62. PCV Valve Baffle
  63. Merlin Engines.. HELP!!!!!!
  64. Too much vacuum
  65. Help identifying engine
  66. 69 Camaro Gen V LT4 Converions?
  67. Gen 1 SBC oiling problem.
  68. Engine monts.. sb vs bb
  69. LS Swap Question
  70. adjusting hydraulic roller cam
  71. Breaking aluminum rocker arms
  72. LS type intakes
  73. 6.0 LS Build
  74. 1969 Mustang 392 stroker combo
  75. Need help selecting cam for my setup.
  76. Bronze dist gear and valve guides impacting used oil analysis numbers? Or bearings...
  77. Pankl connecting rod
  78. Midgrade Gas and twin turbos ...
  79. Any vendors running Detroit Speed deals?
  80. msd ls ignition map port to gm map sensor
  81. ARP Bolt Torque Specs
  82. Help me build a better pcv system
  83. 1971 Camaro engine mounts... LS swap
  84. 69 camaro with zl1 aluminum 427bb
  85. Oldsmobile Engine Power Steering Pump Solutions - What have other people tried?
  86. Big Block Chevy-Water pump has no heater or by-pass outlets...
  87. 408 CID LS Build 4.25" Stroke - Oil Pan Issues - Detroit Speed Subframe
  88. Billet Specialties V-Trac Pulley System
  89. Advice for storing my car
  90. Cam for ls3
  91. 2 piece mini starter
  92. Autocross Oil Pan
  93. Question on cowl induction for 60's era Chevy
  94. Double check me on my oil cooling setup
  95. Gen V LT4 question **HELP**
  96. Accusump and check valve
  97. Name that cam
  98. aluminum head options for 461 stroker to get to 650hp Pontiac 400 block
  99. LQ4, LQ9,LS2,3,6,7 Realistic builds 500 rear wheel HP
  100. BTR LS2 STG2 CAM running in a LS3?
  101. Serpentine conversion question
  102. Camaro C&R radiator users.
  103. Intake Piping - Rattle Can Ceramic/Thermal Barrier?
  104. Serpentine Moves forward on A/C compressor pulley
  105. Can Earl Fittings be used on Russell Hose
  106. From blowing oil pan gasket to now blowing dipstick tube - help
  107. Engine sourcing feedback...
  108. Ls block can this be fixed?
  109. L94 block Cracked!! Can this be fixed?
  110. Ls-700r4
  111. Any do exhaust wrap + cermaic coating?
  112. LS2 Is Dieseling????
  113. LS swap oil pans...
  114. Best/strongest SBF motor mounts?
  115. School me on a good fuel system
  116. ATK Engine Problems
  117. Need help choosing the right cam
  118. DSE subframe what oil pan with stroker motor
  119. Frame mounts
  120. stock dipstick tube with Milodon pan?
  121. AFR head corrosion question
  122. LS offset?
  123. Compression height and rod length
  124. Preferred LS spark plugs?
  125. 347 Stroker suppliers?
  126. 5.3 vortex (lm7)
  127. LS blocks
  128. LSA Accessory Drive Help
  129. Help me ID these engine frame brackets - 69 Impala
  130. Which Heads
  131. One clean spark plug
  132. Starting a fresh engine from 2 year storage lube question
  133. Starting a fresh engine from 2 year storage lube question
  134. Serpentine swap help needed
  135. Dipstick side swap?
  136. L92 cam recommendation
  137. new rocker arms/ pushrods
  138. Pro-Classic or Ultra Pro?
  139. 427 BBC with Moroso 20460 8 quart pan
  140. Dry Sump reservoir Caps?
  141. Filter for Moroso vac pump regulator?
  142. LSA install
  143. Performance shop near OC-LB California
  144. Some help please...
  145. Bolt-on PS Tank or Remote Reservoir?
  146. Cam selection help – Is there a near stock no compromise option?
  147. ford302
  148. Down Shifting Problem
  149. Big Block in Falcon
  150. lsa Blower on LS1
  151. Howard's Composite Fuel Pump Rod
  152. Good Cam Choice?
  153. Fuel pump fuse gets hot
  154. LS Head Gasket / Compression Help
  155. Accessory drive recommendations?
  156. Engines direct from Chevrolet or authorized distributors?
  157. Powermaster Starter
  158. engine, cam choice.
  159. LQ4 Spun Cam Bearing
  160. Race Tec Pistons
  161. Chevy 396
  162. 416 Forged TVS2300 Build recommendations
  163. Leak Down Test on SBC
  164. BTR LS3 STG2 N/A CAM for 408 lq9 / supercharger?
  165. Broken tap
  166. Windage tray modification?
  167. LS427/570 injector specs...
  168. Will there be an EV section on this forum soon?
  169. Help with 502 timing specs
  170. KRE High Port Heads Second Gen Trans Am
  171. Break in oil question
  172. using oil
  173. SBC gasket help
  174. Old Timey Stroker
  175. Anyone running Jones Racing accessories on a street car?
  176. Sniper efi
  177. Roller cam repair / regrind? Btr stg ii ls3 n/a grind
  178. Actually,,-7
  179. chevy 400 sbc 2 bolt main?
  180. How would build a sbc 400 ? heads, cam ect
  181. Throttle body size question
  182. ls3 engine mounts
  183. Driver’s Side Alternator Bracket
  184. Progression Ignition distributor Real deal or real waste of money?
  185. Recommend a PT/RR baffled wet sump SBC oil pan with crank scraper for 327?
  186. 73 Firebird trunk mounted fuel cell
  187. Summit 8708 cam
  188. Wanted- Ford modular 4.6 crankshaft flange bolt circle diameter
  189. Catch can.
  190. Important question on solid lifter adjustment
  191. Brownfield heads, "60/40" offset, and roller rockers without needles. Help!
  192. Need help establishing an engine value
  193. SBC Power Steering Pump mounting bracket question
  194. Question on Melling verse GM pick-up tube O-ring
  195. Skipwhite engine 434 sbc
  196. 302 Windsor Build Pre-planning
  197. Wegner Accessory Drive
  198. West Coast aluminum ls block needed for mockup
  199. Vegas Machine/Nevada Crankshaft of LV good?
  200. SBC 383, Piston to Valve clearance
  201. Ever heard of a torque spec for distributors?
  202. Brodix cast iron engine blocks?
  203. Dry Sump install in First Gen with stock subframe and gen 1 SBC
  204. Gen 6 GM Small Block
  205. Motor Mounts
  206. Camaro or fox body running motor
  207. 454 LSX Runway Racer
  208. AutoX Oil Pan
  209. Gm 502 crate engine question(s).
  210. Can anyone identify this engine?
  211. What size rocker studs do I need?
  212. What is the origin of maximum piston speed of 4,000 ft./min rpm limit?
  213. 2019 lt BALANCER PULLER ?
  214. How to choose correct size balancer for solid lifter 327
  215. Lsa supercharger vs procharger
  216. The dreaded one piece rear main seal
  217. LS-LT combo engine question
  218. Wild looking custom engines
  219. Rear main seal trouble
  220. Removing LS3 from second gen Camaro
  221. LT4 Rocker arm issues
  222. Engine Core Fee...LT1 6.2 Gen V engine.
  223. BBC builder in WA state?
  224. Double hump head question
  225. 434 SBC Build
  226. BBC in a Pro tourer?
  227. Replace lifter on BBC without removing intake
  228. Am I ok to machine my intake so my valve covers fit?
